查看: 1360|回复: 4
分享一个点集求凸包的算法
发表于 2020-1-15 16:05:58 | 显示全部楼层 |阅读模式
  1. #include "stdafx.h"
  2. #include "MyTuBao.h"
  3. #include"MathUtil.h"
  4. MyTuBao::MyTuBao()
  5. {
  6. }
  7. MyTuBao::MyTuBao(AcGePoint3dArray arr)
  8. {
  9.   this->ptArr = arr;
  10. }
  11. MyTuBao::~MyTuBao()
  12. {
  13.   ptArr.removeAll();
  14. }
  15. void   MyTuBao::GetTuBao(AcGePoint3dArray &pArray)
  16. {
  17.   int nums = 0;
  18.   optimizePointsArray(ptArr);
  19.   nums = ptArr.length();
  20.   if (nums > 3) {
  21.     selectMinPoint(ptArr);//寻找最小的点
  22.     quickSort(ptArr, 1, nums - 1);//用来根据极角排序点
  23.     pArray.append(ptArr[0]);
  24.     pArray.append(ptArr[1]);
  25.     pArray.append(ptArr[2]);
  26.     int top = pArray.length() - 1;
  27.     for (int i = 3; i < nums; i++)
  28.     {
  29.       while (xmul(ptArr, pArray[top], pArray[top - 1]) >= 0)  //是否左转,是继续判断,不是,就入栈
  30.       {
  31.         pArray.removeLast();
  32.         top = pArray.length() - 1;
  33.       }
  34.       pArray.append(ptArr);
  35.       top = pArray.length() - 1;
  36.     }
  37.   }
  38. }
  39. void MyTuBao::GetRec(AcGePoint3dArray &pArray){
  40.   selectMinPoint(ptArr);//寻找最小的点
  41.   int nums = 0;
  42.   optimizePointsArray(ptArr);
  43.   nums = ptArr.length();
  44.   quickSort(ptArr, 1, nums - 1);//用来根据极角排序点
  45.   pArray = ptArr;
  46. }
  47. void MyTuBao::optimizePointsArray(AcGePoint3dArray &points, double tol /*= 1.0E-7*/) {
  48.
  49.   for (int i = points.length() - 1; i > 0; i--)
  50.   {
  51.     for (int j = 0; j < i; j++)
  52.     {
  53.       if (CMathUtil::IsEqual(points.x, points[j].x, tol) && CMathUtil::IsEqual(points.y, points[j].y, tol))
  54.       {
  55.         points.removeAt(i);
  56.         break;
  57.       }
  58.     }
  59.   }
  60. }
  61. long long  MyTuBao::dist(AcGePoint3d p1, AcGePoint3d p2) //两点距离的平方
  62. {
  63.   return (p1.x - p2.x)*(p1.x - p2.x) + (p1.y - p2.y)*(p1.y - p2.y);
  64. }
  65. bool MyTuBao::cmp1(AcGePoint3d p1, AcGePoint3d p2)   //找到第一个点,返回 true->p1比较小,false->p2比较小
  66. {
  67.   if (p1.y == p2.y)
  68.     return p1.x<p2.x;
  69.   else
  70.     return p1.y<p2.y;
  71. }
  72. bool MyTuBao::cmp2(AcGePoint3d p1, AcGePoint3d p2, AcGePoint3d pointMin)   //极角排序的比较函数
  73. {
  74.   if (xmul(p1, p2, pointMin)>0)
  75.     return true; //证明 p1小 选中p1
  76.   else if (xmul(p1, p2, pointMin) == 0 && dist(p1, pointMin)<dist(p2, pointMin))  //相等的按距离近的
  77.     return true; //证明 p1小 选中p1
  78.   return false;
  79. }
  80. double MyTuBao::xmul(AcGePoint3d p1, AcGePoint3d p2, AcGePoint3d  p0)
  81. {
  82.   return (p1.x - p0.x)*(p2.y - p0.y) - (p2.x - p0.x)*(p1.y - p0.y);
  83. }
  84. void MyTuBao::selectMinPoint(AcGePoint3dArray &s) {
  85.   int nums = s.length();
  86.   int cur = 0;
  87.   AcGePoint3d Min = s[0];
  88.   for (int i = 1; i<nums; i++) {
  89.     if (cmp1(s, Min)) {
  90.       Min = s;
  91.       cur = i;
  92.     }
  93.   }
  94.   s[cur] = s[0];
  95.   s[0] = Min;
  96.   acutPrintf(L"\n寻找后最小点为x=%f,y=%f", s[0].x, s[0].y);
  97. }
  98. void  MyTuBao::quickSort(AcGePoint3dArray &s, int l, int r) {
  99.   if (l< r)
  100.   {
  101.     int i = l, j = r;
  102.     AcGePoint3d x = s[l];
  103.     while (i < j)
  104.     {
  105.       while (i < j && cmp2(x, s[j], s[0])) // 从右向左找第一个小于x的数
  106.         j--;
  107.       if (i < j)
  108.         s[i++] = s[j];
  109.       while (i < j && cmp2(s, x, s[0])) // 从左向右找第一个大于等于x的数
  110.         i++;
  111.       if (i < j)
  112.         s[j--] = s;
  113.     }
  114.     s = x;
  115.     quickSort(s, l, i - 1); // 递归调用
  116.     quickSort(s, i + 1, r);
  117.   }
  118. }
 楼主| 发表于 2020-1-15 16:06:29 | 显示全部楼层
#include "stdafx.h"
MyTuBao::MyTuBao()
        this->ptArr = arr;
MyTuBao::~MyTuBao()
        ptArr.removeAll();
        int nums = 0;
        if (nums > 3) {
                        while (xmul(ptArr[i], pArray[top], pArray[top - 1]) >= 0)  //是否左转,是继续判断,不是,就入栈
                        pArray.append(ptArr[i]);
        int nums = 0;
        pArray = ptArr;
                        if (CMathUtil::IsEqual(points[i].x, points[j].x, tol) && CMathUtil::IsEqual(points[i].y, points[j].y, tol))
                                points.removeAt(i);
                                break;
        if (p1.y == p2.y)
                return p1.x<p2.x;
        else
                return p1.y<p2.y;
        return false;
        int cur = 0;
                if (cmp1(s[i], Min)) {
                        Min = s[i];
                        cur = i;
        s[cur] = s[0];
        s[0] = Min;
        if (l< r)
                int i = l, j = r;
                while (i < j)
                                j--;
                        if (i < j)
                                s[i++] = s[j];
                        while (i < j && cmp2(s[i], x, s[0])) // 从左向右找第一个大于等于x的数
                                i++;
                        if (i < j)
                                s[j--] = s[i];
                s[i] = x;
发表于 2020-1-15 16:11:34 | 显示全部楼层
MyTuBao 哈哈
论坛搞arx开发的太少了
业余的也就搞搞lisp
这么狠  发表于 2024-12-24 18:17
satan421你就是个彻头彻尾的杂碎。一毛不拨,对别人指手画脚。垃圾。  发表于 2020-5-30 22:05
GMT+8, 2025-5-1 10:49 , Processed in 0.153281 second(s), 24 queries , Gzip On.
