查看: 1363|回复: 1
[事件] 退出时BeginQuit事件返回的Cancel不起效!
发表于 2019-7-31 22:50:20 | 显示全部楼层 |阅读模式
Imports AutoCAD
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Public Class BHNET
    Dim WithEvents QCADapp As AcadApplication
    Private Sub QCADapp_BeginQuit(ByRef Cancel As Boolean) Handles QCADapp.BeginQuit
        On Error Resume Next
        If MsgBox("AutoCAD即将退出,你确定退出吗?", vbYesNoCancel + vbQuestion, "Auto CAD") <> vbYes Then
            Cancel = True
        End If
    End Sub
    Public Sub New()
    End Sub
    Protected Overrides Sub Finalize()
        MyBase.Finalize()
    End Sub
    <CommandMethod("Show")>
    Public Sub Show()
        QCADapp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
    End Sub
End Class
这个代码怎么在CAD退出的时候,点击了NO不起效呢?如果是在CAD没有活动文档的时候点击NO是不会退出的。如果有文档的时候点击CAD关闭就会不起效!哪位大神用VB.net的。帮我看看
发表于 2019-8-1 19:29:13 | 显示全部楼层
发表的板块不对吧
GMT+8, 2025-5-1 14:26 , Processed in 0.158711 second(s), 24 queries , Gzip On.
