[【PyCAD】] Pycad来袭,你还在等什么
发表于 2020-4-26 16:38:45 | 显示全部楼层
有人遇到过pycad不是存在d:\pycad这个目录下就会出错的问题么?
发表于 2020-5-16 09:27:42 | 显示全部楼层
第一部就卡壳了。加载了dll运行命令没反应
发表于 2020-7-2 20:34:19 | 显示全部楼层
我也是,cad2019,vscode,python3.7,cad里输入pyedit或者pye没效果,未知命令
发表于 2020-7-12 18:21:43 | 显示全部楼层
坐等python 3.x 版本,
发表于 2020-7-18 11:01:52 | 显示全部楼层
牛B,膜拜,待我python学会了,再来
发表于 2020-8-6 11:46:59 | 显示全部楼层
keep moving希望越来越完善
发表于 2020-8-6 17:37:47 | 显示全部楼层
很好的样子,非常的感谢
发表于 2020-8-22 16:44:03 | 显示全部楼层
加载不进来啊。我是CAD2020/2018都试过了。
Command: NETLOAD
Cannot load assembly. Error details: System.IO.FileLoadException: Could not load file or assembly 'file:///D:\Pycad\NFox.Pycad.Acad.dll' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
File name: 'file:///D:\Pycad\NFox.Pycad.Acad.dll' ---> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
   at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
   at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark)
   at System.Reflection.Assembly.LoadFrom(String assemblyFile)
   at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
   at loadmgd()
发表于 2020-8-22 21:00:42 | 显示全部楼层
这就厉害了,顶起来
发表于 2020-8-25 11:21:04 | 显示全部楼层
有谁安装成功了吗?分享一下安装步骤
GMT+8, 2025-12-3 12:44 , Processed in 0.211110 second(s), 17 queries , Gzip On.
