查看: 3654|回复: 10
[基础] 请教高手,在cad图面点击三点,程序自动绘制矩形框程序
发表于 2019-6-12 16:47:13 | 显示全部楼层 |阅读模式
请教高手,在cad图面点击三点,程序自动绘制矩形框,矩形框可以使倾斜的,哪位大师有.net源代码能否贡献一下学习,谢谢!!!
发表于 2020-3-20 23:28:16 | 显示全部楼层
请参考gile的程序片段:http://www.theswamp.org/index.php?topic=46284.msg513392#msg513392
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(RectangleDrawJig.CommandMethods))]
namespace RectangleDrawJig
    public class CommandMethods
        [CommandMethod("Test", CommandFlags.Modal)]
        public void Test()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            PromptPointResult ppr = ed.GetPoint("\nSpecify the first corner: ");
            if (ppr.Status != PromptStatus.OK) return;
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
            Point3d basePt = ppr.Value;
            using (Transaction tr = db.TransactionManager.StartTransaction())
            using(Line line = new Line(basePt, basePt))
            using(Polyline pline = new Polyline(4))
                Point2d basePt2d = new Point2d(basePt.X, basePt.Y);
                pline.AddVertexAt(0, basePt2d, 0.0, 0.0, 0.0);
                pline.AddVertexAt(1, basePt2d, 0.0, 0.0, 0.0);
                pline.AddVertexAt(2, basePt2d, 0.0, 0.0, 0.0);
                pline.AddVertexAt(3, basePt2d, 0.0, 0.0, 0.0);
                pline.Closed = true;
                RectangleJig jig = new RectangleJig(pline, line, ucs);
                PromptResult pr = ed.Drag(jig);
                if (pr.Status == PromptStatus.OK)
                    BlockTableRecord btr =
                        (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    pline.TransformBy(ucs);
                    btr.AppendEntity(pline);
                    tr.AddNewlyCreatedDBObject(pline, true);
                    btr.AppendEntity(line);
                    tr.AddNewlyCreatedDBObject(line, true);
                tr.Commit();
        class RectangleJig : DrawJig
            private Polyline pline;
            private Line line;
            private Matrix3d ucs2wcs, wcs2ucs;
            private Point3d dragPt;
            private Point2d basePt;
            public RectangleJig(Polyline pline, Line line, Matrix3d ucs)
                this.pline = pline;
                this.line = line;
                this.ucs2wcs = ucs;
                this.wcs2ucs = ucs.Inverse();
                this.dragPt = line.EndPoint;
                this.basePt = pline.GetPoint2dAt(0);
            protected override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.WorldDraw draw)
                Autodesk.AutoCAD.GraphicsInterface.WorldGeometry geo = draw.Geometry;
                if (geo != null)
                    geo.PushModelTransform(ucs2wcs);
                    geo.Draw(line);
                    geo.Draw(pline);
                    geo.PopModelTransform();
                return true;
            protected override SamplerStatus Sampler(JigPrompts prompts)
                PromptPointResult ppr = prompts.AcquirePoint("\nSpecify the opposite corner: ");
                if (ppr.Value.IsEqualTo(dragPt))
                    return SamplerStatus.NoChange;
                dragPt = ppr.Value;
                Update();
                return SamplerStatus.OK;
            private void Update()
                Point3d pt = dragPt.TransformBy(wcs2ucs);
                line.EndPoint = pt;
                pline.SetPointAt(1, new Point2d(pt.X, basePt.Y));
                pline.SetPointAt(2, new Point2d(pt.X, pt.Y));
                pline.SetPointAt(3, new Point2d(basePt.X, pt.Y));
发表于 2019-9-5 09:55:56 | 显示全部楼层
关键字,jig,两点距离,向量,坐标转换
发表于 2019-9-5 10:21:51 | 显示全部楼层
三点是任意三点吗?如果这三点是角点,不一定能构成矩形吧,如果不是角点,那能绘制的矩形不唯一
发表于 2019-9-7 16:47:54 | 显示全部楼层
点的先后顺序可以确定向量,下面是solidworks的
 楼主| 发表于 2019-9-14 18:20:48 | 显示全部楼层
@Leo1980,是这个意思
发表于 2020-3-21 09:37:58 | 显示全部楼层
这个问题也有人回答,真狠惊奇。
发表于 2021-2-11 20:32:28 | 显示全部楼层
楼主的代码实现了吗
发表于 2021-7-13 20:52:54 | 显示全部楼层
能发上来,共享一下吗
GMT+8, 2025-5-1 08:08 , Processed in 0.175862 second(s), 26 queries , Gzip On.
