查看: 1190|回复: 5
VB新手请教个问题,为什么用轻便多义线画出来的矩形不能填充。
发表于 2020-5-25 11:05:45 | 显示全部楼层 |阅读模式
    Dim HatchObj As AcadHatch
    Dim PatternName As String
    Dim PatternType As Long
    Dim bAssociativity As Boolean
    PatternType = 0
    PatternName = "ANGLE"
    bAssociativity = True
    Set HatchObj = acadapp.ActiveDocument.ModelSpace.AddHatch(PatternType, PatternName, bAssociativity)
  Dim Ld1 As AcadLWPolyline
  Dim Ld2 As AcadSolid
    syu(0) = 0: syu(1) = 0
   syu(2) = 200: syu(3) = 0
   syu(4) = 200: syu(5) = 200
   syu(6) = 0: syu(7) = 200
   syu(8) = 0: syu(9) = 0
    Set Ld1 = acaddoc.ModelSpace.AddLightWeightPolyline(syu)
    HatchObj.AppendOuterLoop (Ld1)
    HatchObj.Evaluate
    acadapp.ActiveDocument.Regen True
发表于 2020-5-25 14:24:51 | 显示全部楼层
    Dim AcadDoc As Object
    PatternType = 0
    Set AcadDoc = ThisDrawing
    Set HatchObj = AcadDoc.ModelSpace.AddHatch(PatternType, PatternName, bAssociativity, 0)
    Dim outerLoop(0 To 0) As AcadEntity
    Dim syu(0 To 9) As Double
    Set outerLoop(0) = AcadDoc.ModelSpace.AddLightWeightPolyline(syu)
    HatchObj.AppendOuterLoop (outerLoop)
    HatchObj.Evaluate
    AcadDoc.Regen True
 楼主| 发表于 2020-5-25 16:51:28 | 显示全部楼层
谢谢您,再问一下,我如果想控制填充的颜色该添加什么语句呢?
发表于 2020-5-25 20:18:09 | 显示全部楼层
    PatternType = 0
    HatchObj.color = 1 '红色
    HatchObj.Evaluate
    AcadDoc.Regen True
 楼主| 发表于 2020-5-25 21:08:11 | 显示全部楼层
非常感谢
 楼主| 发表于 2020-9-14 17:31:37 | 显示全部楼层
你好,想再次请教一下,如果想填充RGB颜色需要更改哪里,谢谢。
GMT+8, 2025-5-1 05:31 , Processed in 0.158379 second(s), 23 queries , Gzip On.
