查看: 2760|回复: 4
第一个c#练习的程序遍历块获取块内图元的外框
发表于 2020-2-18 09:56:57 | 显示全部楼层 |阅读模式
  1.          [CommandMethod("PickDemo")]
  2.          public void PickDemo()
  3.          {
  4.              Database db = HostApplicationServices.WorkingDatabase;
  5.              Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
  6.              PromptEntityResult per = ed.GetEntity("选择块");
  7.              if (per.Status == PromptStatus.OK)
  8.              {
  9.                  using (Transaction trans = db.TransactionManager.StartTransaction())
  10.                  {
  11.                      ResultBuffer result = new ResultBuffer();
  12.                      BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
  13.                      BlockReference br = (BlockReference)per.ObjectId.GetObject(OpenMode.ForRead);
  14.                      string blkname = br.Name;
  15.                      ed.WriteMessage("\nBlock Name: (" + blkname + ").");
  16.                      ObjectId blockRecordId = bt[blkname];
  17.                      BlockTableRecord blockRecord = (BlockTableRecord)blockRecordId.GetObject(OpenMode.ForRead);
  18.                      Extents3d tmpExtents3D = new Extents3d();
  19.                      foreach (ObjectId entID in blockRecord)
  20.                      {
  21.                          Entity entity = (Entity)trans.GetObject(entID, OpenMode.ForRead);
  22.                          Extents3d tmp = entity.GeometricExtents;
  23.                          tmpExtents3D.AddExtents(tmp);
  24.
  25.
  26.                      }
  27.                      Point3d maxpt = tmpExtents3D.MaxPoint;
  28.                      Point3d minpt = tmpExtents3D.MinPoint;
  29.                      result.Add(new TypedValue((int)LispDataType.Point3d, minpt));
  30.                      result.Add(new TypedValue((int)LispDataType.Point3d, maxpt));
  31.                      trans.Commit();
  32.                     //return result;
  33.                  }
  34.              }
  35.          }
发表于 2020-3-9 08:50:50 | 显示全部楼层
最好能做一个非块的外轮廓线的生成
发表于 2021-3-16 09:02:23 | 显示全部楼层
很不错的做法
发表于 2022-12-5 15:14:33 | 显示全部楼层
感谢大神的分享~
发表于 2023-2-24 11:08:14 | 显示全部楼层
最大边界  要能识别 样条曲线 多线段 直线 圆弧 块 还能设置容差 就完美了!! 估计这个很难做到!
GMT+8, 2025-5-1 07:42 , Processed in 0.167758 second(s), 22 queries , Gzip On.
