查看: 1233|回复: 1
LISP 是否可以编辑TXT文本?读入修改后重新输出 如题
发表于 2019-12-3 19:56:24 | 显示全部楼层 |阅读模式
3明经币
(12ASD)
M 1 2 5 N 0 6 8
X125. Y125.
M0S
BS1
--------假设以上是1.txt 是否可用LISP读入后在每行首增加一个排序?
每行首都有一个空格
文件始和末有一个%号
输出后结果如下
(12ASD)
N1 M 1 2 5 N 0 6 8
N2 X125. Y125.
N3 M0S
N4 BS1
N5 .
N6 .
N7 .
最佳答案
发表于 2019-12-3 19:56:25 | 显示全部楼层
    1. (defun jj(/ ff aa lst i)
    2.   (setq ff(open "d:/1.txt" "r") lst '())
    3.   (while
    4.     (setq aa (read-line ff))
    5.     (setq lst (cons aa lst))
    6.   )
    7.   (close ff)
    8.   (setq
    9.     m 1
    10.     i 0
    11.     lst (reverse lst)
    12.   )
    13.   (repeat (length lst)
    14.     (if (and (/= (nth i lst) "%") (/= (nth i lst) "% ")(/= (nth i lst) "(12ASD)"))
    15.       (progn
    16.         (setq
    17.           a1 (strcat "N" (itoa m) " "(nth i lst))
    18.           lst (subst a1(nth i lst)lst)
    19.           m (1+ m)
    20.         )
    21.       )
    22.     )
    23.     (setq i (1+ i))
    24.   )
    25.   (setq i 0)
    26.   (setq fff(open "d:/1.txt" "w"))
    27.   (repeat (length lst)
    28.     (write-line (nth i lst)  fff)
    29.     (setq i (1+ i))
    30.   )
    31.   (close fff)
    32.   (princ)
    33. )
GMT+8, 2025-5-1 07:53 , Processed in 0.153732 second(s), 21 queries , Gzip On.
