查看: 5198|回复: 11
删除绑定参照的图层名字前缀和线型名字前缀
发表于 2018-9-16 03:30:50 | 显示全部楼层 |阅读模式
80明经币
麻烦大侠帮个忙!写个lsp
绑定参照后,把带进的图层名字和线型名字$0$之前前缀全部删掉(图纸说不定被二次参照,名字带有两个或三个$0$)
删除前缀时,如果有名字重合,则可以合并名字,如果不能合并,就在名字后面加个数字,比如1(加数字后,如果还有重合,继续循环运行加数字1,直到不重合)
发表于 2020-2-24 01:01:17 | 显示全部楼层
快捷键  d+  批量图层名称加前缀
全部图层加前缀<除0,Defpoints>
(defun c:d+ ( / YY_QIANZ *doc* LAY LAYERS OLDMING)
(vl-load-com)
(setq YY_QIANZ (getstring "\n输入图层要加的前缀:"))
(if YY_QIANZ
(setq *doc* (vla-get-activedocument (vlax-get-acad-object))
layers (vla-get-layers *doc*))
(vlax-for lay layers (setq OLDMING (vla-get-name lay))
(if (not (member OLDMING '("0" "Defpoints")))
(vla-put-Name lay (strcat YY_QIANZ OLDMING)))))))
快捷键  d-  批量图层名称去前缀
(defun c:d- ()
(if (setq qz (getstring "\n输入图层要删除的前缀: "))
(vlax-for la (vla-get-layers(vla-get-activedocument (vlax-get-acad-object)))
(setq tx (vla-get-name la))
(if (and (not (member tx '("0" "Defpoints")))(vl-string-search qz tx))
(vla-put-Name la (substr tx (1+ (strlen qz)))))))
(princ))
发表于 2020-2-24 07:41:45 | 显示全部楼层
只有简单的去除前缀。
(defun c:RBP(/ ActDoc Name NewName)
; RemoveBindPrefixes
; Renames layers, blocks, dimension styles, text styles, user coordinate systems, and views
; by taking out the bind as bind prefix
; Example Drawing1$0$Layer1 -> Layer1
(vl-load-com)
(defun RemoveBindPrefix (String / Pos LastPos)
(if (setq Pos (vl-string-search "$" String))
(setq LastPos Pos)
(while (setq Pos (vl-string-search "$" String (1+ Pos)))
(setq LastPos Pos)
(substr String (+ 2 LastPos))
String
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vlax-for Obj (vla-get-Layers ActDoc)
(setq Name (vla-get-Name Obj))
(if (/= (setq NewName (RemoveBindPrefix Name)) Name)
(if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Name (list Obj NewName)))
(prompt (strcat "\n Layer: " Name " was not renamed."))
(vlax-for Obj (vla-get-Blocks ActDoc)
(prompt (strcat "\n Block: " Name " was not renamed."))
(vlax-for Obj (vla-get-TextStyles ActDoc)
(prompt (strcat "\n Text style: " Name " was not renamed."))
(vlax-for Obj (vla-get-Views ActDoc)
(prompt (strcat "\n View: " Name " was not renamed."))
(vlax-for Obj (vla-get-UserCoordinateSystems ActDoc)
(prompt (strcat "\n UCS: " Name " was not renamed."))
(vlax-for Obj (vla-get-DimStyles ActDoc)
(prompt (strcat "\n Dimension style: " Name " was not renamed."))
发表于 2020-5-14 19:06:19 | 显示全部楼层
非常好的资料,多谢楼主分享。
发表于 2023-1-6 14:13:18 | 显示全部楼层
终于找到了,试试,感谢
发表于 2023-11-2 14:11:12 | 显示全部楼层
感谢感谢
发表于 2024-6-21 00:43:23 | 显示全部楼层
国外搬运的,有大神能否帮忙修改下:若去除前缀后重名,则进行合并。悬赏20个币.
(defun c:RenBLD ( / aDoc RemoveBindPrefix _taken aDoc name newname)
;;;                Kent Cooper                ;;;
(defun RemoveBindPrefix (String / Pos)
  (if (setq Pos (vl-string-position 36 String nil T)); T = search-from-the-end
    (substr String (+ 2 Pos)); then
    String ; else
  ); if
;;;                pBe                ;;;
(defun _taken        (doc tbl nm i / nme)
          (if (not (vl-catch-all-error-p
                     (vl-catch-all-apply
                       'vla-item
                       (list (vlax-geta doc tbl) (setq nme (strcat nm " (" (itoa i) ")")))
                     ) ;_ end of vl-catch-all-apply
                   ) ;_ end of vl-catch-all-error-p
              ) ;_ end of not
                        (_taken doc tbl nm (1+ i))
            nme))
(setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (foreach item        '("Layers" "DimStyles" "TextStyles" "Blocks" "Linetypes")
    (vlax-for itm (vlax-get aDoc item)
      (cond ((and
               (vl-string-position 36 (setq name (vla-get-name itm)) nil T)
               (setq newname (RemoveBindPrefix name))
               (setq newname
                            (vl-catch-all-apply 'vla-item (list (vlax-get aDoc item) newname))
                        newname
                        (_taken aDoc item newname 2)
                      ) ;_ end of if
               ) ;_ end of setq
               (if (eq item "TextStyles")
                   (setq ent (entget (tblobjname "Style" name)))
                   (entmod (subst (Cons 2 newname) (assoc 2 ent) ent))
                 ) ;_ end of progn
                 (vlax-put itm 'Name newname)
               ) ;_ end of if
             ) ;_ end of and
      ) ;_ end of cond
    ) ;_ end of vlax-for
  ) ;_ end of foreach
发表于 2024-7-1 18:41:57 | 显示全部楼层
感谢作者的分享!
发表于 2024-7-26 09:15:51 | 显示全部楼层
刚好之前写过这个插件,下面是演示视频,你看是你需要的吗?
https://www.toutiao.com/video/73 ... e278e_1721956511515
发表于 2024-8-1 16:12:57 | 显示全部楼层
感谢分享....
GMT+8, 2025-5-1 02:55 , Processed in 0.170461 second(s), 24 queries , Gzip On.
