查看: 1286|回复: 2
梦想CAD控件自定义实体实现
发表于 2019-5-15 14:58:50 | 显示全部楼层 |阅读模式
一、增加自定义实体对象
调用DrawCustomEntity函数,绘制一个自定义实体对象。
下面代码绘制一个自定义实体,C#代码实现如下:
private void DrawMlineCommand()
    MxDrawUiPrPoint getPt = new MxDrawUiPrPoint();
    getPt.message = "点取第一点";
    if (getPt.go() != MCAD_McUiPrStatus.mcOk)
        return;
    var frstPt = getPt.value();
    if (frstPt == null)
        return;
    MxDrawUiPrPoint getSecondPt = new MxDrawUiPrPoint();
    getSecondPt.message = "点取第二点";
    getSecondPt.basePoint = frstPt;
    getSecondPt.setUseBasePt(false);
    MxDrawCustomEntity spDrawData = getSecondPt.InitUserDraw("DrawCustEntity");
    spDrawData.SetDouble("Width", 30);
    spDrawData.SetPoint("Point1", frstPt);
    Int32 lCount = 1;
    spDrawData.SetLong("Count", 1);
    while (true)
        if (getSecondPt.go() != MCAD_McUiPrStatus.mcOk)
            break;
        var secondPt = getSecondPt.value();
        if (secondPt == null)
            break;
        lCount++;
        String sPointName = "Point" + lCount.ToString();
        spDrawData.SetPoint(sPointName, secondPt);
        spDrawData.SetLong("Count", lCount);
    if (lCount > 1)
        axMxDrawX1.DrawEntity(spDrawData);
js代码实现如下:
//绘制自定义实体
function DyInsertCustomEntity() {
    //清空当前显示内容
    mxOcx.NewFile();
    var getPt = mxOcx.NewComObject("IMxDrawUiPrPoint");
    if (getPt.go() != 1)
        return;
    if (frstPt == null)
        return;
    var getSecondPt = mxOcx.NewComObject("IMxDrawUiPrPoint");
    getSecondPt.setUseBasePt(true);
    if (getSecondPt.go() != 1)
        return;
        return;
    var ent = mxOcx.DrawCustomEntity("TestMxCustomEntity", "");
    ent.SetPoint("spt", frstPt);
    ent.SetPoint("ept", secondPt);
//绘制自定义实体1
function MyInsertCustomEntity()
{ //清空当前显示内容
    mxOcx.NewFile();
    var spDrawData;
    var getPt1 = mxOcx.NewComObject("IMxDrawUiPrPoint");
        getPt1.message = "点取第一点";
        spDrawData = getPt1.InitUserDraw("DynDrawEnt1");
        if (getPt1.go() != 1) {
            return;
    var getPt2 = mxOcx.NewComObject("IMxDrawUiPrPoint");
        getPt2.message = "点取第二点";
        spDrawData = getPt2.InitUserDraw("DynDrawEnt2");
        spDrawData.SetPoint("vFirst", getPt1.value());
        if (getPt2.go() != 1) {
            return;
    var getPt3 = mxOcx.NewComObject("IMxDrawUiPrPoint");
        getPt3.message = "点取第三点";
        spDrawData = getPt3.InitUserDraw("DynDrawEnt3");
        spDrawData.SetPoint("vSecond", getPt2.value());
        if (getPt3.go() != 1) {
            return;
    var getPt4 = mxOcx.NewComObject("IMxDrawUiPrPoint");
        getPt4.message = "点取第四点";
        spDrawData = getPt4.InitUserDraw("DynDrawEnt4");
        spDrawData.SetPoint("vThird", getPt3.value());
        if (getPt4.go() != 1) {
            return;
        spDrawData = mxOcx.DrawCustomEntity("DrawEnt", "");
        spDrawData.SetPoint("vFour", getPt4.value());
二、响应自定义事件,绘制自定义实体
需要响应DMxDrawXEvents::CustomEntity_Explode事件。
下面例子,得到自实体的数据,C#代码实现如下:
private void axMxDrawX1_CustomEntity_Explode(object sender, AxMxDrawXLib._DMxDrawXEvents_CustomEntity_ExplodeEvent e)
            MxDrawCustomEntity pCustomEntity = (MxDrawCustomEntity)e.pCustomEntity;
            var sGuid = pCustomEntity.Guid;
            MxDrawWorldDraw pWorldDraw = (MxDrawWorldDraw)e.pDraw;
            if (sGuid == "DrawCustEntity")
                MyDrawMline(pWorldDraw, pCustomEntity, null);
                e.pRet = 1;
private void MyDrawMline(MxDrawWorldDraw pWorldDraw, MxDrawCustomEntity pCustomEntity, MxDrawPoint curPt)
    // 取自定义实体的端点数目,属性。
    if (!pCustomEntity.IsHave("Count"))
        return;
    long lCount = pCustomEntity.GetLong("Count");
    MxDrawPolyline tmpPl = new MxDrawPolyline();
    for (long i = 0; i < lCount; i++)
        String sName;
        sName = "Point" + (i + 1).ToString();
        if (!pCustomEntity.IsHave(sName))
            break;
        // 取自定义实体的端点坐标。
        MxDrawPoint pt = pCustomEntity.GetPoint(sName);
        // 把端点坐标,传给pl线,用于生成双线。
        tmpPl.AddVertexAt(pt);
    if (curPt != null)
        tmpPl.AddVertexAt(curPt);
    if (tmpPl.NumVerts < 2)
        // 端点数少于2就,不构成直线,就不需要显示。
        return;
    // 求pl线,开始点的导数.
    MxDrawVector3d vecFx;
    if (!tmpPl.GetFirstDeriv(tmpPl.GetStartParam(), out vecFx))
        return;
    if (vecFx.IsZeroLength())
        return;
    // 把向量旋转90度.
    vecFx.RotateByXyPlan(3.14159265 / 2.0);
    vecFx.Normalize();
    //  得到双线的宽度属性。
    double dWidth = pCustomEntity.GetDouble("Width");
    vecFx.Mult(dWidth);
    MxDrawPoint startPt = tmpPl.GetStartPoint();
    // 向pl线,两个方向偏移,
    MxDrawPoint offsetPt1 = new MxDrawPoint();
    offsetPt1.x = startPt.x;
    offsetPt1.y = startPt.y;
    offsetPt1.Add(vecFx);
    MxDrawPoint offsetPt2 = new MxDrawPoint();
    offsetPt2.x = startPt.x;
    offsetPt2.y = startPt.y;
    offsetPt2.Sum(vecFx);
    MxDrawText text = new MxDrawText();
    text.TextString = "Test";
    text.Height = 100;
    text.Position = startPt;
    text.AlignmentPoint = startPt;
    MxDrawPoint pt1, pt2;
    text.GetBoundingBox(out pt1, out pt2);
    MxDrawPoint pt3 = new MxDrawPoint();
    pt3.x = pt1.x;
    pt3.y = pt2.y;
    MxDrawPoint pt4 = new MxDrawPoint();
    pt4.x = pt2.x;
    pt4.y = pt1.y;
    MxDrawPoints pts = new MxDrawPoints();
    pts.Add(pt1.x, pt1.y, 0);
    pts.Add(pt3.x, pt3.y, 0);
    pts.Add(pt2.x, pt2.y, 0);
    pts.Add(pt4.x, pt4.y, 0);
    Int32 lDraworder = pWorldDraw.Draworder;
    pWorldDraw.Draworder = lDraworder + 1;
    pWorldDraw.DrawWipeout(pts);
    pWorldDraw.Draworder = lDraworder + 2;
    pWorldDraw.DrawEntity((MxDrawEntity)text);
    pWorldDraw.Draworder = lDraworder;
    //    pWorldDraw->
        MxDrawResbuf newobj;
        if (tmpPl.OffsetCurves(dWidth, offsetPt1, out newobj))
            for (Int32 j = 0; j < newobj.Count; j++)
                MxDrawEntity tmpObj = (MxDrawEntity)newobj.AtObject(j);
                if (tmpObj == null)
                    continue;
                pWorldDraw.DrawEntity(tmpObj);
            newobj.RemoveAll();
        if (tmpPl.OffsetCurves(dWidth, offsetPt2, out newobj))
                if (tmpObj == null)
                    continue;
            // 这不使用newobj,需要显示调用RemoveAll函数清楚内存。
            // 不然这个可能就会程序退出时才释放,这时它会去释放控件对象指针,有可能会出错。
            newobj.RemoveAll();
js代码实现如下:
// 自定义实体绘制函数
function ExplodeFun(pCustomEntity, pWorldDraw, txt) {
    if (sGuid == "TestMxCustomEntity") {
        if (!pCustomEntity.IsHave("ept"))
            return;
        var stp = pCustomEntity.GetPoint("spt");
        if (stp == null)
            return;
        var ept = pCustomEntity.GetPoint("ept");
        if (ept == null)
            return;
        var mxUtility = mxOcx.NewUtility();
        var vec = ept.SumVector(stp);
        vec.Mult(0.5);
        var midPt = mxOcx.NewPoint();
        midPt.x = stp.x;
        midPt.y = stp.y;
        midPt.Add(vec);
        var dAng = vec.Angle();
        //计算一个标注角度,使用文字对象始终头朝上
        dAng = mxUtility.GetDimAngle(dAng);
        var dDis = 0.0;
        dDis = stp.DistanceTo(ept);
        var sTxt = "L=" + formatNumber(dDis, '#.##');
        dAng = dAng * 180.0 / 3.14159265;
        vec.RotateByXyPlan(3.14159265 / 2.0);
        vec.Normalize();
        vec.Mult(10);
        stp.Add(vec);
        ept.Add(vec);
        pWorldDraw.DrawLine(stp.x, stp.y, ept.x, ept.y);
        vec.Mult(2);
        stp.Sum(vec);
        ept.Sum(vec);
        pWorldDraw.SetColorIndex(1);
        pWorldDraw.DrawText(midPt.x, midPt.y, sTxt, 5, dAng,
            1, 2);
        mxOcx.SetEventRet(1);
    var dHeigth = mxOcx.ViewLongToDocCoord(5);
    // 绘制绘制自定义实体1
    if(sGuid == "DrawEnt"){
            if (!pCustomEntity.IsHave("vFour"))
                return;
            if (!pCustomEntity.IsHave("vThird"))
                return;
            if (!pCustomEntity.IsHave("vSecond"))
                return;
            if (!pCustomEntity.IsHave("vFirst"))
                return;
            var vFourPt = pCustomEntity.GetPoint("vFour");
            var dX = vFourPt.x;
            var dY = vFourPt.y;
            var vThirdPt = pCustomEntity.GetPoint("vThird");
            pWorldDraw.DrawLine(vThirdPt.x, vThirdPt.y, dX, dY);
            pWorldDraw.DrawText(dX, dY, "(" + dX.toFixed(1) + "," + dY.toFixed(1) + ")", dHeigth, 0, 1, 1);
            var dX = vThirdPt.x;
            var dY = vThirdPt.y;
            var vSecondPt = pCustomEntity.GetPoint("vSecond");
            pWorldDraw.DrawLine(vSecondPt.x, vSecondPt.y, dX, dY);
            dX = vSecondPt.x;
            dY = vSecondPt.y;
            var vFirstPt = pCustomEntity.GetPoint("vFirst");
            pWorldDraw.DrawLine(vFirstPt.x, vFirstPt.y, dX, dY);
            dX = vFirstPt.x;
            dY = vFirstPt.y;
三、响应自定义事件,动态绘制
C#代码实现如下:
private void axMxDrawX1_DynWorldDraw(object sender, AxMxDrawXLib._DMxDrawXEvents_DynWorldDrawEvent e)
    MxDrawCustomEntity pCustomEntity = (MxDrawCustomEntity)e.pData;
    String sGuid = pCustomEntity.Guid;
    e.pRet = 0;
    MxDrawWorldDraw pWorldDraw = (MxDrawWorldDraw)e.pWorldDraw;
    MxDrawPoint curPt = new MxDrawPoint();
    curPt.x = e.dX;
    curPt.y = e.dY;
        MyDrawMline(pWorldDraw, pCustomEntity, curPt);
js代码实现如下:
//动态施放绘制事件回调函数指针
//动态拖放时的绘制事件
//参数一为当前鼠标位置X坐标;参数为二当前鼠标位置Y坐标;
// 参数三为IMxDrawWorldDraw对象,用于动态绘制;参数四为IMxDrawCustomEntity对象,动态绘制数据
function DoDynWorldDrawFun(dX,dY,pWorldDraw,pData) {
    //自定义实体的GUID标识符
    var sGuid = pData.Guid;
    //设置自定义事件的返回值
    mxOcx.SetEventRet(0);
    var curPt = mxOcx.NewPoint();
    curPt.x = dX;
    curPt.y = dY;
    //自定义实体的GUID标识符
    switch (pData.Guid) {
        case "DynDrawEnt4":
            var vThirdPt = pData.GetPoint("vThird");
            dX = vThirdPt.x;
            dY = vThirdPt.y;
        case "DynDrawEnt3":
            var vSecondPt = pData.GetPoint("vSecond");
            dX = vSecondPt.x;
            dY = vSecondPt.y;
        case "DynDrawEnt2":
            var vFirstPt = pData.GetPoint("vFirst");
            dX = vFirstPt.x;
            dY = vFirstPt.y;
        case "DynDrawEnt1":
    //设置自定义事件的返回值
四、响应自定义事件,返回自定义实体夹点
需要响应_DMxDrawXEvents::CustomEntity_getGripPoints事件,C#代码实现如下:
private void axMxDrawX1_CustomEntity_getGripPoints(object sender, AxMxDrawXLib._DMxDrawXEvents_CustomEntity_getGripPointsEvent e)
    e.pOk = 0;
            return;
        MxDrawResbuf ret = (MxDrawResbuf)axMxDrawX1.NewResbuf();
            String sName;
                break;
            // 取自定义实体的端点坐标。
            ret.AddPoint(pt);
        e.pOk = 1;
        axMxDrawX1.SetEventRetEx(ret);
js代码实现如下:
// 返回自定义实体夹点
function GetGripPointsFun(pCustomEntity) {
    //自定义实体绘制两条直线
            return;
        if (stp == null)
            return;
        if (ept == null)
            return;
        var ret = mxOcx.NewResbuf();
        ret.AddPoint(stp);
        ret.AddPoint(ept);
        mxOcx.SetEventRetEx(ret);
    //自定义实体1
    if (sGuid == "DrawEnt") {
            return;
        var stp = pCustomEntity.GetPoint("vFirst");
        if (stp == null)
            return;
        var ept = pCustomEntity.GetPoint("vSecond");
        if (ept == null)
            return;
        var tpt = pCustomEntity.GetPoint("vThird");
        if (tpt == null)
            return;
        var fpt = pCustomEntity.GetPoint("vFour");
        if (fpt == null)
            return;
        ret.AddPoint(stp);
        ret.AddPoint(ept);
        ret.AddPoint(tpt);
        ret.AddPoint(fpt);
五、响应自定义事件,夹点移动后的处理
需要响应CustomEntity_moveGripPointsAt事件。
下面例子,夹点移动后,修改自定义实体的属性,C#代码实现如下:
private void axMxDrawX1_CustomEntity_moveGripPointsAt(object sender, AxMxDrawXLib._DMxDrawXEvents_CustomEntity_moveGripPointsAtEvent e)
    e.pRet = 1;
            return;
            String sName;
                break;
            // 取自定义实体的端点坐标。
            if (i == e.lGridIndex)
                pt.x = pt.x + e.dOffsetX;
                pt.y = pt.y + e.dOffsetY;
                pCustomEntity.SetPoint(sName, pt);
js代码实现如下:
// 移动自定义实体夹点
function MoveGripPointsFun(pCustomEntity, lGridIndex, dOffsetX, dOffsetY) {
            return;
        if (stp == null)
            return;
        if (ept == null)
            return;
        if (lGridIndex == 0) {
            stp.x = stp.x + dOffsetX;
            stp.y = stp.y + dOffsetY;
            pCustomEntity.SetPoint("spt", stp);
        else {
            ept.x = ept.x + dOffsetX;
            ept.y = ept.y + dOffsetY;
            pCustomEntity.SetPoint("ept", ept);
            return;
        if (stp == null)
            return;
        if (ept == null)
            return;
        if (tpt == null)
            return;
        if (fpt == null)
            return;
            pCustomEntity.SetPoint("vFirst", stp);
            pCustomEntity.SetPoint("vSecond", ept);
            tpt.x = tpt.x + dOffsetX;
            tpt.y = tpt.y + dOffsetY;
            pCustomEntity.SetPoint("vThird", tpt);
            fpt.x = fpt.x + dOffsetX;
            fpt.y = fpt.y + dOffsetY;
            pCustomEntity.SetPoint("vFour", fpt);
六、自定义实体之打碎
c#代码实现如下
            // 打开图纸文件。
            axMxDrawX1.OpenDwgFile("C:\西桥头村.dwg");
            // 打碎图纸上的自定义实体。
            MxDrawResbuf filter = new MxDrawResbuf();
            // 设置选择过滤条件,只选择自定义实体。
            filter.AddStringEx("ACAD_PROXY_ENTITY", 5020);
            MxDrawSelectionSet ss = new MxDrawSelectionSet();
            // 得到所有自定义实体。
            ss.AllSelect(filter);
            // 遍历自定义实体
            for (Int32 i = 0; i < ss.Count; i++)
                MxDrawEntity ent = ss.Item(i);
                MxDrawResbuf param = new MxDrawResbuf();
                param.AddObjectId(ent.ObjectID);
                // 打碎自定义实体。
                MxDrawResbuf ret = (MxDrawResbuf)axMxDrawX1.CallEx("Mx_Explode", param);
                // 删除自定义实体。
                if(ret.AtString(0) == "Ok")
                    ent.Erase();
            // 把图纸所有内容都放到当前视区。
            axMxDrawX1.ZoomAll();
七、在块表记录中添加一个自定义实体
c#代码实现如下
        MxDrawDatabase database = (MxDrawDatabase)axMxDrawX1.GetDatabase();
        MxDrawBlockTableRecord blkRec = database.CurrentSpace();
        // 调用AddCustomEntity函数绘制自定义实体。 逗号后的字符串"DrawCustEntity"是自定义实体的GUID
        MxDrawResbuf ret =  blkRec.GetProp("AddCustomEntity,DrawCustEntity");
        // 得到自定义实体。
        MxDrawCustomEntity ent = (MxDrawCustomEntity)database.ObjectIdToObject(ret.AtObjectId(0));
        // 设置自定义实体的属性。
        ent.BeginSetValue();
        ent.SetDouble("Width", 30);
        MxDrawPoint pt1 = new MxDrawPoint();
        pt1.x = 10;
        pt1.y = 10;
        MxDrawPoint pt2 = new MxDrawPoint();
        pt2.x = 20;
        pt2.y = 20;
        ent.SetPoint("Point1", pt1);
        ent.SetPoint("Point2", pt2);
        ent.SetLong("Count", 2);
        ent.EntSetValue();
发表于 2019-6-21 00:48:13 来自手机 | 显示全部楼层
厉害,学习了自定义实体
发表于 2019-7-17 20:40:07 | 显示全部楼层
楼主应该多介绍下 这个软件啊
GMT+8, 2025-5-1 13:11 , Processed in 0.174563 second(s), 24 queries , Gzip On.
