查看: 3480|回复: 5
【超级显示/隐藏工】多年前的好贴,别再错过了
发表于 2019-4-9 07:26:53 | 显示全部楼层 |阅读模式
原贴网址http://bbs.mjtd.com/thread-24923-5-1.html
;;优化交互界面,by1028695446--2019.4.9
;;By LUCAS(龙龙仔)(原著)
;;这是无痕的思路(不会用就找他)
;;超级隐藏/显示工具
(prompt "\n超级隐藏/显示工具-------------龙龙仔.2004.1")
(alert
        (strcat
                "\n\n-----------超级隐藏/显示工具(测试版V0)-龙龙仔.2004.1----------"
                "\n\n-----------------交互界面优化-102869554-----------------------"
                "\n\n显示所有(E)           隐藏所有(D)"
                "\n\n显示已标记组(V)     隐藏已标记组(C)/"
                "\n\n显示上个标记组(S)  显示下个标记组(F)/"
                "\n\n锁定显示(空格)===显示上一个/下一个的时候不会被隐藏"
                "\n\n显示解锁(R)=====显示上一个/下一个的时候会  被隐藏"
                "\n\n显示记录列表(B)    退出(X)/"
                "\n\n增加隐藏标记组(A)  删除隐藏标记组(Q)/"
                "\n\n清空记录(Z):"
                "\n\n主程序(XSHOW_LAI <词典名称>)---------------------------------"
                "\n\n这样用户可以自定义快捷键,并创建多个词典,用于存储标记组-------"
                "\n\n如defun C:xy( )(XSHOW_LAI " "\"LUNG\""")),本程序默认设置---"
                "\n\n超级命令,对所有词典管用-----C:XSHOWALL-----------------------"
                "\n\n超级命令,对所有词典管用-----C:XHIDEALL-----------------------"
;;超级隐藏/显示工具
;;By LUCAS(龙龙仔)
;;写好就没有用过.......
(defun C:xy()(XSHOW_LAI "LUNG"))
(defun C:xsa()(C:XSHOWALL));;显示全部
(defun C:yca()(C:XHIDEALL));;隐藏全部
(vl-load-com)
(defun C:XSHOWALL (/ SSOBJ ENT)
        (if
                (and
                        (ssget "X" (list (cons 60 1) (cons 410 (getvar "CTAB"))))
                        (setq SSOBJ (ssget "X" (list (cons 410 (getvar "CTAB")))))
                        (setq        SSOBJ (vla-get-activeselectionset        (vla-get-activedocument (vlax-get-acad-object))))
                        (vlax-for ENT SSOBJ
                                (vla-put-visible ENT :vlax-true)
                        (prompt "\n显示所有物件!")
                (prompt "\n无隐藏物件!")
(defun C:XHIDEALL (/ SSOBJ ENT)
        (if (setq SSOBJ (ssget "X" (list (cons 410 (getvar "CTAB")))))
                        (vlax-for        ENT SSOBJ        (vla-put-visible ENT :vlax-false))
                        (prompt "\n隐藏所有物件!")
) ;;(CHECK "LUNG");;获取词典列表索引
(defun CHECK (DICT / DICT_KEY ENT LL N)
        (setq        DICT_KEY (vlax-ldata-list DICT)        N        0)
        (repeat (length DICT_KEY)
                (setq LL (cons (car (nth N DICT_KEY)) LL))
                (setq N (1+ N))
        LL
) ;;(DICT_OFF "LUNG" "1");;隐藏
(defun DICT_OFF        (DICT KEY / SS ENT)
        (setq SS (cdr (assoc KEY (vlax-ldata-list DICT))))
        (foreach ENT SS
                (if        (and (setq ENT (handent ENT)) (entget ENT))
                        (vla-put-visible (vlax-ename->vla-object ENT) :vlax-false)
) ;;(DICT_ON "LUNG" "1");;显示
(defun DICT_ON (DICT KEY / SS ENT)
        (foreach ENT SS
                        (vla-put-visible (vlax-ename->vla-object ENT) :vlax-true)
) ;;(MAKE_DICT "LUNG" "1" (SSGET));;存储图元句柄(5 . *)
(defun MAKE_DICT (DICT KEY SS / ENAME_LIST N)
        (setq N 0)
        (repeat (sslength SS)
                (setq ENAME_LIST
                        (cons (cdr (assoc 5 (entget (ssname SS N))))
                                ENAME_LIST
                (setq N (1+ N))
        (vlax-ldata-put DICT KEY ENAME_LIST)
) ;;主程序
;;(XSHOW_LAI "LUNG")
(defun XSHOW_LAI (DICT / KEY N LEN LIS LIS1 LOOP MSG MODE S1 TMPKEY)
        (if (not (setq N (vlax-ldata-get (strcat DICT "_N") "N")));;如有N没有被存储...N为当前记录索引值
                        (setq N 0);;设定默认值,,暂时设定为0,原先为1
                        (vlax-ldata-put (strcat DICT "_N") "N" 1);;给n创建词典,用于记录
        (if (not (setq LIS (vlax-ldata-get (strcat DICT "_LIS") "LIS")));;如有LIS没有被存储...用于锁定标记
                        (setq LIS '());;设定默认值
                        (vlax-ldata-put (strcat DICT "_LIS") "LIS" LIS)
        (setq        MSG
                "\n[显示所有(E)/隐藏所有(D)/显示记录(V)/隐藏记录(C)/显示上个(S)/显示下个(F)/显示锁定(空格)/显示解锁(R)/记录列表(B)/退出(X)/增加隐藏(A)/删除标记(Q)/清空记录(Z)]:"
        (prompt MSG)
        (setq LOOP t)
        (while LOOP
                (setq MODE (grread t 4 0));(grread t 4 2)
                (cond
                        ((or
                                 (member MODE '((2 13) (2 88) (2 120) ));;; CTRL-M或回车;;; X键;;; x键;;; 鼠标右键,右键设置为回车时
                                 (= (car MODE) 11);;; 鼠标右键,右键设置为回车时
                                 (= (car MODE) 25);;; 鼠标右键,右键设置为屏幕菜单时
                                (setq LOOP NIL)
                        ((member MODE '((2 65) (2 97)))        ;A
                                (if (CHECK DICT);;如果已经有记录索引
                                        (setq KEY (rtos (1+ (last (setq KEY_LIST
        (vl-sort (mapcar 'atof (CHECK DICT)) '<);;列表从小到大排列
                                        );指定最新的标记索引
                                        (setq KEY "1")
                                (setq LEN (length (vlax-ldata-list DICT)))
                                ;;(vlax-ldata-put "LUNG" "KEY_LIST" KEY_LIST)
                                ;;(setq KEY (rtos (1+ (apply 'max (mapcar 'atof (CHECK "LUNG"))))))
                                (prompt (strcat "\n" DICT "增选隐藏物件:"))
                                (if (setq S1 (ssget))
                                        (MAKE_DICT DICT KEY S1);;添加标记内容
                                (prompt MSG)
                        ((member MODE '((2 69) (2 101)))        ;E;;;;这个正确*********************************************
                                (C:XSHOWALL)
                                (prompt MSG)
                        ((member MODE '((2 100) (2 68)))        ;D;;;;这个正确*********************************************
                                (C:XHIDEALL)
                                (prompt MSG)
                        ((member MODE '((2 67) (2 99)))        ;C;;隐藏被记录图元
                                (setq CHECK_LIST (CHECK DICT))
                                (mapcar '(lambda        (X)
        (DICT_OFF DICT X);;关闭被记录的图元
                                        CHECK_LIST
                                (prompt (strcat"\n" DICT "中标记物件已被--全部隐藏!"))
                                (prompt MSG)
                        ((member MODE '((2 86) (2 118)))        ;V
        (DICT_ON DICT X)
                                        CHECK_LIST
                                (prompt (strcat"\n" DICT "中标记物件已被--全部显示!"))
                                (prompt MSG)
                        ((member MODE '((2 83) (2 115)))        ;S
                                (if (not (setq N (vlax-ldata-get (strcat DICT "_N") "N")));;取出N值
                                                (setq N 1);;设定默认值,,暂时设定为0,原先为1************************************
                                                (vlax-ldata-put (strcat DICT "_N") "N" 1);;存储N
                                (if (setq LIS1 (CHECK DICT))
                                                (setq LEN (length LIS1))
                                                (if (= N (1- LEN));;N为最后一值(最大值),那就重0开始,循环往复
                                                        (setq N 0);;;为什么要设为0,默认值1干嘛用的***********************************
                                                        (setq N (1+ N))
                                                (DICT_ON DICT (nth N LIS1));;显示下一个
                                                (if (= N 0)
                                                        (setq TMPKEY (nth (1- LEN) LIS1));;设置索引最大值
                                                        (setq TMPKEY (nth (1- N) LIS1))
                                                );;记录之前所在位置
                                                (if (not (member TMPKEY LIS))
                                                        (DICT_OFF DICT TMPKEY)
                                                (vlax-ldata-put (strcat DICT "_N") "N" N);;存储当前索引值
                                                (prompt (strcat "\n" DICT "显示第"
        (vl-prin1-to-string(nth N LIS1))
        "笔物件,锁定串列="
        (vl-prin1-to-string LIS)
                                (prompt MSG)
                        ((member MODE '((2 102) (2 70)))        ;F
                                                (vlax-ldata-put (strcat DICT "_N") "N" N);;;修正了
                                                (if (= N 0)
                                                        (setq N (1- LEN))
                                                        (setq N (1- N))
                                                (if (= N (1- LEN))
                                                        (setq TMPKEY (nth 0 LIS1))
                                                        (setq TMPKEY (nth (1+ N) LIS1))
        "笔物件,锁定串列="
                                (prompt MSG)
                        ((member MODE '((2 32)))        ;"";;将当前显示的索引标记,添加的锁定栏
                                                (if
        (setq LIS '())
                                                (if (not (member (nth N LIS1) LIS))
                                                        (setq LIS (append LIS (list (nth N LIS1))))
                                                (prompt (strcat "\n" DICT "显示锁定串列"
        ",目前显示第"
        "笔物件"
                                (prompt MSG)
                        ((member MODE '((2 114) (2 82)))        ;R;;将当前显示的索引标记,从锁定栏解锁
                                                (if
        (setq LIS '())
                                                (if (member (nth N LIS1) LIS)
                                                        (setq LIS (vl-remove (nth N LIS1) LIS))
        ",目前显示第"
        "笔物件"
                                (prompt MSG)
                        ((member MODE '((2 122) (2 90)))        ;Z
                                (setq
                                KEY_LIST1 (mapcar 'rtos
                                (vl-sort (mapcar 'atof (CHECK "LUNG")) '<)
                                (setq CHECK_LIST (CHECK "LUNG"))
                                (vlax-ldata-delete "LUNG" X)
                                CHECK_LIST
                                (initget "Y ")
                                (if (getkword (strcat"\n" DICT "真的要清除所有标记物件!<N>:"))
                                                (dictremove (namedobjdict) DICT)
                                                (dictremove (namedobjdict) (strcat DICT "_N"))
                                                (dictremove (namedobjdict) (strcat DICT "_LIS"))
                                                (prompt (strcat"\n" DICT "已清除所有标记物件!"))
                                        (prompt (strcat"\n" DICT "标记物件已保留!"))
                                (prompt MSG)
                        ((member MODE '((2 113) (2 81)))        ;Q
                                                (vlax-ldata-delete DICT (nth N LIS1))
                                                (prompt (strcat "\n" DICT "已删除"
        (vl-prin1-to-string (nth N LIS1))
        "标记,目前标记"
        (vl-prin1-to-string (CHECK DICT))
                                (prompt MSG)
                        ((member MODE '((2 66) (2 98)))        ;B
                                (prompt
                                        (strcat "\n" DICT "目前标记" (if DICT (vl-prin1-to-string (CHECK DICT))))
                                (prompt MSG)
发表于 2019-4-9 17:45:58 | 显示全部楼层
原来的好象一直没用起来,现在似乎能行了。仔细研究一下,谢谢楼主!
我以前也发贴讨论过这个问题,http://bbs.mjtd.com/thread-176377-1-1.html
希望得到的结果就是一个下拉的显示状态管理器,可以存很多个这种显示隐藏的状态,可以很方便的调用。
CAD原生的是图层管理器,但很多时候很不方便,要求很严格的分层。
发表于 2019-6-18 17:13:23 | 显示全部楼层
我看到海龙工具箱与源泉工具箱都有这功能,但是我只想要 超级显示/隐藏工具,所以今天找到这里来了。这个就是我想要的原码了:http://bbs.mjtd.com/forum.php?mo ... FE%B2%D8&page=1
 楼主| 发表于 2019-11-2 00:29:55 | 显示全部楼层
cyfdean 发表于 2019-6-18 17:13
我看到海龙工具箱与源泉工具箱都有这功能,但是我只想要 超级显示/隐藏工具,所以今天找到这里来了。这个就 ...
http://bbs.mjtd.com/thread-179805-1-1.html
这里有很多的选择
发表于 2020-6-13 08:07:51 | 显示全部楼层
感谢无私分享,最喜欢源码了
发表于 2020-7-2 15:12:09 | 显示全部楼层
天正局部隐藏功能??
GMT+8, 2025-5-24 20:29 , Processed in 0.214973 second(s), 23 queries , Gzip On.
