楼主: SEU_麻
[2020] Autodesk 2020 全系官方下载地址
发表于 2019-4-7 11:17:14 | 显示全部楼层
revit 2020 应该快出来了吧 我看官网都开始改了
发表于 2019-4-11 07:31:34 | 显示全部楼层
revit 2020 昨晚发布了 谁提供一下下载地址
发表于 2019-4-11 07:34:29 | 显示全部楼层
ARCHITECTUREMEPPRODUCT NEWSSTRUCTUREWHAT’S NEW
You’ve got to see what’s new in Revit 2020
Harlan Brumm April 10, 2019   (2)    Save   17
3
Written by Harlan Brumm, Sasha Crotty, Ian Molloy, and Pawel Piechnik
The Revit team is thrilled to release Revit 2020, incorporating improvements in Revit 2019.1 and Revit 2019.2.  The release year “2020” is epic, and Revit 2020 lives up to the name, reflecting both your requests submitted to the Revit Ideas page and also introducing new features and functionality. With Revit 2020 all disciplines will see new tools and enhancements that help you generate consistent, coordinated, and complete model-based building designs and documentation.  As detailed in the public Revit Roadmap, our goal is to deliver start to finish capabilities that lead to improved project outcomes, and as product managers we’re proud to do so.
Capture detailed design intent
Multiple features new in Revit 2020 equip you to create the more accurate, detailed documentation that more closely represents design intent.
A great example that we’re particularly pleased to release are long-requested electrical design workflow improvements.
Revit now lets you utilize feed through lugs when creating your electrical distribution systems. This capability streamlines related documentation tasks, and helps designers create a better digital model of the system to support analysis.
Electrical homerun wiring improvements give you the control over arrowheads and tickmarks that you need to create electrical documentation that’s easier to understand and use.
发表于 2019-4-11 16:05:10 | 显示全部楼层
 楼主| 发表于 2019-4-11 16:50:05 | 显示全部楼层
Autodesk Civil 3D
                   英语版:http://trial2.autodesk.com/NetSWDLD/2020/CIV3D/05CC55D9-39BD-4E72-988B-D9303B20AB80/SFX/Autodesk_Civil3D_2020_English_Win_64bit_dlm_001_002.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/CIV3D/05CC55D9-39BD-4E72-988B-D9303B20AB80/SFX/Autodesk_Civil3D_2020_English_Win_64bit_dlm_002_002.sfx.exe
Autodesk Fabrication CADmep
                   英语版:http://trial2.autodesk.com/NetSWDLD/2020/CADMEP/C3843314-6190-4BA3-ACDD-A89D7CFCA1E7/SFX/CADMEP_2020_EN_WIN_64BIT_dlm.sfx.exe
Autodesk Fabrication CAMduct
                   英语版:http://trial2.autodesk.com/NetSWDLD/2020/CAMDCT/88627B8E-8BA9-4E2A-ABF5-8DFB0190E7E4/SFX/CAMDCT_2020_EN_WIN_64BIT_dlm.sfx.exe
Autodesk Fabrication ESTmep
                   英语版:http://trial2.autodesk.com/NetSWDLD/2020/ESTMEP/BE7F3E92-378D-4EBF-9DA2-19DD079CFA8E/SFX/ESTMEP_2020_EN_WIN_64BIT_dlm.sfx.exe
Autodesk Point Layout
                   英语版:http://trial2.autodesk.com/NetSWDLD/2020/PNTLAY/1.2019.03.13/ESD/Autodesk_Point_Layout_2020_Win_32-64bit_en-us.exe
Autodesk Revit
                  语版:http://trial2.autodesk.com/NetSWDLD/2020/RVT/DEB896FF-86A4-4C44-89A4-46C550BEDB60/SFX/Revit_2020_G1_Win_64bit_dlm_001_007.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVT/DEB896FF-86A4-4C44-89A4-46C550BEDB60/SFX/Revit_2020_G1_Win_64bit_dlm_002_007.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVT/DEB896FF-86A4-4C44-89A4-46C550BEDB60/SFX/Revit_2020_G1_Win_64bit_dlm_003_007.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVT/DEB896FF-86A4-4C44-89A4-46C550BEDB60/SFX/Revit_2020_G1_Win_64bit_dlm_004_007.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVT/DEB896FF-86A4-4C44-89A4-46C550BEDB60/SFX/Revit_2020_G1_Win_64bit_dlm_005_007.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVT/DEB896FF-86A4-4C44-89A4-46C550BEDB60/SFX/Revit_2020_G1_Win_64bit_dlm_006_007.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVT/DEB896FF-86A4-4C44-89A4-46C550BEDB60/SFX/Revit_2020_G1_Win_64bit_dlm_007_007.sfx.exe
Autodesk Revit LT
                  语版:http://trial2.autodesk.com/NetSWDLD/2020/RVTLT/1AE76102-B066-40B6-B420-7119BE7E8FCD/SFX/RevitLT_2020_G1_Win_64bit_dlm_001_004.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVTLT/1AE76102-B066-40B6-B420-7119BE7E8FCD/SFX/RevitLT_2020_G1_Win_64bit_dlm_002_004.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVTLT/1AE76102-B066-40B6-B420-7119BE7E8FCD/SFX/RevitLT_2020_G1_Win_64bit_dlm_003_004.sfx.exe
                                http://trial2.autodesk.com/NetSWDLD/2020/RVTLT/1AE76102-B066-40B6-B420-7119BE7E8FCD/SFX/RevitLT_2020_G1_Win_64bit_dlm_004_004.sfx.exe
Autodesk Robot Structural Analysis Pro
                  语版:http://trial2.autodesk.com/NetSWDLD/2020/RSAPRO/B0207347-925C-453B-BA7A-12180A1DE09C/SFX/Robot_Structural_Analysis_Professional_2020_Multilingual_Win_64bit_dlm.sfx.exe
Autodesk Vehicle Tracking
                  语版:http://trial2.autodesk.com/NetSWDLD/2020/VEHTRK/CB3B985A-04CE-4381-B6E2-94C370BE2E46/SFX/VEHTRK_2020_G1_WIN_64BIT_dlm.sfx.exe
 楼主| 发表于 2019-4-13 10:42:07 | 显示全部楼层
Autodesk InfraWorks
多语版:http://trial2.autodesk.com/NetSWDLD/2020/IW360P/8CE64F3A-DFD1-4B19-A945-E53BCAC58335/SFX/INFWKS_2020_G1_WIN_64BIT_dlm_001_002.sfx.exe
             http://trial2.autodesk.com/NetSWDLD/2020/IW360P/8CE64F3A-DFD1-4B19-A945-E53BCAC58335/SFX/INFWKS_2020_G1_WIN_64BIT_dlm_002_002.sfx.exe
Autodesk Navisworks Manage
多语版:http://trial2.autodesk.com/NetSWDLD/2020/NAVMAN/89ED309E-DEA4-4070-9CE7-DB285722CD73/SFX/Autodesk_Navisworks_Manage_2020_Multilingual_Win_64bit_dlm_001_002.sfx.exe
             http://trial2.autodesk.com/NetSWDLD/2020/NAVMAN/89ED309E-DEA4-4070-9CE7-DB285722CD73/SFX/Autodesk_Navisworks_Manage_2020_Multilingual_Win_64bit_dlm_002_002.sfx.exe
GMT+8, 2025-5-18 07:41 , Processed in 0.138771 second(s), 17 queries , Gzip On.
