查看: 6009|回复: 27
图块原位缩放
发表于 2020-3-28 23:27:11 | 显示全部楼层 |阅读模式
汉化一个英文版的图块原位缩放
注意dcl文件名为“BLKSCALE.DCL”放搜索目录或者lisp程序改下路径,源码在这里了,有点dcl基础的都可以随意diy
;***        BLKSCALE.LSP
;***        Written by Don J. Buschert
;        Southern Alberta Institute of Technology
;        1301 - 16th Ave. N.W.
;        Calgary, Alberta Canada
;        T2M 0L4
;        don.buschert@sait.ab.ca
;        Version 3.2        03/08/95
;        Fixed bugs in List Box.
;        Version 3.1        02/09/95
;        Added ability to select blocks by selection set
;        Version 3.0  10/18/94
;        This dialog program quickly changes the scale of selected blocks,
;        using the insertion point of the block as the reference point.  The
;        scale may be an absolute or relative value to the block's existing.
;        Dialog Options
;        Select All...                Selects all the blocks in the list box.
;        Clear All...                Clears the selection of blocks.
;        Select Objects                Allows selection of blocks
;        Relative                Scales blocks relative to their existing scale.
;        Absolute                Scales blocks to an absolute scale
;        Scale factor                The scale factor of which the blocks will be scaled.
;***        Function BKSC_BLKLIST
;This function tests the block name retrieved via TBLNEXT to see if it is
;not externally dependant; then adds it to the block name list.
(defun BKSC_BLKLIST ()
  (if bksc_block_item
      (setq bksc_block_name (cdr (assoc '2 bksc_block_item)))
      (setq bksc_block_code (cdr (assoc '70 bksc_block_item)))
      (if (and
            (if (eq (logand bksc_block_code 1) 1) nil T);if anonymous...
            (if (eq (logand bksc_block_code 16) 16) nil T);or externally dependant...
        (progn ;then...
          (if (not bksc_block_list)
            ;create the block list,
            (setq bksc_block_list (list bksc_block_name))
            ;else add name to it
            (setq bksc_block_list (cons bksc_block_name bksc_block_list))
  ;sort list alphabetically
  (if bksc_block_list
    (setq bksc_block_list (acad_strlsort bksc_block_list))
;***        Function BKSC_CHECK
;This function checks to see if the minimum data requirements have been
;inputted by the user...
(defun BKSC_CHECK ( / )
  (if (and (or (not bksc_name_list);see if blocks have been picked...
               (eq bksc_cbck "");empty callback
          (not bksc_sst2);see if blocks were selected via selection
    (alert
      (strcat "请选择块!")
      (done_dialog);end the dialog
      (setq bksc_doit T)
;***        Function BKSC_GET_BLOCKS
;This function takes the callback from the list box and returns
;a list of the selected block names...
(defun BKSC_GET_BLOCKS (value)
  ;convert it to a list
  (setq bksc_blk_nlis (string_to_list value))
  ;if there were blocks picked...
  (if bksc_blk_nlis
      ;create the name list
      (setq bksc_name_list
        (list
          (nth (nth 0 bksc_blk_nlis) bksc_block_list)
      ;if there is more than one block picked...
      (if (> (length bksc_blk_nlis) 1)
          (setq bksc_coun 1);counter set to 1 to get second element
          (repeat (- (length bksc_blk_nlis) 1)
            ;retrieve name from original list
            (setq bksc_elem
              (nth (nth bksc_coun bksc_blk_nlis) bksc_block_list)
            ;append to block name list
            (setq bksc_name_list (cons bksc_elem bksc_name_list))
            ;step up counter
            (setq bksc_coun (1+ bksc_coun))
  ;pass message to "selection_msg" tile
  (if bksc_blk_nlis
    (if (> (length bksc_blk_nlis) 0)
      (set_tile "selection_msg"
        (strcat
          "已选择了: "
          (itoa (length bksc_blk_nlis))
          " 个图块"
;;;          (if (> (length bksc_blk_nlis) 1)
;;;            "选择了"
    (set_tile "selection_msg" "")
  ;sort the layer name list alphabetically...
  (if bksc_name_list
    (setq bksc_name_list (acad_strlsort bksc_name_list))
;***        Function  BLKSCALE
;This is the main program, load dialog version...
(defun C:BLK ( /
        bksc_block_list        ;Block List for List Box
        bksc_block_code        ;Block 70 code.
        bksc_block_item        ;Block item.
        bksc_block_list        ;List of all valid blocks for dialog list box.
        bksc_block_name        ;Extracted block name.
        bksc_blk_nlis                ;Block name list from dialog callback.
        bksc_cbck                ;callback for check
        bksc_coun                ;Counter.
        bksc_doit                ;Flag which executes scaling portion of routine.
        bksc_elem                ;Element.
        bksc_elis                ;Entity data list.
        bksc_enam                ;Entity name.
        bksc_enty                ;Entity.
        bksc_indx                ;Index.
        bksc_name_list                ;String list of all the selected blocks from the
                                ;dialog list box.
        bksc_poiI                ;Insertion point of block.
        ;bksc_scale                ;New block scale.
        bksc_sst1                ;Selection set of selected blocks.
        bksc_sst2                ;Selection set containing block objects only.
        bksc_strg                ;String value from selection method.
        ;bksc_type                ;String which determines if scaling is Absolute
                                ;or Relative (GLOBAL).
        bksc_xscn                ;Current extracted block scale.
        sv_blipmode                ;"BLIPMODE".
        what_next                ;Controller for dialog display...
  (graphscr)
  ;Define error routine for this command
  (defun blkscale_error (s)
    (if (/= s "Function cancelled.");if ^c occurs...
      (princ (strcat "\nError: " s))
    (if olderr (setq *error* olderr))
    (if sv_blipmode (setvar "BLIPMODE" sv_blipmode))
  (setq olderr *error*)
  (setq *error* blkscale_error)
  (setvar "CMDECHO" 0)
  (command ".UNDO" "M")
  ;turn off blipmode
  (setq sv_blipmode (getvar "BLIPMODE"))
  (setvar "BLIPMODE" 0)
  ;create a list of all the blocks in the drawing
  (setq bksc_block_item (tblnext "BLOCK" T))
  (bksc_blklist)
  (while (setq bksc_block_item (tblnext "BLOCK"))
    (bksc_blklist)
  ;set the scale type global variable...
  (if (not bksc_type)
    (setq bksc_type "Absolute")
  ;initialize the dialog
  (if (findfile "BLKSCALE.DCL" );
    (if (not bksc_block_list); if there are no blocks in drawing...
      (alert "没得图块你干啥要缩放呢!")
      ;else load dialog...
        (setq what_next 3)
        (while (< 2 what_next)
          (setq dcl_id (load_dialog "BLKSCALE.DCL"))
          ;dclfile
          ;open the dialog box
          (new_dialog "blkscale" dcl_id)
          (set_tile "block_YWSF"  "图块原位缩放 汉化by 图途")
          ;set the tile defaults...
          ;set the message tile...
          (if bksc_sst2
            (set_tile "message"
              (strcat
                (itoa (sslength bksc_sst2))
                " block(s) found..."
          ;set the "block_list" list box
          (start_list "block_list")
          (mapcar 'add_list bksc_block_list)
          (end_list)
          ;set the radio button
          (if (eq bksc_type "Absolute")
            (set_tile "absolute" "1")
            (set_tile "relative" "1")
          ;set the scale factor
          (if (not bksc_scale)
            (setq bksc_scale (getvar "DIMscale"))
          (set_tile "scale" (rtos bksc_scale))
          ;if there was a selection of layers via Select Objects <...
          (if bksc_strg
              (strcat bksc_strg
                      " Block"
                      (if (> (atoi bksc_strg) 1)
                        "s"
                      " selected...")
          ;define action for tiles
          (action_tile "block_list"
            (strcat "(setq bksc_cbck $value)" ;for check routine...
                    "(bksc_get_blocks $value)"
          ;if the Select All... button is pressed, run this program...
          (action_tile
            "select_all"
            (strcat
              "(select_all bksc_block_list \"block_list\")"
              "(bksc_get_blocks list_string)"
          ;if the Clear All... button is pressed...
          (action_tile "clear_all"
            (strcat "(set_tile \"block_list\" \"\")"
                    "(set_tile \"selection_msg\" \"\")"
          ;if the select objects button is pushed...
          (action_tile "select_entities" "(done_dialog 3)")
          ;if the absolute radio is picked...
          (action_tile "absolute" "(setq bksc_type \"Absolute\")")
          ;if the relative radio is picked...
          (action_tile "relative" "(setq bksc_type \"Relative\")")
          ;if a value is placed in the scale box...
          (action_tile "scale" "(setq bksc_scale (atof $value))")
          ;if the help button is picked...
;disabled (action_tile "help" "(saithelp \"blkscal\")")
          ;if the "do it" button is picked...
          (action_tile "help" "(saithelp)")
          (action_tile "accept" "(bksc_check)")
          ;if the "exit" button is picked...
          (action_tile "cancel" "(done_dialog)" )
          (setq what_next (start_dialog))
          (cond
            ;if Select < button was picked
            ((= what_next 3)
               (setq bksc_sst2 (ssget (list '(0 . "INSERT"))))
               (if bksc_sst2
                   (setq bksc_coun (sslength bksc_sst2))
                   (if bksc_sst2
                       ;set the string for the message
                       (setq bksc_strg (itoa bksc_coun))
                       ;clear the block name list
                       (setq bksc_name_list nil)
                 (alert "No blocks were selected...")
          (unload_dialog dcl_id)
        );end of while
       );end of progn
     );end of if
   (princ "\nUnable to find BLKSCALE.dcl...")
(defun saithelp()
(alert "其实操作很简单,自己测试一下。\n 感谢源码,我只是搬运工!")
  rocess the Block Name list
  (if bksc_doit
    (if bksc_name_list
        (foreach n bksc_name_list ;for each block name
          (princ (strcat "\nScanning drawing for block " (strcase n) "... "))
          (setq bksc_sst1 (ssget "X" (list (cons 2 n))));get a selection set
          (if bksc_sst1 ;if successful
              (princ (strcat (itoa (sslength bksc_sst1)) " found, updating..."))
              (setq bksc_indx 0)
              (repeat (sslength bksc_sst1);repeat for each entity
                (setq bksc_enam (ssname bksc_sst1 bksc_indx));get ename
                (setq bksc_elis (entget bksc_enam));get entity data list
                ;determine the scale factor for the block
                  (setq bksc_xscn (/ bksc_scale (abs (cdr (assoc 41 bksc_elis)))))
                  (setq bksc_xscn bksc_scale)
                (setq bksc_poiI (cdr (assoc 10 bksc_elis)))
                (command ".SCALE" bksc_enam "" bksc_poiI bksc_xscn)
                (setq bksc_indx (1+ bksc_indx))
            (alert
              (strcat "Block " (strcase n)
                      " has not been\n"
                      "inserted in the drawing!\n"
                      "Use the INSERT command to insert it first..."
        );end of foreach
      );end of progn
      (if bksc_sst2
          (setq bksc_indx 0)
          (repeat (sslength bksc_sst2);repeat for each entity
            (setq bksc_enam (ssname bksc_sst2 bksc_indx));get ename
    );end of if
  );end of if
;***        End of Progra
;***        Support functions
;***        Function (STRING_TO_LIST)
;        This function converts a string "1" or "1 2 3" into a list
;        (1) or (1 2 3).  This is useful for dialog list callbacks
;        which return strings.
(defun STRING_TO_LIST (strg / counter string_item string_list)
  (setq counter 1)
  (while (<= counter (strlen strg));as long as counter is less= to string
    (setq string_element "")
    (while (and ;as long as
             (<= counter (strlen strg));counter is less= to string or
             (/= (setq string_item (substr strg counter 1)) " ");grab item
      (setq string_element (strcat string_element string_item))
      (setq counter (1+ counter))
    );end of while
    (if (>= (strlen string_element) 1)
      (if string_list ;append to list,
        (setq string_list (cons (atoi string_element) string_list))
        (setq string_list (list (atoi string_element)));else create list
  );end of while
  ;reverse the list, this returns it with the function...
  (if string_list
    (reverse string_list)
发表于 2020-4-18 14:01:13 | 显示全部楼层
谢谢楼主分享     支持一下
发表于 2020-4-11 18:52:50 | 显示全部楼层
这个不是CAD自动的吗 我就得CAD2000上面
发表于 2020-4-3 19:59:46 来自手机 | 显示全部楼层
???论坛好像已经有了,很简单的代码,没有dcl
发表于 2020-3-29 13:08:50 | 显示全部楼层
谢谢! jun353835273 分享程序!!!!!
发表于 2020-3-29 16:45:29 | 显示全部楼层
是什么东西啊我看看
发表于 2020-3-30 00:30:16 | 显示全部楼层
发表于 2020-4-1 13:25:54 | 显示全部楼层
发表于 2020-4-3 11:07:08 | 显示全部楼层
看看里面有什么
发表于 2020-4-3 14:16:39 | 显示全部楼层
看看 是什么东西哦
发表于 2020-4-3 14:54:26 | 显示全部楼层
谢谢楼主分享!
GMT+8, 2025-5-24 16:52 , Processed in 0.203084 second(s), 29 queries , Gzip On.
