查看: 1581|回复: 1
[基础] 发送命令加载lisp
发表于 2020-2-22 22:04:48 | 显示全部楼层 |阅读模式
搬运http://www.theswamp.org/index.php?topic=49944.0
复制代码
  1.     class LaunchAutoCAD
  2.     {
  3.         private static IAcadApplication vAcadApp = null;
  4.         private static IAcadDocument vAcadDoc = null;
  5.         private static string vAcadID = "AutoCAD.Application.20";
  6.         public static void StartAutoCAD()
  7.         {
  8.             try
  9.             {
  10.                 // Check for instance of AutoCAD
  11.                 vAcadApp = (IAcadApplication)System.Runtime.InteropServices.Marshal.GetActiveObject(vAcadID);
  12.             }
  13.             catch (Exception) // None found so start a new instance of AutoCAD
  14.             {
  15.                 Type AcadProg = Type.GetTypeFromProgID(vAcadID);
  16.                 vAcadApp = (IAcadApplication)System.Activator.CreateInstance(AcadProg);
  17.             }
  18.             if (vAcadApp != null)
  19.             {
  20.                 vAcadApp.Visible = true;
  21.                 vAcadDoc = vAcadApp.Documents.Open(myDrawingTemplate.dwg", true);
  22.                 vAcadDoc.SendCommand("(load "" + LispPath + "myLisp.lsp" "The load failed") ");
  23.                 vAcadDoc.SendCommand(LISPVariables.PrepareAcadCmd() + " ");
  24.                 vAcadDoc.SendCommand("(setq svPath "" + (ReadDefaults.vsSaveAutoDwgPath).Replace("\", "/") + "") ");
  25.                 vAcadDoc.SendCommand("(setq *erp 1) ");
  26.                 vAcadDoc.SendCommand("startLisp ");
  27.             }
  28.             else
  29.             {
  30.                 Console.WriteLine("ERROR: The drawing file is missing.");
  31.             }
  32.         }
  33.     }
  34. }
发表于 2022-2-11 08:56:24 | 显示全部楼层
太难了,看不懂
GMT+8, 2025-5-1 07:46 , Processed in 0.148617 second(s), 23 queries , Gzip On.
