楼主: zb1374498780
[经验] 折断线lisp,加载有些情况生成不了。高手帮解决一下呗
 楼主| 发表于 2018-9-28 17:01:34 | 显示全部楼层
菜卷鱼 发表于 2018-9-28 15:28
设置比例试一试??
好像不是比例问题
 楼主| 发表于 2018-9-28 17:27:00 | 显示全部楼层
菜卷鱼 发表于 2018-9-28 15:15
(setq pts (trans pts 1 0))
也许是你差这一句
我那个你能调整一下么,我只需要单条的折断线就行
发表于 2018-9-28 18:04:37 | 显示全部楼层
(defun c:zdx(/ ang p0 p1 p2 p3 p4 p5 p6 sc)
        (setq sc (getint "\n请输入出图比例<100>:"))
        (if (not sc) (setq sc 100))
        (setq p0 (getpoint "\n请选择第一点:"))
        (setq p1 (getpoint p0 "\n请选择第二点:"))
        (setq ang (angle p0 p1))
        (setq p2 (polar p0 ang (/ (distance p0 p1) 2)))
        (setq p3 (polar p2 (+ ang (* pi 0.56)) (* 2.25 sc)))
        (setq p4 (polar p2 (+ ang (* pi 1.56)) (* 2.25 sc)))
        (setq p5 (polar p2 (+ ang pi) (* 1.25 sc)))
        (setq p6 (polar p2 ang (* 1.25 sc)))
        (if (< (distance p0 p1) (* 7.0 sc))
                        (setq p0 (polar p5 (+ ang pi) (* 2.25 sc)))
                        (setq p1 (polar p6 ang (* 2.25 sc)))
                        (setq p0 (polar p0 (+ ang pi) (* 2.25 sc)))
                        (setq p1 (polar p1 ang (* 2.25 sc)))
        (setq os (getvar "osmode"))
  (setvar "osmode" 0)
        (command "PLINE" p0 p5 p3 p4 p6 p1"")
        (setvar "osmode" os)
是不是自定义函数搞错了,直接改成command吧
 楼主| 发表于 2018-9-29 09:31:11 | 显示全部楼层
        (setq sc (getint "\n请输入出图比例:"))
哈哈,谢谢了。解决了
发表于 2024-5-2 16:42:23 | 显示全部楼层
感谢楼主的分享,借用了层主的代码
发表于 2024-5-2 16:44:46 | 显示全部楼层
  1. (defun c:zdx(/ ang p0 p1 p2 p3 p4 p5 p6 sc)
  2.         ;(setq sc (getint "\n请输入出图比例<100>:"))
  3.         ;(if (not sc) (setq sc 100))
  4.         (setq p0 (getpoint "\n请选择第一点:"))
  5.         (setq p1 (getpoint p0 "\n请选择第二点:"))
  6.         (setq sc (/ (distance p0 p1) 27))
  7.         (setq ang (angle p0 p1))
  8.         (setq p2 (polar p0 ang (/ (distance p0 p1) 2)))
  9.         (setq p3 (polar p2 (+ ang (* pi 0.56)) (* 2.25 sc)))
  10.         (setq p4 (polar p2 (+ ang (* pi 1.56)) (* 2.25 sc)))
  11.         (setq p5 (polar p2 (+ ang pi) (* 1.25 sc)))
  12.         (setq p6 (polar p2 ang (* 1.25 sc)))
  13.         (if (< (distance p0 p1) (* 7.0 sc))
  14.                 (progn
  15.                         (setq p0 (polar p5 (+ ang pi) (* 2.25 sc)))
  16.                         (setq p1 (polar p6 ang (* 2.25 sc)))
  17.                 )
  18.                 (progn
  19.                         (setq p0 (polar p0 (+ ang pi) (* 2.25 sc)))
  20.                         (setq p1 (polar p1 ang (* 2.25 sc)))
  21.                 )
  22.         )
  23.         (setq os (getvar "osmode"))
  24.   (setvar "osmode" 0)
  25.         (command "PLINE" p0 p5 p3 p4 p6 p1"")
  26.         (setvar "osmode" os)
  27.   (princ)
  28. )
按照选择两点的距离除一个系数得出折断线的比例,适合自己用,再次感谢楼主的分享
GMT+8, 2025-7-7 14:12 , Processed in 0.185054 second(s), 19 queries , Gzip On.
