查看: 949|回复: 0
vb.net 启动cad2010
发表于 2019-10-16 10:03:54 | 显示全部楼层 |阅读模式
代码如下Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Class Form1
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim AcadApp As AcadApplication
On Error Resume Next
AcadApp = GetObject(, "AutoCAD.Application")
If Err.Number Then
Err.Clear()
AcadApp = CreateObject("AutoCAD.Application.18")
If Err.Number Then
MsgBox("系统未安装AutoCAD。", vbInformation, Me.Text)
Exit Sub
End If
End If
AcadApp.Visible = True
End Sub
End Class
问题现象为“窗口界面没有打开cad,但进程有”
GMT+8, 2025-5-1 14:35 , Processed in 0.178380 second(s), 23 queries , Gzip On.
