查看: 1082|回复: 1
选择线附近文字
发表于 2019-12-3 12:54:53 | 显示全部楼层 |阅读模式
1明经币
目前有一串代码,选择线附近文字,有几个缺点,麻烦论坛改善,谢谢!缺点:1.只能选择多段线附近文字;2.文字与线的距离不可调速;3.只能选择一条线附近的文字,不能选择多条线;4.只能选择视图内的文字,超出视图的文字不能选择。
(defun c:xw()
    (setq cmd (getvar "cmdecho"))
    (setvar  "cmdecho" 0)
    (if (progn
               (princ "\n请选取多段线:")
               (setq ssa (ssget ":S" '((0 . "lwpolyline,pline"))))
            (setq ent (ssname ssa 0))
            (setq dxf (entget ent))
            (setq pts (mapcar 'cdr (vl-remove-if '(lambda(x)(/= (car x) 10)) dxf)))
            (setq ptmin (mapcar '+ (apply 'mapcar (cons 'min pts)) '(-1 -1)))
            (setq ptmax (mapcar '+ (apply 'mapcar (cons 'max pts)) '( 1  1)))
            (if (setq ssb (ssget "w" ptmin ptmax '((1 . "架*[0-9],卡*[0-9],吊*[0-9],挂*[0-9],埋*[0-9],留*[0-9],测*[0-9],钢*[0-9],钉*[0-9],引*[0-9]"))))
                    (setq i 0)
                    (setq n (sslength ssb))
                    (setq jgb nil)
                    (repeat n
                        (setq entt (ssname ssb i))
                        (setq dxft (entget entt))
                        (setq pt (cdr (assoc 10 dxft)))
                        (setq str (cdr (assoc 1 dxft)))
                        (setq ptt (vlax-curve-getclosestpointto ent pt))
                        (setq jgb (cons (list ptt str) jgb))
                        (setq i (1+ i))
                    (setq jgb (vl-sort jgb '(lambda(a b)
                                               (< (vlax-curve-getdistatpoint ent (car a))
                                                  (vlax-curve-getdistatpoint ent (car b))
                   (foreach pt jgb
                       (princ (strcat "\n" (cadr pt)))
     (sssetfirst nil  ssb)
发表于 2020-5-8 22:03:18 | 显示全部楼层
看你用的东西   咱俩应该是同行   可惜我是小白 帮不了你   遇到同行不容易  帮忙顶一下
GMT+8, 2025-5-1 10:49 , Processed in 0.142381 second(s), 20 queries , Gzip On.
