- 积分
- 14356
- 明经币
- 个
- 注册时间
- 2019-3-22
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
;;交流学习用,,,,,当然,主要是混经验[em77][em77][em77],为了获取更高的权限;;已根据edata前辈的建议改进
;;之前给选集添加了选择过滤参数,现在把它注解掉了,可以支持对块操作了,只是尽可能的方便不懂lsp的人员
;;快速拉线标注--带捕捉;;;
;;修改自 雨的节奏 http://bbs.mjtd.com/thread-180247-1-1.html
;;; grread捕捉子函数
;;; name为移动的图元名,pt为光标点
;;; 返回值:如果有捕捉点则返回捕捉点,无则返回光标点
;;;http://bbs.mjtd.com/forum.php?mo ... hlight=%B2%B6%D7%BD
;;默认关闭动态捕捉,按F3切换动态捕捉开关;;里面都有注解,,主要展示动态捕捉的用法,可根据自己的需求修改完善
;;快速拉线标注--带捕捉;;;;;修改自 雨的节奏 http://bbs.mjtd.com/thread-180247-1-1.html
;;交流学习用,,,,,当然,主要是混经验了
;;F3临时切换捕捉,,懂lsp的可以直接修改下完善下
(defun C:TT (/ minsize pt1 pt2 ss intlist
x y lds olden pts1 pts2 n ens
code i ptx endata
(defun *error* (msg)
(setvar "osmode" osm);;还原捕捉点设置
(princ "\n程序终止")
(if (< (atof (getvar "acadver")) 20.0)
(command "undo" "end")
(command-s "undo" "end")
(princ "\nF3 临时切换捕捉开关,默认关闭");;设置F3键,可能是习惯吧
(princ "\n过滤尺寸下限:不生成小于此数值的尺寸标注的")
(setq osm (getvar "osmode"));;存储捕捉点设置
(if ddf_old_minsize
(setq minsize ddf_old_minsize)
(command "undo" "be")
(if
(progn (initget "S")
(setq pt1 (getpoint "\n指定标注起始方向/设置过滤尺寸(S)"))
(while (= "S" pt1)
(if (null ddf_old_minsize)
(setq minsize (getdist "\n请输入过滤尺寸,默认为<5mm>"))
(setq minsize (getdist (strcat "\n请输入过滤尺寸,上次输入为<"
(rtos ddf_old_minsize 2 2)
"mm>"
(if (null minsize)
(setq minsize 5)
(setq ddf_old_minsize minsize)
(initget "S")
) ;end while
(if (null minsize)
(setq minsize 5)
(setq pt2 (getpoint pt1 "\n指定标注方向"))
(if (and pt1 pt2)
(setq pt1(polar pt1 (angle pt2 pt1) minsize))
(setq pt2(polar pt2 (angle pt1 pt2) minsize))
(if (setq ss (ssget "F"
(list pt1 pt2)
;;'((0 . "*E,CIRCLE,ARC") (6 . "BYLAYER"))
(setq intlist ()
endata (ssnamex ss)
(foreach x endata
(foreach y (cdddr x) (setq intlist (cons (cadr y) intlist)))
;;点要排序一下才行,按从开始点的距离来排序
(setq lds (+ 10 (distance pt1 pt2)))
(setq intlist (vl-remove-if-not
'(lambda (x) (<= (distance x pt1) lds))
intlist
(setq
intlist (vl-sort intlist
'(lambda (x y)
(< (distance pt1 x) (distance pt1 y))
;;这里开始写标注程序
(setq olden (entlast)
ss (ssadd)
(setq n 0)
(repeat (- (length intlist) 1)
(setq pts1 (nth n intlist)
pts2 (nth (1+ n) intlist)
(if (> (distance pts1 pts2) minsize)
(ddf_entmakedim pts1 pts2)
(setq n (1+ n))
) ;end repeat
(while (setq ens (entnext olden))
(setq ss (ssadd ens ss)
olden ens
(if(>(getvar"OSMODE")16384)(princ)(setvar"OSMODE"(+(getvar"OSMODE")16384)));;默认关闭捕捉
;(if(>(getvar"OSMODE")16384)(setvar"OSMODE"(-(getvar"OSMODE")16384))(princ));默认打开捕捉
;;下面开始来移动
(setq loop t);;;带捕捉的grread框架开始
(while loop
(setq gr (grread t 15 0) code (car gr) ptx (cadr gr))
(cond
((= code 3)(redraw) (setq loop nil)) ; 鼠标左键
((= code 5) ; 鼠标移动
(redraw)
(if (>(getvar"OSMODE")16384)
(setq ptx (osnappt nil ptx))
;;根据获取的动态点坐标更新程序-开始
(setq i 0)
(repeat (sslength ss)
(setq endata (entget (ssname ss i)))
(entmod (subst (cons 10 ptx) (assoc 10 endata) endata))
(setq i (1+ i))
); end repeat
;;根据获取的动态点坐标更新程序-结束
((member code '(2 6)) ; 键盘输入--"F3"键
(if(>(getvar"OSMODE")16384)(setvar"OSMODE"(-(getvar"OSMODE")16384))(setvar"OSMODE"(+(getvar"OSMODE")16384))));切换捕捉开关
;((= code 2) ; 键盘输入
; (princ "\n键盘输入=")(princ pt))
((member code '(11 25)); 鼠标右击
);end while;;;;;带捕捉的grread框架结束
) ;end if
);end progn
) ;end if
(princ "\n标注完成")
(command "undo" "END")
(prin1)
) ;end
(defun ddf_entmakedim (pt1 pt2 /)
(cond
((or (equal 0 (angle pt1 pt2) 0.001)
(equal pi (angle pt1 pt2) 0.001)
(entmake
(list
'(0 . "DIMENSION")
'(100 . "AcDbEntity")
'(100 . "AcDbDimension")
(cons 10 pt1)
'(70 . 32)
'(1 . "")
'(100 . "AcDbAlignedDimension")
(cons 13 pt1)
(cons 14 pt2)
'(100 . "AcDbRotatedDimension")
((or (equal (/ pi 2) (angle pt1 pt2) 0.001)
(equal (* pi 1.5) (angle pt1 pt2) 0.001)
(entmake
(list
'(0 . "DIMENSION")
(cons 10 pt1)
'(70 . 33)
'(1 . "")
(cons 13 pt1)
(cons 14 pt2)
((and (null (equal 0 (angle pt1 pt2) 0.001))
(null (equal (/ pi 2) (angle pt1 pt2) 0.001))
(entmake
(list
'(0 . "DIMENSION")
(cons 10 pt1)
'(70 . 33)
'(1 . "")
(cons 13 pt1)
(cons 14 pt2)
) ;end cond
) ;end
(prin1)
;;; grread捕捉子函数
(defun osnappt (name pt / color d h k lst nearpt nearpt2 osmo pt1 pt2 pt3 pt4 pt5 ptx pty x)
(if name (entdel name))
(redraw)
(if (< (getvar "osmode") 16384);;打开捕捉
(setq color (vla-get-autosnapmarkercolor (vla-get-drafting (vla-get-preferences (vlax-get-acad-object))))
h (/ (getvar "viewsize") (cadr (getvar "screensize"))) d (getvar "pickbox")
lst (list (* d h) (* (- d 0.5) h) (* (+ d 0.5) h)) k (* 1.5 d h))
(if (setq nearpt (osnap pt "_END,_CEN,_NOD,_QUA,_INS,_TAN,_EXT"))(setq osmo 1))
(if (and(setq nearpt2 (osnap pt "_NEA"))(not (equal nearpt nearpt2 k)))
(setq osmo 2 nearpt nearpt2))
(if (and(setq nearpt2 (osnap pt "_MID"))(equal nearpt nearpt2 k))
(setq osmo 3 nearpt nearpt2))
(if (and(setq nearpt2 (osnap pt "_INT"))(equal nearpt nearpt2 k))
(setq osmo 4 nearpt nearpt2))))
(if name(entdel name))
(if nearpt
(setq ptx (car nearpt)pty (cadr nearpt))
(foreach x lst
(setq pt1 (list (- ptx x) (- pty x)) pt2 (list (+ ptx x) (- pty x))
pt3 (list (+ ptx x) (+ pty x)) pt4 (list (- ptx x) (+ pty x))
pt5 (list ptx (+ pty x)))
(cond
((= osmo 1)(grvecs (list color pt1 pt2 pt2 pt3 pt3 pt4 pt4 pt1)))
((= osmo 2)(grvecs (list color pt1 pt2 pt2 pt4 pt3 pt4 pt3 pt1)))
((= osmo 3) (grvecs (list color pt1 pt2 pt2 pt5 pt5 pt1)))
((= osmo 4) (grvecs (list color pt1 pt3 color pt2 pt4)))))
(setq pt nearpt)))
pt
