查看: 3107|回复: 4
文本统计lisp程序
发表于 2019-2-1 11:30:06 | 显示全部楼层 |阅读模式
  • (defun c:wbtj (/      LST1   N      E     S    WB   SS  lst2
  •          lst_new       shuz   lst     lst11  lst12   height  p1
  •          WBJULI
  •   (setq  ss (ssget '((0 . "TEXT")))
  •   N  0
  •   (REPEAT (SSLENGTH SS)
  •     (SETQ E   (SSNAME SS N)
  •     S   (ENTGET E)
  •     WB   (CDR (ASSOC 1 S))
  •     height (CDR (ASSOC 40 s))
  •     LST1   (CONS WB LST1)
  •     (SETQ N (1+ N))
  •   (while (> (LENGTH LST1) 0)
  •     (IF  (NOT (MEMBER (NTH 0 LST1) LST2))
  •       (progn
  •   (SETQ LST2    (append LST2 (list (strcat (NTH 0 LST1) "=")))
  •         lst_new (vl-remove (NTH 0 LST1) LST1)
  •         shuz    (itoa (- (LENGTH LST1) (length lst_new)))
  •         lst2    (append lst2 (list shuz))
  •         lst1    lst_new
  •     (setq lst  (cons lst2 lst)
  •     lst2 nil
  •   (mapcar '(lambda (x)
  •        (setq lst11 (cons (strcat (car x) (cadr x)) lst11))
  •     lst
  •   (setq lst11 (acad_strlsort lst11))
  •   (setq WBJULI (* height 1.4))
  •   (setq p1 (getpoint "\n请指定插入点:"))
  •   (setq n 0)
  •   (foreach x lst11
  •     (command "text" p1 height "" x)
  •     (command)
  •     (setq p1 (list (car p1) (- (cadr p1) WBJULI) (caddr p1)))
  •     (setq n (1+ n))
  •   (princ)
发表于 2019-2-2 08:20:35 | 显示全部楼层
谢谢楼主的分享了。
发表于 2019-2-3 16:57:16 | 显示全部楼层
再加上统计指定字符就完美了
发表于 2019-4-22 23:03:06 | 显示全部楼层
楼主这个结果会重叠到一起。
发表于 2024-7-12 14:14:39 | 显示全部楼层
多行文字无法统计么,测试了下:
命令:
WBTJ
选择对象: 指定对角点: 找到 0 个
选择对象:  参数类型错误: lselsetp nil
命令:
GMT+8, 2025-5-2 10:21 , Processed in 0.215120 second(s), 28 queries , Gzip On.
