楼主: tigcat
【分享】清理工具drawing purge9.0.0版本[20240620更新]
发表于 2021-5-19 18:56:03 | 显示全部楼层
官网说明8.3.0.0支持CAD版本2012~2022
https://apps.autodesk.com/ACD/zh-CN/Detail/Index?id=3773138176974634673&appLang=en&os=Win32_64&autostart=true
Drawing Purge描述
Compatiblewith Autodesk® AutoCAD® 2012 to 2022.
Pleasenote that this app will not work with AutoCAD LT version
After installing the app,if the commands are not working please read the Frequently Asked Questions page.
There are 2 commands forthis plug-in
1.DWG-PURGE
To purge the CurrentDrawing
By entering DWG-PURGE atthe command line this plug-in will delete all the DGN unreferenced LineTypes,RegApps and Annotation Scale.
Also a dialog box willshow with list of any XRefs attached to the drawing that needs to purge.
By clicking 'Purge' willstart to purge the attached XRefs.
2.DWG-PURGE-BATCH
To purge multiple drawingswithout opening the files.
In DWG-PURGE-BATCH you canadd the drawings by following methods
  • By     selecting the drawing from 'Select drawing' button
  • By     selecting a folder
  • Copy/Paste     a folder path
  • Drag and     drop
From this dialog box go toOptions tab for more options.
  • Purge the     drawings and save to a different location
  • Purge the     drawings and add a suffix to the file name e.g:- Mydrawing_purged.dwg
  • Purge and     save the drawing to another version
 楼主| 发表于 2021-5-20 10:56:59 | 显示全部楼层
https://apps.autodesk.com/ACD/zh-CN/Detail/Index?id=37731381769 ...
对,官网作者回复我时也说是支持的。但实际使用过程中,发现有些低版本的cad中的字典清除不了,原因不清楚。
发表于 2021-11-1 14:12:45 | 显示全部楼层
非常感谢,一直用这款插件
 楼主| 发表于 2022-7-19 08:58:29 | 显示全部楼层
官网已于2022.05.17更新了插件,可以支持最新的cad2023了。提供给大家下载。
发表于 2022-7-23 10:33:24 | 显示全部楼层
可以的这个东西---
发表于 2023-3-27 13:08:54 | 显示全部楼层
谢谢楼主分享
发表于 2023-4-21 19:06:57 | 显示全部楼层
非常实用的插件
发表于 2023-4-21 22:23:36 | 显示全部楼层
2023.3.29更新了8.3支持2024。很好奇软件版本为啥一直8.3
 楼主| 发表于 2024-6-20 20:20:52 | 显示全部楼层
更新20240605官网版本.新版本更新版本号为9.0.0.0,新增了script功能.值得拥有!
发表于 2024-7-5 15:48:17 | 显示全部楼层
没想到 你泡论坛 二十年之久了哈
GMT+8, 2025-5-1 14:46 , Processed in 0.235851 second(s), 17 queries , Gzip On.
