查看: 1601|回复: 2
VB编写的自动加载arx程序 支持win10 64位系统 修改后可加载lsp net等
发表于 2018-8-22 16:05:52 | 显示全部楼层 |阅读模式
把此程序放到需要加载的arx同目录下,将此程序名称改为arx同样名字(如 Myapp.exe  32位:Myapp.16.arx 64位:Myapp.16.X64.arx  16为arx版本对应的CAD版本号),否则无法加载,点运行即可加载及卸载,
加载后,CAD每次运行都会加载ARX.
注册表读取函数来自zzyong版主,其它部分代码来自网络,在此谢过,代码水平有限,仅限于实现功能。包涵。
源码共享 ,这个代码稍作修改可用于加载net lisp程序,需要有人来继续了哦
部分核心代码,加载部分
  1. Private Sub Command4_Click()
  2. Dim MyAppName As String
  3. MyAppName = App.Title
  4. 'MsgBox App.Path
  5. Dim CurVer As String, cadpath As String, i As Long, Ver As String
  6. For i = 0 To List1.ListCount - 1
  7. If List1.Selected(i) = True Then
  8. Ver = CStr(Cadstr(i))
  9.   Select Case Ver
  10.          Case "16.0", "16.1", "16.2"
  11.
  12.                CurVer = RegQueryStringValue(HKCU32, "Software\Autodesk\AutoCAD\R" & Ver, "CurVer")
  13.                    cadpath = RegQueryStringValue(GetPreferredRoot32, "Software\Autodesk\AutoCAD\R" & Ver & "\" & CurVer, "Location")
  14.                  If Dir(cadpath & "\acad.exe") <> "" Then
  15.
  16.                      PopulateDemandloadKey GetPreferredRoot32, "Software\Autodesk\AutoCAD\R" & Ver & "\" & CurVer & "\Applications", MyAppName & ".ARX." & Int(CDbl(Ver)) & ".arx", Ver
  17.                   End If
  18.
  19.          Case Else:
  20.                 CurVer = RegQueryStringValue(HKCU32, "Software\Autodesk\AutoCAD\R" & Ver, "CurVer")
  21.                    cadpath = RegQueryStringValue(GetPreferredRoot32, "Software\Autodesk\AutoCAD\R" & Ver & "\" & CurVer, "Location")
  22.                  If Dir(cadpath & "\acad.exe") <> "" Then
  23.                  MsgBox cadpath & "1"
  24.                      PopulateDemandloadKey GetPreferredRoot32, "Software\Autodesk\AutoCAD\R" & Ver & "\" & CurVer & "\Applications", MyAppName & ".ARX." & Int(CDbl(Ver)) & ".arx", Ver
  25.                   End If
  26.                   If Is64bit() Then
  27.                   CurVer = RegQueryStringValue(HKCU64, "Software\Autodesk\AutoCAD\R" & Ver, "CurVer")
  28.                    cadpath = RegQueryStringValue(GetPreferredRoot64, "Software\Autodesk\AutoCAD\R" & Ver & "\" & CurVer, "Location")
  29.                  If Dir(cadpath & "\acad.exe") <> "" Then
  30.                  'MsgBox cadpath & "2"
  31.                      PopulateDemandloadKey GetPreferredRoot64, "Software\Autodesk\AutoCAD\R" & Ver & "\" & CurVer & "\Applications", MyAppName & ".ARX." & Int(CDbl(Ver)) & ".X64.arx", Ver
  32.                   End If
  33.                   End If
  34.
  35.
  36.
  37.   End Select
  38. End If
  39. Next
  40. End Sub
“win10 WIN7 WIN8"需用管理员权限运行
源码
 楼主| 发表于 2018-8-22 20:14:09 | 显示全部楼层
自己顶一下吧,期待有人能改改支持加载 lsp vlx 添加支持路径等
发表于 2018-8-23 12:42:44 | 显示全部楼层
我以前有过一个实时加载lsp等程序,不过不是设成自动加载,cad自动加载太多插件,启动时或打开图时会很慢!
http://bbs.mjtd.com/thread-111114-1-1.html
GMT+8, 2025-5-25 20:11 , Processed in 0.194911 second(s), 24 queries , Gzip On.
