查看: 1385|回复: 0
[基础] .net 定义lisp字符串函数
发表于 2019-10-27 20:52:57 | 显示全部楼层 |阅读模式
初学.net,写了几个lisp字符串函数,解决lisp字符串处理功能较弱,请指点
using System;
using System.Text.RegularExpressions;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace commom_lib
    /// <summary>
    /// 辅助操作类
    /// </summary>
    public static partial class Tools
        private static object results;
        /// <summary>
        /// 字符串替换,参数:被替换字符 旧字符 新字符
        /// </summary>
        /// <param name="rb"></param>
        /// <returns></returns>
        [LispFunction("zgx:str:replace")]
        public static string Lsp_stringreplace(ResultBuffer rb)
            string iRtn = null;
            if (rb != null)
                TypedValue[] tb = rb.AsArray();
                if (tb.Length == 3 && tb[0].TypeCode == (int)LispDataType.Text && tb[1].TypeCode == (int)LispDataType.Text && tb[2].TypeCode == (int)LispDataType.Text)
                    string toreplace = tb[0].Value as string;
                    string oldstr = tb[1].Value as string;
                    string newstr = tb[2].Value as string;
                    iRtn = toreplace.Replace(oldstr, newstr);
            return iRtn;
        /// <summary>
        /// 字符分割,同split,参数string seperator;
        /// (zgx:str:Split input seperator)
        /// </summary>
        [LispFunction("zgx:str:Split")]
        public static ResultBuffer Lsp_stringSplit(ResultBuffer rb)
            ResultBuffer reb = new ResultBuffer();
            try
                if (rb != null)
                    //ResultBuffer reb = new ResultBuffer();
                    if (tb.Length == 2 && tb[0].TypeCode == (int)LispDataType.Text && tb[1].TypeCode == (int)LispDataType.Text)
                        string toReplace = tb[0].Value as string;
                        string sep = tb[1].Value as string;
                        string[] strArr = Regex.Split(toReplace, sep);
                        for (int i = 0; i < strArr.Length; i++)
                            if (strArr[i] != "")
                                reb.Add(new TypedValue((int)LispDataType.Text, strArr[i]));
                    else
                        reb = null;
                else
                    reb = null;
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
            //如何判断reb为空?
            return reb;
        /// <summary>
        /// 正则表达式,与晓东函数顺序一致;
        /// (zgx:regExps patten input [regoptions默认 1+2])
        /// </summary>
        [LispFunction("zgx:regExps")]
        public static ResultBuffer Lsp_regexps(ResultBuffer rb)
            ResultBuffer Rsb = new ResultBuffer();
            int RegOpts = 3;
            try
                if (rb != null)
                    if (tb.Length >= 2 & tb.Length <= 3 && tb[0].TypeCode == (int)LispDataType.Text && tb[1].TypeCode == (int)LispDataType.Text)
                        string pattern = tb[0].Value as string;
                        string s = tb[1].Value as string;
                        if (tb.Length == 3
                            && tb[2].TypeCode == (int)LispDataType.Int32
                            | tb[2].TypeCode == (int)LispDataType.Int16
                            RegOpts = Convert.ToInt32(tb[2].Value);
                        MatchCollection results = Regex.Matches(s, pattern, (RegexOptions)RegOpts);
                        if (results.Count > 0)
                            for (int i = 0; i < results.Count; i++)
                                if (results[i].Value != "")
                                    Rsb.Add(new TypedValue((int)LispDataType.Text, results[i].Value));
                        else
                            Rsb = null;
                    else
                        Rsb = null;
                else
                    Rsb = null;
            //如何判断reb为空?
            return Rsb;
        /// <summary>
        /// (zgx:regExpr pat input new [替换选项 替换次数T,仅替换一次])
        /// 0       None
        ///1       IgnoreCase
        ///2       Multiline
        ///4       ExplicitCapture
        ///8       Compiled
        ///16      Singleline
        ///32      IgnorePatternWhitespace
        ///64      RightToLeft
        ///256     ECMAScript
        ///512     CultureInvariant
        /// </summary>
        [LispFunction("zgx:regExpr")]
        public static string Lsp_regexpr(ResultBuffer rb)
            string Rtnstr = null;
            int RegOpts = 3;
            try
                if (rb != null)
                    if (tb.Length >= 3 & tb.Length <= 5
                        string sInput = tb[1].Value as string;
                        string sNew = tb[2].Value as string;
                        int iCount = sInput.Length;
                        if (tb.Length >= 4 & tb.Length <= 5
                            && tb[3].TypeCode == (int)LispDataType.Int32
                            | tb[3].TypeCode == (int)LispDataType.Int16
                            RegOpts = Convert.ToInt32(tb[3].Value);
                        if (tb.Length == 5
                            && tb[4].Value != null
                            iCount = 1;
                        Regex reg = new Regex(pattern, (RegexOptions)RegOpts);
                        Rtnstr = reg.Replace(sInput, sNew, iCount);
            return Rtnstr;
        //string input = "aaaaaaaaaaa";
        //string pat = "a";
        //string newstring = "v";
        //Regex re = new Regex(pat);
        //string rtn = re.Replace(input, newstring, input.Length, 1);
        /// <summary>
        /// substr同lispsubstr,参数:字符串 起始位置(从1开始) 截取长度
        /// </summary>
        [LispFunction("zgx:str:Substring")]
        public static string Lsp_stringSubstring(ResultBuffer rb)
            string iRtn = null;
            if (rb == null) return null;
            try
                    tb[1].TypeCode == (int)LispDataType.Int32 |
                    tb[1].TypeCode == (int)LispDataType.Int16 |
                    tb[1].TypeCode == (int)LispDataType.Double &&
                    tb[2].TypeCode == (int)LispDataType.Double |
                    tb[2].TypeCode == (int)LispDataType.Int32 |
                    tb[2].TypeCode == (int)LispDataType.Int16)
                    int strLen = toReplace.Length;
                    int start = Convert.ToInt32(tb[1].Value) - 1;
                    int Length = Convert.ToInt32(tb[2].Value);
                    if (start < 1)
                        start = 1;
                    if (start + Length > strLen)
                        Length = strLen - start;
                    iRtn = toReplace.Substring(start, Length);
            return iRtn;
        /// <summary>
        /// 返回字符串长度,汉字按一个字符计算;
        /// 输入:字符串
        /// </summary>
        [LispFunction("zgx:str:length")]
        public static object Lsp_strlength(ResultBuffer rb)
            object iRtn = null;
            try
                if (tb.Length == 1 && tb[0].TypeCode == (int)LispDataType.Text)
                    iRtn = toreplace.Length;
            return iRtn;
GMT+8, 2025-5-1 14:44 , Processed in 0.181050 second(s), 23 queries , Gzip On.
