楼主: singer314
如何修改CAD内部命令名称
发表于 2019-1-20 17:17:32 | 显示全部楼层
真有1000明经吗
发表于 2019-1-21 16:11:46 | 显示全部楼层
singer314 发表于 2019-1-18 17:54
行,那我就试试改改acvba.arx看有没有用
改程序,影响兼容性
发表于 2019-1-21 19:37:50 | 显示全部楼层
以前,用DOS的时候,烦别人,经常动自己的电脑,把 CD 改成了 DD ,
发表于 2019-1-22 09:45:34 | 显示全部楼层
Mikewolf2k Posted at 2019-1-18 16:48
This method should only execute the new command when the original command is in effect. After the execution of the original command is invalid, the new command will be executed later, because the original command is lost...
Maybe you were wrong. Let try.
You must notice different beetwen " . VBArun" and "VBArun"
发表于 2019-1-22 10:00:13 | 显示全部楼层
ketxu 发表于 2019-1-22 09:45
Maybe you was wrong. Let try.
You must notice different beetwen ".VBArun" and "VBArun"
I didn't test. I think the originator don't want any other users to execute it, only him/she can execute it. If any command is workable, all the users can execute it also. If all the commands are not workable, the originator cannot execute it neither. I think the only to is to change the command name, the other users don't know how to execute it.
发表于 2019-4-27 19:49:33 | 显示全部楼层
mikewolf2k 发表于 2019-1-18 10:38
acad.pgp
另外看下楼主怎么支付赏金,身无分文悬赏50。
贴主明经币显示50,悬赏1000,这个没问题的,悬赏发布的时候这1000币是选扣掉的。你自已没有发过悬赏不懂。
发表于 2019-4-27 20:50:11 | 显示全部楼层
这个的思路是写一个外挂,而不是插件。运行外挂后修改acad.exe的内存,想改成什么都可以。
写这个的困难在于acad有多个版本,加载后内存位置是不同的,需要每个 版本都单独处理一下。难度不大,但非常麻烦,估计为了个1000个币,没有人去做。
发表于 2019-4-28 19:00:53 | 显示全部楼层
我发过一次悬赏,先扣币的,没人解答,后来就不发悬赏了,
悬赏1000明经币是两百块钱,是个大佬
GMT+8, 2025-5-1 15:00 , Processed in 0.174883 second(s), 16 queries , Gzip On.
