帖子
查看: 1889|回复: 4
怎么修改字体
发表于 2018-7-31 18:34:05 | 显示全部楼层 |阅读模式
为什么这样修改标注样式字体是不行的,该怎么修改??
  1. Private Sub Form_Load()
  2. Dim newText As Object
  3. Dim ys As Object,n&
  4. On Error Resume Next
  5. Set acadApp = GetObject(, "AutoCAD.Application")
  6. If Err Then
  7.     Err.Clear
  8.     Set acadApp = CreateObject("AutoCAD.Application")
  9.     If Err Then End
  10. Else
  11.     Set acadDoc = acadApp.Documents.Add
  12. End If
  13. acadApp.Visible = True
  14. n = acadApp.Documents.Count
  15. Set acadDoc = acadApp.Documents(n - 1)
  16. Set ys = acadDoc.ActiveDimStyle
  17. Set newText = acadDoc.TextStyles
  18. newText.Item(1).Name = "宋体"
  19. End Sub
发表于 2018-8-3 13:21:42 | 显示全部楼层
试试这样行不行
 楼主| 发表于 2018-8-3 17:34:19 | 显示全部楼层
谢谢,已解决,引用@zzyong00的办法
cad用单线字体好一点,字多也速度快
'创建新的字体样式
Public Sub NewTextStyle2()   '创建新的字体样式,gbenor.SHX gbcbig.SHX 字体
    On Error GoTo err1
    Dim lkxtextstyle As AcadTextStyle
    Set lkxtextstyle = ThisDrawing.TextStyles.Add("ZZY_2")
    With lkxtextstyle
        .fontFile = "gbenor.SHX"
        .BigFontFile = "gbcbig.SHX"
        .Width = 0.85
    End With
    Exit Sub
err1:
    Err.Clear
    Resume Next
End Sub
发表于 2018-8-8 13:17:25 | 显示全部楼层
下载试试,谢谢源码!
GMT+8, 2025-6-15 07:47 , Processed in 0.155962 second(s), 23 queries , Gzip On.
