查看: 3221|回复: 14
【原创】块改名 直接改嵌套块的名字
发表于 2019-9-16 09:47:20 | 显示全部楼层 |阅读模式
基本思想是参照原生的在位编辑命令界面的,左面表达块嵌套关系,右边显示块的简单缩略图(我限制了一下秒点精度和广度,保证不会因为缩略图而卡,卡的话工具就得不偿失了)
卖一个币辛苦费啊,来到以后没有收入过明经币,有时候想看前辈的帖子都打不开。
 楼主| 发表于 2019-9-30 14:16:43 来自手机 | 显示全部楼层
i see, you like the thumbnail preview and want a similiar one without the odcl.
it's easy to make one, but the preview is based on some cpu resource needed code, it's hard to balance the accuration and the speed, Open DCL implemt preview in a programtically better way, if you like and need preview, You probably should choose ODCL plugin.
anyway, i will upload a prototype today, feel free to try, but don't take any expectation
 楼主| 发表于 2019-9-28 19:57:17 | 显示全部楼层
sachindkini 发表于 2019-9-24 19:26
dear ,
please add multiple block rename
I am not sure what you mean, this script meant for neased block reference rename, for batch rename you should find a better tool
发表于 2019-9-30 13:54:25 | 显示全部楼层
The CAD new army was published on 2019-9-28 19:57
I am not sure what you mean, this script meant for neased block reference rename, for batch rename ...
This is odcl version
发表于 2019-9-16 21:26:01 | 显示全部楼层
dear sir
looking nice ....
i prefer coin to praise.  发表于 2019-9-17 20:45
发表于 2019-9-17 15:42:37 | 显示全部楼层
不是源码,还收费
默认命令名
BlockRenamerMXV
应该是
默认命令名
BlockRenamer
发表于 2019-9-17 17:44:18 | 显示全部楼层
望楼主上传源码
发表于 2019-9-17 20:53:13 | 显示全部楼层
dear sir,
better share source code for coin
i doubt it... you are broke..  发表于 2019-9-17 21:14
发表于 2019-9-18 15:15:28 | 显示全部楼层
sachindkini 发表于 2019-9-17 20:53
dear sir,
发表于 2019-9-18 15:20:54 | 显示全部楼层
Dear
please share English version
发表于 2019-9-24 19:26:28 | 显示全部楼层
dear ,
发表于 2019-9-27 09:44:32 | 显示全部楼层
支持匿名块吗?
GMT+8, 2025-5-1 14:27 , Processed in 0.227908 second(s), 32 queries , Gzip On.
