查看: 925|回复: 1
打断插文字
发表于 2019-4-21 12:49:10 | 显示全部楼层 |阅读模式
;***打断插文字
(defun c:ddt ()
(setq th (getdist "\请输入文字高度:"))
(setq r(* th 1.25))
(setq t (getstring "请输入要插入的文字:"))
(setq h1 (entsel))
(setq h2 (getpoint"\n选择插入点:"))
(while h2
(command "circle" h2 r)
(setq na (entlast))
(command "trim" na "" h1"")
(command "text""J""M" h2 th""t)
(command "erase" na"")
(setq h1 (entsel))
 楼主| 发表于 2019-4-21 13:08:55 | 显示全部楼层
;批量修改文字角度程序
GMT+8, 2025-5-24 20:23 , Processed in 0.161380 second(s), 23 queries , Gzip On.
