查看: 1021|回复: 2
希望大神帮改个画单线管
发表于 2019-11-18 10:28:37 | 显示全部楼层 |阅读模式
1明经币
在明经论坛经常有些连续画弯头的程序效果是图a,希望大神能帮添加两个功能(1)可以自定义多段线的宽度(2)在弯头处加两条短线短线(长度为线宽的5倍,如图b所示。
附件: 您需要 登录 才可以下载或查看,没有账号?注册
 楼主| 发表于 2019-11-18 10:34:04 | 显示全部楼层
论坛有个画连续弯头的程序:http://bbs.mjtd.com/thread-93655-3-1.html
 楼主| 发表于 2019-11-18 10:49:38 | 显示全部楼层
这个程序也能实现图a的效果
(defun err (s)
   (if (and (/= s "console break")
      (/= s "Function cancelled")
      (/= s "quit/exit abort")
    (setvar "osmode" oldos)
    (setvar "autosnap" oldosn)
    (setvar "orthomode" oldor)
    (setq *error* olderr)
    (command "_.undo" "e")
     (setvar "cmdecho" oldcmd)
    (princ (strcat "\n程序出错或用户退出:" s))
;;;备份系统变量
(defun bak ()
   (setq        oldcmd        (getvar "cmdecho"))
   (setvar "cmdecho" 0)
   (command "_.undo" "be")
   (setq        oldos        (getvar "osmode")
   oldosn (getvar "autosnap")
   oldor (getvar "orthomode")
   olderr        *error*
   *error*        err
;;恢复系统变量
(defun rebak ()
;求交点集函数-nth
;;经过测试,nth函数仅比assoc函数快一点点。
;;故此函数也可取消i,j变量,直接使用assoc函数
(defun ssinter (el / el1 obj1 obj2 ipts pts list1 outlst i j)
   (setq outlst (mapcar 'list el)
  i      -1   ;obj1位置指针
  n      0   ;交点数计数器
   (while el
  (setq obj1 (car el)
    list1 (nth (setq i (1+ i)) outlst) ;obj1已有的交点列表
    el (cdr el)
    el1 el
    j i   ;obj2位置指针
  (while el1
    (setq obj2 (car el1)
   el1  (cdr el1)
   j  (1+ j)
    ;;取交点
    (if (and (setq ipts (vla-intersectwith obj1 obj2 0))
   (setq ipts (vlax-variant-value ipts))
   (> (vlax-safearray-get-u-bound ipts 1) 0)
    (setq ipts (vlax-safearray->list ipts)
   pts  '()  ;obj1,obj2交点临时列表变量
    (while (> (length ipts) 0)
   (setq pts  (cons (list (car ipts)
     (cadr ipts)
     (caddr ipts)
   pts
  ipts (cdddr ipts)
    (setq list1 (append list1 pts) ;存obj1交点表,循环结束后再更新
   n     (+ n (length pts)) ;交点计数累加
    ;;obj2的交点列表立即更新
    (setq
   outlst (subst (append (nth j outlst) pts)
   (nth j outlst)
   outlst
;|   ;;当obj1存在交点,且非封闭曲线,添加两端点
  (if (and (cdr list1) (not (vlax-curve-isClosed obj1)))
   (list (vlax-curve-getEndPoint obj1))
   (list (vlax-curve-getStartPoint obj1))
  (setq outlst (subst list1 (nth i outlst) outlst)) ;更新obj1交点列表 |;
   outlst
;;点集排序及删除重复点函数
(defun InterSort (el / obj1 pts plst outlst)
   (setq outlst '())   ;empty list
   (foreach item el
  (setq obj1 (car item)
    pts  (cdr item)
    plst '()   ;empty list
  (if pts    ;若无交点,则不修改该实体
  ;;交点排序,列表为逆序
  (setq
    pts (vl-sort
   pts
   (function (lambda (p1 p2)
     (< (vlax-curve-getParamAtPoint obj1 p1)
     (vlax-curve-getParamAtPoint obj1 p2)
  ;;剔除重复点并将列表顺序转正
  (foreach p pts
    (if plst
   (if (not (equal p (car plst) 0.00001))
     (setq plst (cons p plst))
  ;;闭合曲线需再添加首个交点以使新实体完全封闭
  (if (vlax-curve-isClosed obj1)
    (setq plst (cons (last plst) plst))
  (setq plst   (cons (vlax-vla-object->ename obj1) plst)
     outlst (cons plst outlst)
   outlst
;;计算耗时
(defun xdl-getutime ()
   (* 86400 (getvar "tdusrtimer"))
;; 清理当前选择集
(defun Clearcset (/ cset)
  (if (not (vl-catch-all-error-p
  (setq cset (vl-catch-all-apply 'vla-item (list(vlax-get-property (vlax-get-property (vlax-get-acad-object) 'activedocument ) 'selectionsets)"CURRENT")))
  (vla-delete cset)
(defun c:xlx( / elist ssg n t0)
   (VL-LOAD-COM)
   (setq pt_list1 '())
   (setq r (getreal (strcat "请输入倒角半径<" (rtos (getvar "filletrad"))
   (if (null r)
    (setq r (getvar "filletrad"))
    (setvar "filletrad" r)
  ;(setq ss (ssget '((0 . "line"))))
  (bak)
  (clearcset)
  (if (setq ssg (ssget '((0 . "line"))))
    (vlax-for obj (vla-get-activeselectionset
      (vla-get-activedocument (vlax-get-acad-object))
      (setq elist (cons obj elist)) ; ssg->elist
(vlax-release-object obj)
  (setq t0 (xdl-getutime))
  (setq pt_list(InterSort (ssinter elist)))
  (foreach pt pt_list
  (setq pt_list1 (append (cdr pt)pt_list1))
  (foreach pt pt_list1
  ;(setq pt (cadr pt))
      (setq ss2 (ssget "c" pt pt))
        (setq en1 (ssname ss2 0))
    (setq en2 (ssname ss2 1))
        (if (and en1 en2)(command "fillet" en1 en2))
(rebak)
(princ (strcat "\n*****找到交点"
   (itoa n)
   "个,交点倒角操作操作共耗时"
   (rtos (- (xdl-getutime) t0) 2 3)
   "秒。*****"
  (prompt "<<xlx>>相连线批量倒角")
GMT+8, 2025-5-24 05:50 , Processed in 0.162316 second(s), 20 queries , Gzip On.
