查看: 1575|回复: 7
[自我挑战] 匈牙利算法求最大匹配问题问题
发表于 2020-2-6 19:04:35 | 显示全部楼层 |阅读模式
_$ (setq x 4 y 6 pdlst '((1 2)(1 4)(2 1)(2 5)(3 2)(4 1)(4 3)(4 5)(4 6)));;;X中有4个节点,Y中有6个节点 ,如果X中的1和Y中的2有关联,则将'(1 2)置入pdlst中
(setq n (max x y))
(defun fnlst (nn)
  (setq i nn n_lst nil)
  (while (> i 0)
      (setq i (- i 1))
      (setq n_lst (cons i n_lst))
(setq lst (fnlst (* n n)))                                        ;;;用列表存储关系矩阵,初始化lst
(defun rc_num (pt)
   (+ (* n (- (car pt) 1)) (cadr pt) -1)
)        ;;;将坐标(i  j)转化为lst中的对应序号
(setq zero_lst (mapcar 'rc_num pdlst))
(setq lst (mapcar '(lambda (x) (if (member x zero_lst) 0 1)) lst))
(defun splst (llst)
  (setq lst1 (vl-sort llst '<) n_sum (length llst))
  (mapcar '(lambda (x) (list x (- n_sum (length (vl-remove x llst))))) lst1)
(defun hx_rcmax (rclst_zero)
  (cdr (car (vl-sort
        (append (mapcar '(lambda (x) (list (cadr x) (car x) 0 )) (splst (mapcar 'car rclst_zero)))
             (mapcar '(lambda (x) (list (cadr x) 0 (car x) )) (splst (mapcar 'cadr rclst_zero)))
        '(lambda (ea eb)
                 (> (car ea) (car eb))
(defun hx_num (rclst_zero)
  (cond
       ((= (length rclst_zero) 1) (setq linelst rclst_zero))
       ((and (> (length rclst_zero) 1) (null (vl-remove 0 (mapcar '(lambda (x) (- (cadr x) (cadr (car rclst_zero)))) rclst_zero))))
             (setq linelst (list (list 0 (cadr (car rclst_zero)))))
       ((and (> (length rclst_zero) 1) (null (vl-remove 0 (mapcar '(lambda (x) (- (car x) (car (car rclst_zero)))) rclst_zero))))
             (setq linelst (list (list (car (car rclst_zero)) 0)))
       (t (progn
                 (setq hx (hx_rcmax rclst_zero))
                         (if (> (car hx) (cadr hx))
                             (setq linelst (cons hx (hx_num (vl-remove nil (mapcar '(lambda (x) (if (= (car hx) (car x)) nil x)) rclst_zero)))))
                             (setq linelst (cons hx (hx_num (vl-remove nil (mapcar '(lambda (x) (if (= (cadr hx) (cadr x)) nil x)) rclst_zero)))))
(defun sxlst (hhxlst rrclst0)
   (setq ptlst nil ij (length hhxlst))
   (repeat ij
      (if (> (apply '+ (mapcar '(lambda (x) (* (car x )(cadr x))) hhxlst)) 0)
                     (setq pt (car (vl-remove nil (mapcar '(lambda (x) (if (> (* (car x )(cadr x)) 0) x nil)) hhxlst))))
             (setq ptlst (cons pt ptlst))
             (setq rrclst0 (vl-remove nil (mapcar '(lambda (x) (if (or (= (car x) (car pt)) (= (cadr x) (cadr pt))) nil x)) rrclst0)))
                         (if rrclst0
                           (setq hhxlst (hx_num rrclst0))
                     (if (> (car (car hhxlst)) 0)
                             (setq pt (car (vl-sort (vl-remove nil(mapcar '(lambda (x) (if (= (car x) (car (car hhxlst))) x nil)) rrclst0)) '(lambda (ea eb) (< (cadr ea) (cadr eb))))))
                             (setq pt (car (vl-sort (vl-remove nil(mapcar '(lambda (x) (if (= (cadr x) (cadr (car hhxlst))) x nil)) rrclst0)) '(lambda (ea eb) (< (car ea) (car eb))))))
                         (if rrclst0
   ptlst
(sxlst (hx_num pdlst) pdlst)
((1 2) (1 4) (2 1) (2 5) (3 2) (4 1) (4 3) (4 5) (4 6))
6
FNLST
(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35)
RC_NUM
(1 3 6 10 13 18 20 22 23)
(1 0 1 0 1 1 0 1 1 1 0 1 1 0 1 1 1 1 0 1 0 1 0 0 1 1 1 1 1 1 1 1 1 1 1 1)
SPLST
HX_RCMAX
HX_NUM
SXLST
((2 5) (4 1) (1 4) (3 2))
_$
 楼主| 发表于 2020-2-6 22:32:21 | 显示全部楼层
_$ (setq x 6 y 7 pdlst '((1 1)(1 2)(1 4)(2 2)(2 5)(3 1)(3 4)(3 7)(4 3)(4 4)(4 6)(5 4)(6 4)));;;X中有4个节点,Y中有6个节点 ,如果X中的1和Y中的2有关联,则将'(1 2)置入pdlst中
(setq n (max x y))
(defun fnlst (nn)
  (while (> i 0)
      (setq i (- i 1))
(defun rc_num (pt)
(defun splst (llst)
  (cdr (car (vl-sort
        '(lambda (ea eb)
  (cond
       (t (progn
   (repeat ij
                         (if rrclst0
                         (if rrclst0
   ptlst
((1 1) (1 2) (1 4) (2 2) (2 5) (3 1) (3 4) (3 7) (4 3) (4 4) (4 6) (5 4) (6 4))
7
FNLST
(0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48)
RC_NUM
(0 1 3 8 11 14 17 20 23 24 26 31 38)
(0 0 1 0 1 1 1 1 0 1 1 0 1 1 0 1 1 0 1 1 0 1 1 0 0 1 0 1 1 1 1 0 1 1 1 1 1 1 0 1 1 1 1 1 1 1 1 1 1)
SPLST
HX_RCMAX
HX_NUM
SXLST
(nil (4 3) (3 1) (2 2) (1 4))
_$
 楼主| 发表于 2020-2-6 22:34:25 | 显示全部楼层
找到网上数据测试了下,发现结果不正确。经分析,删除过程中选择了非0基,匹配数就减少了,结果就不正确。
 楼主| 发表于 2020-2-8 14:01:58 | 显示全部楼层
问题转化为已一非负矩阵(含部分0元素),如何找到关键k个0 元素及其通过该k个0元素的k条线覆盖矩阵中的所有的0元素?k是最大匹配数,可以容易求出。
 楼主| 发表于 2020-2-9 15:32:43 | 显示全部楼层
(setq flst '(4 10 7 5 2 7 6 3 3 3 4 4 4 6 6 3))
(defun fnlst (nn)(setq ii nn nn_lst nil)(while (> ii 0)(setq ii (- ii 1))(setq nn_lst (cons ii nn_lst))))
(defun cp (pdlst)(defun f (ppt llst) (cons  (apply '+ (mapcar '(lambda (x) (if (= (car x)(car ppt)) 1 0)) llst))(cons (apply '+ (mapcar '(lambda (x) (if  (= (cadr x)(cadr ppt)) 1 0)) llst)) ppt)))(setq vlst nil)
(while pdlst (setq pt (car (vl-sort (mapcar '(lambda (x) (f x pdlst)) pdlst) '(lambda (ea eb)
(cond ((and (= (min (car ea) (cadr ea)) 1) (= (min (car eb) (cadr eb)) 1))(< (max (car ea) (cadr ea)) (max (car eb) (cadr eb))))((and (= (min (car ea) (cadr ea)) 1) (> (min (car eb) (cadr eb)) 1)) '<)((= (+ (car ea) (cadr ea)) (+ (car eb) (cadr eb)))(< (min (car ea) (cadr ea)) (min (car eb) (cadr eb))))(t (< (+ (car ea) (cadr ea)) (+ (car eb) (cadr eb)))))))))(setq pdlst (vl-remove nil (mapcar '(lambda (y) (if (or (= (car y) (caddr pt)) (= (cadr y)(cadddr pt))) nil y)) pdlst)))(setq vlst (cons pt vlst))))(setq lst flst n (length lst) k (fix (sqrt n)))
(setq n_n_lst (mapcar 'list (fnlst n) lst) i 0 j 1)
(defun rowclo (num)(list  (+ (/ num k) 1) (+ (rem num k) 1)))
(defun ij_to_num (rclst)(+ (* (- (car rclst) 1) k) (cadr rclst) -1))
(while (< i k)(setq min_num (apply 'min (vl-remove nil (mapcar '(lambda (x y) (if (and (>= (car x) (* i k)) (< (car x) (* (+ i 1) k))) y nil))  n_n_lst lst)))) (setq lst (mapcar '(lambda (x y) (if (and (>= (car x) (* i k)) (< (car x) (* (+ i 1) k))) (- y min_num) y))  n_n_lst lst)) (setq i (+ i 1)))
(while (<= j k) (setq min_num (apply 'min (vl-remove nil (mapcar '(lambda (x y) (if (= j (cadr (rowclo (car x)))) y nil))  n_n_lst lst)))) (setq lst (mapcar '(lambda (x y) (if (= j (cadr (rowclo (car x)))) (- y min_num) y))  n_n_lst lst)) (setq j (+ j 1)))
(setq n_n_lst (mapcar 'list (fnlst n) lst) kklst (mapcar '1+ (fnlst k)))
(setq ijlst (apply 'append (mapcar '(lambda (x) (mapcar '(lambda (y) (list x y)) kklst)) kklst)))
(setq zero_lst (vl-remove nil (mapcar '(lambda (x y) (if (= x 0) (rowclo (car y)))) lst n_n_lst)))
(defun funij_num_lst (hhxline_lst) (mapcar '(lambda (x) (cons (apply '+ (mapcar '(lambda (y) (if (= (caddr y) 1) (if (= (car x) (car y)) 1 0) (if (= (cadr x) (cadr y)) 1 0))) hhxline_lst)) x)) ijlst))
(setq hxline_lst (mapcar '(lambda (x) (if (> (car x) (cadr x)) (list (caddr x) (cadddr x) 1 0) (list (caddr x) (cadddr x) 0 1))) (cp zero_lst)))
(while (< (length hxline_lst) k)
    (setq ij_num_lst (funij_num_lst hxline_lst))
        (setq n_n_lst (mapcar 'list (fnlst n) lst))
        (setq min_num (apply 'min (mapcar '(lambda (y) (cadr (nth y n_n_lst))) (mapcar 'ij_to_num (vl-remove nil (mapcar '(lambda (x) (if (= (car x) 0) (cdr x) nil)) ij_num_lst))))))
        (setq lst (mapcar '(lambda (x y)(if (= (car x) 0) (- y min_num) (if (= (car x) 1) y (+ y min_num)))) ij_num_lst lst))
(setq hxline_lst (mapcar '(lambda (x) (if (> (car x) (cadr x)) (list (caddr x) (cadddr x) 1 0)(list (caddr x) (cadddr x) 0 1))) (cp zero_lst))))
(if (and (equal kklst (vl-sort (mapcar 'car hxline_lst) '<)) (equal kklst (vl-sort (mapcar 'cadr hxline_lst) '<)))
    (cons (apply '+ (mapcar '(lambda (y) (nth y flst)) (mapcar '(lambda (x) (ij_to_num (list (car x) (cadr x)))) hxline_lst))) hxline_lst)
    (princ "结果有误!")
 楼主| 发表于 2020-2-9 19:54:24 | 显示全部楼层
总结下算法过程:首先将k*k矩阵(可用列表存储)的每行每列减去改行或该列的最小值,得到每行每列至少有1个0的矩阵,至少有k个0。若刚好是k个0,显然就是结果(0所对应的位置)。若0的个数大于k,那么至少有一行或列有2个及以上的0,而我们要求的结果是非同行非同列的k个0*(得到它们的位置),那如何删选0和0*呢?显然,如果一行或一列只有一个0,那我们毫无疑问将该0定为0*。所以我们将每个0(坐标为i,j)所在的行列进行统计,用(i,j,行上0的个数,列上0的个数)表示,如(2,3,3,4)表示位于C23处的0元素所在的行有3个0,所在的列上有4个0,对所有0元素的统计结果排序。优先选择行或列上0的个数最小值为1的0作为0*,如0(2,1,2,2)和0(4,5,1,5)比较,选择0(4,5,1,5)为0*。若两个0元素行列上上均没有1,且行+列相等,取min(行,列)较小的0为0*,如0(2,1,2,4)和0(4,5,3,3)比较,选择0(2,1,2,4)为0*。若行+列不相等,取和值小的0元素作为0*,如0(2,1,2,6)和0(4,5,3,4)比较,选择0(4,5,3,4)为0*,因为选定一个0*后,就要删除所在的行和列上的所有0,选择和值小的0为0*,意味保留的0就多,匹配大的几率就高。按排序先后顺序,选择1个0*,就删除该行该列,对剩下的0再排序,再选一个0*,直至删除完所有的0。选择0*的同时,对应确定一条划线,该条划线的方向由该0*行或列上数值大的一方决定,用(1,0)表示行,用(0,1)表示列,如选定0(2,1,1,5)为0*,则对应的划线计为(2,1,0,1),目的用最少条划线覆盖所有的0。若行列相等,随便定横向或竖向。显然多少个0*对应多少条划线。若最后的0*个数等于k,也就是有k条划线,也就得到答案了。若小于k,则通过增减增加0元素,书上的方法标记行、标记列、找0、找0*描述太绕了,把人都搞晕了。简单方法,根据每个元素坐标跟那些划线的三种关系,不在线上、仅在一条线上、在两条线的交点上,求出不在线上元素的最小值min,然后对应减min(不在线上的元素),不变(仅在一条线上的元素),加上min(在两条划线的交点上的元素),得到新的0元素分部图,按前面算法开始重新逐步选取0*,反复循环,直至找到k个0*。
 楼主| 发表于 2020-2-9 22:19:47 | 显示全部楼层
对于《匈牙利算法质疑》中的反例(非0元素可取1),检测运行确实会出现死循环情况,因为选定c11为0*(正确的应该选c21),则必然得不到最大分配数,而0(1,1,2,3)和0(2,1,2,3)无法比较,只能尝试选取其中一个为0*,也就是该文所说的不能严格保证结果的正确性(虽然遇到的几率很小)。简言之,不管增加多少限制条件来确定如何选取0*,都迈不过这个坎。
 楼主| 发表于 2020-2-21 23:40:36 | 显示全部楼层
针对特例情况,选取0作为0*的条件稍作修改:1、如果某行或某列只有一个0,则选取该0作为0*;若无此情况执行2:2、若某行或某列中的0即是行最小值也是列最小值,则选择该0作为0*(注意0之间也有大小之分,一行或一列中靠后的0比靠前的0小),若无此情况则执行3:3、一个0所在的行和列上的0个数之和最少的,则选择该0作为0*。不知是否还存在反例?
GMT+8, 2025-5-1 03:12 , Processed in 0.197596 second(s), 23 queries , Gzip On.
