查看: 712|回复: 0
麻烦哪位大神帮改一下导出单行文字代码
发表于 2020-6-9 08:49:03 | 显示全部楼层 |阅读模式
(defun c:yhb()
   (if (= (setq n (getint "\n保存文字时每行的个数<1>:")) niL)
       (setq n 1)
   (princ "\n请选择单行文字:")
   (if (setq ssa (ssget '((0 . "text"))))
       (if (setq wjm  (getfiled "请指定提取结果存盘文件" "C:\Users\ooxx\Documents\AAAA" "csv" 1))
               (setq m (sslength ssa)
                     i 0
                     zfc ""
                     ff (open wjm "w")
                     j 0
               (repeat m
                   (setq dxf (entget (ssname ssa i))
                         i   (1+ i)
                         wz  (cdr (assoc 1 dxf))
                         j   (1+ j)
                   (if (= j n)
                           (setq zfc (strcat zfc wz "\n"))
                           (princ zfc ff)
                           (princ zfc)
                           (setq zfc "" j 0)
                       (setq zfc (strcat zfc wz ","))
              (if (< 0 j n)
                      (setq zfc (substr zfc 1 (1- (strlen zfc)))
                            zfc (strcat zfc "\n")
                      (princ zfc ff)
                      (princ zfc)
              (close ff)
           (princ "\n没有指定提取结果存盘文件")
       (princ "\n没有选取任何单行文字!")
以上是可以导出选中的单行文字,但是同一个文字点选多次也只导出一个,我想点多少次就导出多少个,重复的也要导出来,谢谢老师。
GMT+8, 2025-5-2 08:03 , Processed in 0.149925 second(s), 25 queries , Gzip On.
