查看: 2214|回复: 4
这是一个刷标注的插件,布局图中只刷标注和文字,有些问题,能帮忙改一下
发表于 2018-11-5 18:57:17 | 显示全部楼层 |阅读模式
我先说这个插件的用法,在布局图中只刷标注和文字,相当于你重新套视口,以前的标注就在这视口不一样的大小,用法就是在视口中随便出一个标注,用插件命令就能刷视口所有标注和文字。自动就能匹配视口大小。就是有些问题,刷了以后自动给你生成一个标注替代,造成后续标注都是一样大。能帮忙改一下不然它生成一个替代。     也可以用格式刷,但就是格式刷会把图形,标注,文字把全部都刷了。我就想刷标注。以下是源代码
(DEFUN C:DUU (/ BlkElist@ BlkEname^ BlkEntList@ BlkEntName^ BlkList@ Cnt#
  DimStyle@ DimTad# DimValue DimVarDxf# EndLen# EndList@ EntName^ EntName1^
  EntList@ EntType$ Font$ Num# OSmode# SSet& StyHeight~ TextHeight~
  );variables
  (setq OSmode# (getvar "osmode"))
  (setvar "cmdecho" 0)(setvar "regenmode" 1)***
  (setq EntName1^ (car (entsel "必须选择标注样式,再刷需要匹配的标注样式和文字!: ")))
  (if EntName1^
    (setq EntList@ (entget EntName1^ (list "*"))
          EntType$ (cdr (assoc 0 EntList@))
          EndList@ (last EntList@)
    );setq
  );if
  (if (= EntType$ "DIMENSION")
      (redraw EntName1^ 3)
      (setq BlkEntName^
        (cdr (assoc -2 (tblsearch "BLOCK" (cdr (assoc 2 EntList@)))))
      );setq
      (while (setq BlkEntName^ (entnext BlkEntName^))
        (setq BlkEntList@ (entget BlkEntName^))
        (if (= (cdr (assoc 0 BlkEntList@)) "MTEXT")
          (setq TextHeight~ (cdr (assoc 40 BlkEntList@)))
        );if
      );while
      (command ".DIMSTYLE" "R" (cdr (assoc 3 EntList@)))
      (setq DimStyle@ (tblsearch "STYLE" (getvar "DIMTXSTY")))
      (command ".TEXTSIZE" TextHeight~)
      (if (/= (cdr (assoc 40 (tblsearch "STYLE" (cdr (assoc 3 EntList@))))) 0)
        (command ".STYLE" (cdr(assoc 3 EntList@)) "" TextHeight~ "" "" "" "" "")
      );if
      (command ".LAYER" "S" (cdr (assoc 8 EntList@)) "")
      (if (= (car EndList@) -3)
          (setq EndList@ (nth 1 EndList@)
                EndLen# (/ (length EndList@) 2)
                Num# 1
          );setq
          (repeat EndLen#
            (if (= (type (nth Num# EndList@)) 'LIST)
              (if (= (car (nth Num# EndList@)) 1070)
                (if (or (= (car (nth (1+ Num#) EndList@)) 1040)
                        (= (car (nth (1+ Num#) EndList@)) 1070)
                    );or
                    (setq DimVarDxf# (cdr (nth Num# EndList@))
                          DimValue (cdr (nth (1+ Num#) EndList@))
                    );setq
                    (cond
                      ( (= DimVarDxf# 3)  (setvar "DIMPOST" DimValue))
                      ( (= DimVarDxf# 4)  (setvar "DIMAPOST"DimValue))
                      ( (= DimVarDxf# 5)  (setvar "DIMBLK"  DimValue))
                      ( (= DimVarDxf# 6)  (setvar "DIMBLK1" DimValue))
                      ( (= DimVarDxf# 7)  (setvar "DIMBLK2" DimValue))
                      ( (= DimVarDxf# 40) (setvar "DIMSCALE"DimValue))
                      ( (= DimVarDxf# 41) (setvar "DIMASZ"  DimValue))
                      ( (= DimVarDxf# 42) (setvar "DIMEXO"  DimValue))
                      ( (= DimVarDxf# 43) (setvar "DIMDLI"  DimValue))
                      ( (= DimVarDxf# 44) (setvar "DIMEXE"  DimValue))
                      ( (= DimVarDxf# 45) (setvar "DIMRND"  DimValue))
                      ( (= DimVarDxf# 46) (setvar "DIMDLE"  DimValue))
                      ( (= DimVarDxf# 47) (setvar "DIMTP"   DimValue))
                      ( (= DimVarDxf# 48) (setvar "DIMTM"   DimValue))
                      ( (= DimVarDxf# 71) (setvar "DIMTOL"  DimValue))
                      ( (= DimVarDxf# 72) (setvar "DIMLIM"  DimValue))
                      ( (= DimVarDxf# 73) (setvar "DIMTIH"  DimValue))
                      ( (= DimVarDxf# 74) (setvar "DIMTOH"  DimValue))
;                     Ignore suppressing extension lines
;                     ( (= DimVarDxf# 75) (setvar "DIMSE1"  DimValue))
;                     ( (= DimVarDxf# 76) (setvar "DIMSE2"  DimValue))
                      ( (= DimVarDxf# 77) (setvar "DIMTAD"  DimValue))
                      ( (= DimVarDxf# 78) (setvar "DIMZIN"  DimValue))
                      ( (= DimVarDxf# 140)(setvar "DIMTXT"  DimValue))
                      ( (= DimVarDxf# 141)(setvar "DIMCEN"  DimValue))
                      ( (= DimVarDxf# 142)(setvar "DIMTSZ"  DimValue))
                      ( (= DimVarDxf# 143)(setvar "DIMALTF" DimValue))
                      ( (= DimVarDxf# 144)(setvar "DIMLFAC" DimValue))
                      ( (= DimVarDxf# 145)(setvar "DIMTVP"  DimValue))
                      ( (= DimVarDxf# 146)(setvar "DIMTFAC" DimValue))
                      ( (= DimVarDxf# 147)(setvar "DIMGAP"  DimValue))
                      ( (= DimVarDxf# 170)(setvar "DIMALT"  DimValue))
                      ( (= DimVarDxf# 171)(setvar "DIMALTD" DimValue))
                      ( (= DimVarDxf# 172)(setvar "DIMTOFL" DimValue))
                      ( (= DimVarDxf# 173)(setvar "DIMSAH"  DimValue))
                      ( (= DimVarDxf# 174)(setvar "DIMTIX"  DimValue))
                      ( (= DimVarDxf# 175)(setvar "DIMSOXD" DimValue))
                      ( (= DimVarDxf# 176)(setvar "DIMDLRD" DimValue))
                      ( (= DimVarDxf# 177)(setvar "DIMCLRE" DimValue))
                      ( (= DimVarDxf# 178)(setvar "DIMCLRT" DimValue))
                      ( (= DimVarDxf# 270)(setvar "DIMUNIT" DimValue))
                      ( (= DimVarDxf# 271)(setvar "DIMDEC"  DimValue))
                      ( (= DimVarDxf# 272)(setvar "DIMTDEC" DimValue))
                      ( (= DimVarDxf# 273)(setvar "DIMALTU" DimValue))
                      ( (= DimVarDxf# 274)(setvar "DIMALTTD"DimValue))
                      ( (= DimVarDxf# 275)(setvar "DIMAUNIT"DimValue))
                      ( (= DimVarDxf# 280)(setvar "DIMJUST" DimValue))
                      ( (= DimVarDxf# 281)(setvar "DIMSD1"  DimValue))
                      ( (= DimVarDxf# 282)(setvar "DIMSD2"  DimValue))
                      ( (= DimVarDxf# 283)(setvar "DIMTOLJ" DimValue))
                      ( (= DimVarDxf# 284)(setvar "DIMTZIN" DimValue))
                      ( (= DimVarDxf# 285)(setvar "DIMALTZ" DimValue))
                      ( (= DimVarDxf# 286)(setvar "DIMALTTZ"DimValue))
                      ( (= DimVarDxf# 287)(setvar "DIMFIT"  DimValue))
                      ( (= DimVarDxf# 288)(setvar "DIMUPT"  DimValue))
                    );cond
                  );progn
                );if
              );if
            );if
            (setq Num# (+ Num# 2))
          );repeat
        );progn
      );if
      (setq BlkList@ (tblsearch "BLOCK" (cdr (assoc 2 EntList@))))
      (setq BlkEname^ (cdr (assoc -2 BlkList@)))
      (while (setq BlkEname^ (entnext BlkEname^))
        (if BlkEname^
            (setq BlkList@ (entget BlkEname^))
            (if (= (cdr (assoc 0 BlkList@)) "MTEXT")
              (setq StyHeight~ (cdr (assoc 40 BlkList@)))
            );if
          );progn
        );if
      );while
      (if (= StyHeight~ 0)
          (setq StyHeight~ (/ (getvar "dimscale") StyHeight~))
          (setvar "dimtxt" StyHeight~)
        );progn
      );if
      (princ "\n选择尺寸或文本更新:")
      (setq SSet& (ssget
        '((-4 . "<OR")
          (0 . "DIMENSION")(0 . "LEADER")(0 . "MTEXT")(0 . "TEXT")
         (-4 . "OR>")))
      );setq
      (setq Cnt# 0)
      (if SSet&
        (repeat (sslength SSet&)
          (setq EntType$ (cdr (assoc 0 (entget (ssname SSet& Cnt#)))))
          (setq EntName^ (ssname SSet& Cnt#))
          (cond
            ( (= EntType$ "DIMENSION")
              (command ".DIM1" "UP" EntName^ "")
            ( (= EntType$ "LEADER")
              (setq DimTad# (getvar "DIMTAD"))
              (setvar "DIMTAD" 0)
              (setvar "DIMTAD" DimTad#)
            ( (or (= EntType$ "TEXT") (= EntType$ "MTEXT"))
              (setq EntList@ (entget (ssname SSet& Cnt#)))
              (entmod (subst (cons 40 StyHeight~) (assoc 40 EntList@) EntList@))
          );cond
          (cond
              (setq Font$ (cdr (assoc 2 Dimstyle@)))
              (entmod (subst (cons 7 Font$) (assoc 7 EntList@) EntList@))
          );cond
          (setq Cnt# (1+ Cnt#))
        );repeat
      );if
      (redraw EntName1^ 4)
    );progn
    (princ "\n没有选择标注样式!.")
  );if
);defun
 楼主| 发表于 2018-11-11 15:48:21 | 显示全部楼层
找到解决办法不了  这个命令就行了   (DEFUN C:DU ( ) (COMMAND "DIM" "UP")) 虽说只能刷标注,但还是很好用
发表于 2022-4-16 14:52:27 | 显示全部楼层
已解决已解决已解决
发表于 2022-4-27 20:44:21 | 显示全部楼层
已解决已解决已解决
发表于 2023-8-6 18:09:36 | 显示全部楼层
简答代码解决问题
GMT+8, 2025-5-24 10:21 , Processed in 0.175017 second(s), 22 queries , Gzip On.
