楼主: 树櫴希德
2多段线延伸相交捡懒
 楼主| 发表于 2022-10-20 11:49:07 | 显示全部楼层
yanshengjiang 发表于 2021-11-27 02:25
请问这个和cad的倒角是不是一样的
你是对的 没有用过 chamfer 倒角命令 惭愧啊 啊 啊s
 楼主| 发表于 2022-12-15 16:42:40 | 显示全部楼层
重复多段线 重复表判别 73哥函数
  1. (defun plinexy(e / p a b n ob q et d d1 en et)
  2.     (setq a(entget e)ob(vlax-ename->vla-object e)et(cdr(assoc 0 a))n 0 p nil d nil)
  3.     (cond((="LWPOLYLINE"et)
  4.     (repeat(length a)(setq b (nth n a) n (+ n 1))
  5.       (if (= 10 (car b))(progn
  6.         (setq q(list (cadr b) (caddr b))d1(vlax-curve-getDistAtPoint ob q))
  7.         (if p (if (not(member d1 d)) (setq p (append p (list q))d (append d (list d1))))
  8.           (setq p (list q)))))))
  9.    ((="POLYLINE"et)
  10.     (SETQ EN (ENTGET (SETQ E (ENTNEXT E))))
  11.     (WHILE (/= (CDR (ASSOC 0 EN)) "SEQEND")
  12.       (SETQ q (CDR (ASSOC 10 EN))d1(vlax-curve-getDistAtPoint ob q)q(reverse(cdr(reverse q))))
  13.       (if p(if (not(member d1 d)) (setq p (append p (list q))d (append d (list d1))))(setq p(list q)))
  14.       (SETQ EN (ENTGET (SETQ E (ENTNEXT E)))))
  15.     (setq p(reverse p))))P)
  16. (defun lst-(l1 l2 fuz / a l)
  17.   (while l1
  18.       (setq a(car l1)l1(cdr l1))
  19.       (or(vl-some(function(lambda(x)(equal a x fuz)))l2)
  20.    (setq l(cons a l))))
  21.       (reverse l))
  22. (defun lst-1 (l1 l2 fuz / l)
  23.   (if l2
  24.     (progn
  25.       (vl-every(function(lambda(a)
  26.         (or(vl-some(function(lambda(x)(equal a x fuz)))l2)
  27.            (setq l(cons a l)))))l1)
  28.       (reverse l))
  29.     l1))
  30.
  31. (setq p1(lst-  (plinexy (car(entsel "\n请选择一条线:"))) (plinexy (car(entsel "\n请选择另一条线:"))) 0.0001 ))
发表于 2023-5-13 09:17:29 | 显示全部楼层
多谢楼主分享
GMT+8, 2025-5-1 14:39 , Processed in 0.142062 second(s), 18 queries , Gzip On.
