查看: 1365|回复: 8
求CAD打印时,自动设置图纸图幅尺寸程序!
发表于 2019-4-10 16:21:58 | 显示全部楼层 |阅读模式
1明经币
求CAD打印时,自动设置图纸图幅尺寸程序!如不规格图纸,任意A3加长图纸,任意尺寸图纸,可根据矩形框、外部参照、图块或手动输入图纸尺寸大小(任一功能皆可)。
发表于 2019-4-10 19:10:06 | 显示全部楼层
具体点,大哥.
 楼主| 发表于 2019-4-13 14:06:37 | 显示全部楼层
比如将图纸转换成PDF,设置PDF打印机,然后设置图纸尺寸(任意矩形框,外部参照等尺寸)。
发表于 2019-4-13 20:39:01 | 显示全部楼层
优先选择“DWG TO PDF.PC3",这么多尺寸不够吗?需要自定义尺寸么?
有些形状就是填不满的。
ISO_expand_A0_(841.00_x_1189.00_MM)
ISO_A0_(841.00_x_1189.00_MM)
ISO_expand_A1_(841.00_x_594.00_MM)
ISO_expand_A1_(594.00_x_841.00_MM)
ISO_A1_(841.00_x_594.00_MM)
ISO_A1_(594.00_x_841.00_MM)
ISO_expand_A2_(594.00_x_420.00_MM)
ISO_expand_A2_(420.00_x_594.00_MM)
ISO_A2_(594.00_x_420.00_MM)
ISO_A2_(420.00_x_594.00_MM)
ISO_expand_A3_(420.00_x_297.00_MM)
ISO_expand_A3_(297.00_x_420.00_MM)
ISO_A3_(420.00_x_297.00_MM)
ISO_A3_(297.00_x_420.00_MM)
ISO_expand_A4_(297.00_x_210.00_MM)
ISO_expand_A4_(210.00_x_297.00_MM)
ISO_A4_(297.00_x_210.00_MM)
ISO_A4_(210.00_x_297.00_MM)
ARCH_expand_E1_(30.00_x_42.00_Inches)
ARCH_E1_(30.00_x_42.00_Inches)
ARCH_expand_E_(36.00_x_48.00_Inches)
ARCH_E_(36.00_x_48.00_Inches)
ARCH_expand_D_(36.00_x_24.00_Inches)
ARCH_expand_D_(24.00_x_36.00_Inches)
ARCH_D_(36.00_x_24.00_Inches)
ARCH_D_(24.00_x_36.00_Inches)
ARCH_expand_C_(24.00_x_18.00_Inches)
ARCH_expand_C_(18.00_x_24.00_Inches)
ARCH_C_(24.00_x_18.00_Inches)
ARCH_C_(18.00_x_24.00_Inches)
ANSI_expand_E_(34.00_x_44.00_Inches)
ANSI_E_(34.00_x_44.00_Inches)
ANSI_expand_D_(34.00_x_22.00_Inches)
ANSI_expand_D_(22.00_x_34.00_Inches)
ANSI_D_(34.00_x_22.00_Inches)
ANSI_D_(22.00_x_34.00_Inches)
ANSI_expand_C_(22.00_x_17.00_Inches)
ANSI_expand_C_(17.00_x_22.00_Inches)
ANSI_C_(22.00_x_17.00_Inches)
ANSI_C_(17.00_x_22.00_Inches)
ANSI_expand_B_(17.00_x_11.00_Inches)
ANSI_expand_B_(11.00_x_17.00_Inches)
ANSI_B_(17.00_x_11.00_Inches)
ANSI_B_(11.00_x_17.00_Inches)
ANSI_expand_A_(11.00_x_8.50_Inches)
ANSI_expand_A_(8.50_x_11.00_Inches)
ANSI_A_(11.00_x_8.50_Inches)
ANSI_A_(8.50_x_11.00_Inches)
ANSI_A_(8.50_x_11.00_Inches)               215.899993896484x279.399993896484
发表于 2019-4-14 21:48:21 | 显示全部楼层
几句话的问题. 实现是挺复杂的. 论坛也有一些 能实现打印功能的小插件. 可以查找后自己尝试使用一下.  如果你要实现十分适合你的图纸情况的.程序.  一时也没有.  我用的都是自己开发的. 任意比例,任意长度.程序自已会设置相应参数.笔表等. 输出到物理打印机. 或生成PDF,同时生成JPG ...
 楼主| 发表于 2019-4-17 12:53:04 | 显示全部楼层
有些形状就是填不满的。
尺寸不是标准图幅啊,不规则。
 楼主| 发表于 2019-4-17 12:53:49 | 显示全部楼层
Bell 发表于 2019-4-14 21:48
几句话的问题. 实现是挺复杂的. 论坛也有一些 能实现打印功能的小插件. 可以查找后自己尝试使用一下.  如果 ...
请问可否共享呢?
发表于 2019-4-17 13:50:35 | 显示全部楼层
同样需求者路过,因为要打印的图纸大大小小,都不是标准图框,每次都要测量图框的长宽,再添加新图框,真的好麻烦
发表于 2019-4-17 20:56:10 | 显示全部楼层
给你个思路吧,先用Hp的虚拟打印机设置一个超长A0图纸,比如845X3000(或者更长)的图纸,一张顶万张,然后编程判断.
GMT+8, 2025-5-1 08:14 , Processed in 0.157296 second(s), 21 queries , Gzip On.
