- 积分
- 24096
- 明经币
- 个
- 注册时间
- 2016-5-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
C#如何遍历块获取块,内部图元坐标点集的最大包围框
https://forums.autodesk.com/t5/net/bounding-boxes-around-blocks/td-p/3822317
 - [CommandMethod("BBO")]
- public void testBlockBound()
- Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
- Database db = doc.Database;
- Editor ed = doc.Editor;
- //Matrix3d ucs = ed.CurrentUserCoordinateSystem;
- BlockReference clon = null;
- doc.TransactionManager.EnableGraphicsFlush(true);
- try
- PromptEntityOptions peo = new PromptEntityOptions("\nSelect block: ");
- peo.SetRejectMessage("Only a block instance !");
- peo.AddAllowedClass(typeof(BlockReference), false);
- PromptEntityResult per = ed.GetEntity(peo);
- if (per.Status != PromptStatus.OK) return;
- ObjectId id = per.ObjectId;
- using (Transaction tr = db.TransactionManager.StartTransaction())
- Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
- if (ent == null) return;
- BlockReference bref = ent as BlockReference;
- if (bref == null) return;
- clon = bref.Clone() as BlockReference;
- clon.Rotation = 0;
- clon.TransformBy(ed.CurrentUserCoordinateSystem);
- tr.TransactionManager.QueueForGraphicsFlush();
- Extents3d ext = clon.GeometryExtentsBestFit(ed.CurrentUserCoordinateSystem);
- ext.TransformBy(ed.CurrentUserCoordinateSystem);
- Polyline pl = new Polyline(4);
- Point3d p1 = ext.MinPoint.TransformBy(ed.CurrentUserCoordinateSystem);
- Point3d p3 = ext.MaxPoint.TransformBy(ed.CurrentUserCoordinateSystem);
- Point3d p2 = new Point3d(p3.X, p1.Y, p1.Z).TransformBy(ed.CurrentUserCoordinateSystem);
- Point3d p4 = new Point3d(p1.X, p3.Y, p1.Z).TransformBy(ed.CurrentUserCoordinateSystem);
- pl.AddVertexAt(0, new Point2d(p1.X, p1.Y), 0.0, 0.0, 0.0);
- pl.AddVertexAt(1, new Point2d(p2.X, p2.Y), 0.0, 0.0, 0.0);
- pl.AddVertexAt(2, new Point2d(p3.X, p3.Y), 0.0, 0.0, 0.0);
- pl.AddVertexAt(3, new Point2d(p4.X, p4.Y), 0.0, 0.0, 0.0);
- pl.Closed = true;
- pl.ColorIndex = 121;
- pl.TransformBy(ed.CurrentUserCoordinateSystem);
- Matrix3d rot = Matrix3d.Rotation(bref.Rotation, bref.Normal.GetNormal(), bref.Position);
- pl.TransformBy(rot);
- BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
- btr.AppendEntity(pl);
- tr.AddNewlyCreatedDBObject(pl, true);
- doc.TransactionManager.FlushGraphics();
- tr.Commit();
- catch (System.Exception e)
- ed.WriteMessage("\nError: {0}\n{1}", e.Message, e.StackTrace);
- finally
- if (!clon.IsDisposed) clon.Dispose();//optional
