查看: 1045|回复: 0
输出全局变量及函数名至csv文件
发表于 2020-4-27 15:42:14 | 显示全部楼层 |阅读模式
  1. ;输出函数名及全局变量
  2. (defun c:tt1 (/ nn l fn)
  3. (setq nn (open "c:\\函数.csv" "w"))
  4.   (setq l (mapcar 'eval (atoms-family 0)))
  5.   (if (setq fn (getfiled "" "" "*" 4))
  6.     (progn
  7.       (load fn)
  8.       (setq a
  9.              (mapcar
  10.                'print
  11.                (vl-remove-if
  12.                  '(lambda (x) (= "" (substr x 1 2)))
  13.                  (mapcar
  14.                    'VL-PRINC-TO-STRING
  15.                    (vl-remove-if
  16.                      '(lambda (x) (member (eval x) l))
  17.                      (atoms-family 0)
  18.                    )
  19.                  )
  20.                )
  21.              )
  22.       )
  23.
  24.       (if a
  25.         (progn
  26.         (setq b (vl-remove-if'(lambda (x) (= (type (eval (read x))) 'SUBR)) a))
  27.         (foreach n a (write-line n nn))
  28.         (if b
  29.          (progn
  30.             (write-line "全局变量为"  nn)
  31.             (foreach n b (write-line n nn))
  32.            )
  33.         )
  34.         (close nn)
  35.         )
  36.       )
  37.     )
  38.   )
  39.   (ALERT "文件保存至c:\\函数.csv")
  40.   (princ)
  41. )
GMT+8, 2025-5-24 19:25 , Processed in 0.131262 second(s), 23 queries , Gzip On.
