查看: 1290|回复: 2
[命令] 调用cad2015命令的问题
发表于 2019-6-4 08:49:49 | 显示全部楼层 |阅读模式
NET可以直接调用CAD2015的命令,但是在按钮的点击事件里调用cad2015命令却出现错误。
成功调用代码:
  1. [CommandMethod("Test")]
  2.         public static void Test()
  3.         {
  4.             Document doc = Application.DocumentManager.MdiActiveDocument;
  5.             Database db = doc.Database;
  6.             Editor ed = doc.Editor;
  7.             PromptEntityOptions peo = new PromptEntityOptions("\nSelect a curve: ");
  8.             peo.SetRejectMessage("Only a curve.");
  9.             peo.AddAllowedClass(typeof(Curve), false);
  10.             PromptEntityResult per = ed.GetEntity(peo);
  11.             if (per.Status != PromptStatus.OK) return;
  12.             ObjectId curveId = per.ObjectId;
  13.             PromptPointResult ppr = ed.GetPoint("\nBreak point on curve:");
  14.             if (ppr.Status != PromptStatus.OK) return;
  15.             Point3d breakPoint = ppr.Value;
  16.             ed.Command("_.break", curveId, "_first", breakPoint, breakPoint);
  17.
  18.             using (Transaction tr = db.TransactionManager.StartTransaction())
  19.             {
  20.                 ObjectId id = Autodesk.AutoCAD.Internal.Utils.EntLast();
  21.                 Entity ent = (Entity) tr.GetObject(id, OpenMode.ForWrite);
  22.                 ent.Color = Color.FromColorIndex(ColorMethod.ByAci, 1);
  23.                 tr.Commit();
  24.             }
  25.         }
窗口一按钮点击事件,一样的代码
  1. private void button2_Click(object sender, EventArgs e)
  2.         {
  3.             Document doc = Application.DocumentManager.MdiActiveDocument;
  4.             Database db = doc.Database;
  5.             Editor ed = doc.Editor;
  6.             PromptEntityOptions peo = new PromptEntityOptions("\nSelect a curve: ");
  7.             peo.SetRejectMessage("Only a curve.");
  8.             peo.AddAllowedClass(typeof(Curve), false);
  9.             PromptEntityResult per = ed.GetEntity(peo);
  10.             if (per.Status != PromptStatus.OK) return;
  11.             ObjectId curveId = per.ObjectId;
  12.             PromptPointResult ppr = ed.GetPoint("\nBreak point on curve:");
  13.             if (ppr.Status != PromptStatus.OK) return;
  14.             Point3d breakPoint = ppr.Value;
  15.             ed.Command("_.break", curveId, "_first", breakPoint, breakPoint);
  16.             using (Transaction tr = db.TransactionManager.StartTransaction())
  17.             {
  18.                 ObjectId id = Autodesk.AutoCAD.Internal.Utils.EntLast();
  19.                 Entity ent = (Entity)tr.GetObject(id, OpenMode.ForWrite);
  20.                 ent.Color = Color.FromColorIndex(ColorMethod.ByAci, 1);
  21.                 tr.Commit();
  22.             }
  23.         }
结果报错:
************* 异常文本 **************
Autodesk.AutoCAD.Runtime.Exception: eInvalidInput
在 Autodesk.AutoCAD.EditorInput.Editor.Command(Object[] parameter)
发表于 2019-6-4 09:11:52 | 显示全部楼层
在开始事务处理前,将文档锁一下
  1. Using Lock As DocumentLock = Doc.LockDocument
  2.             Using Trans As Transaction = Doc.TransactionManager.StartTransaction
  3.             End Using
  4.         End Using
复制代码
 楼主| 发表于 2019-6-4 09:45:14 | 显示全部楼层
guohq 发表于 2019-6-4 09:11
在开始事务处理前,将文档锁一下
试过锁定文档,还是报同样的错误
GMT+8, 2025-5-2 12:32 , Processed in 0.157909 second(s), 24 queries , Gzip On.
