查看: 5113|回复: 20
求个加前后缀的源码
发表于 2019-5-28 21:01:38 | 显示全部楼层 |阅读模式
10明经币
要求如图,求哪位大神能做一下
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
(defun c:tt4 ();;;; (vl-load-com) (setq @dclfiledame (vl-filename-mktemp nil nil ".dcl")) (setq @dclfiled (open @dclfiledame "w")) (write-line "dzmjjsbdc:dialog {" @dclfiled) (write-line " label = \"文本加前后缀\" ;" @dclfiled) (write-line " :row {" @dclfiled) (write-line " :edit_box {" @dclfiled) (write-line " key = \"textaddstring1\" ;" @dclfiled) ...
发表于 2019-5-28 21:01:39 | 显示全部楼层
(defun c:tt4 ();;;;
  (vl-load-com)
  (write-line "            label = \"前缀\" ;" @dclfiled)
  (write-line "            width = 30  ;" @dclfiled)
  (write-line "        }" @dclfiled)
  (write-line "            key = \"textaddstring2\" ;" @dclfiled)
  (write-line "            label = \"后缀\" ;" @dclfiled)
  (write-line "        ok_cancel;" @dclfiled)
  (write-line "}" @dclfiled)
  (close @dclfiled)
  ;;以下根据情况处理
  (setq @dclid (load_dialog @dclfiledame))
  (new_dialog "dzmjjsbdc" @dclid)
  ;;设置控件默认值
  (if (and (/= textaddstring1_1 "") (/= textaddstring1_1 nil))
    (set_tile "textaddstring1" textaddstring1_1)
  (if (and (/= textaddstring2_1 "") (/= textaddstring2_1 nil))
    (set_tile "textaddstring2" textaddstring2_1)
  (action_tile "accept" "(get_dzmjjsbdc_main)(done_dialog 1)");;;确定
  (setq return# (start_dialog))
  (cond
    ((= return# 1)
                        (prompt "\n 选择文本<退出>")
                        (if (setq ss (ssget (list (cons 0 "TEXT"))))
                                (repeat (setq k (sslength ss))
                                        (setq ent (ssname ss (setq k (1- k))))
                                        (setq obj (vlax-ename->vla-object ent))
                                        (setq str1 (vla-get-textstring obj))
                                        (vla-put-textstring obj (strcat textaddstring1_1 str1 textaddstring2_1))
  (unload_dialog @dclid)
  (vl-file-delete @dclfiledame)
;;;;;获得对话框值
(defun get_dzmjjsbdc_main ()
        (setq textaddstring1_1   (get_tile "textaddstring1"))
        (setq textaddstring2_1   (get_tile "textaddstring2"))
 楼主| 发表于 2019-5-28 21:02:21 | 显示全部楼层
与贱人工具箱的前后缀一样,谁能写个代码,谢谢!!
发表于 2019-5-29 08:52:36 | 显示全部楼层
http://bbs.mjtd.com/forum.php?mo ... hlight=%BA%F3%D7%BA
虽然此链接的发帖者 非常不厚道,但可以向ssyfeng大侠讨要啊,要来之后 ,如ssyfeng允许 还把代码贴在这个帖子中比较好
建议明总对设置【此贴仅作者可见】的功能收费,支持论坛的生存
 楼主| 发表于 2019-5-29 10:20:55 | 显示全部楼层
帮顶出高手吧
发表于 2019-5-29 10:30:39 | 显示全部楼层
;;entget+assoc得到组码1中的文字内容,多行文字可能需要注意下格式
;;strcat增加前后缀
;;subst替换
;;entmod更新资料
;;还有啥???
 楼主| 发表于 2019-5-29 19:25:42 | 显示全部楼层
请高手,出手!!
 楼主| 发表于 2019-5-30 09:15:02 | 显示全部楼层
继续等!,继续等 !!
 楼主| 发表于 2019-5-31 12:22:19 | 显示全部楼层
高手都在睡觉吗
 楼主| 发表于 2019-6-1 07:23:47 | 显示全部楼层
请各路大神给个指示吧
GMT+8, 2025-7-15 07:01 , Processed in 0.165106 second(s), 22 queries , Gzip On.
