- 积分
- 991
- 明经币
- 个
- 注册时间
- 2016-9-26
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
Jig不好用,界面一直闪,自己写个玩玩,请前辈们指点一下,代码不够严谨
[CommandMethod("DrawPolyline")]
public void DrawPolyline()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
DocumentLock dlock = doc.LockDocument();
//为临时图形得到当前的颜色
Autodesk.AutoCAD.Colors.Color col = doc.Database.Cecolor;
//创建一个点集来存储顶点
Point3dCollection pts = new Point3dCollection();
//为所有的顶点设置选择选项
PromptPointOptions opt = new PromptPointOptions("\n设置线段起点或者取消[Undo]", "Undo");
//存储临时线段
List<ObjectId> lines = new List<ObjectId>();
opt.AllowNone = true;
//得到的 polyline 第一点
PromptPointResult res = ed.GetPoint(opt);
while (res.Status == PromptStatus.OK || res.Status == PromptStatus.Keyword)//有点被选中时的操作
pts.Add(res.Value);
if (pts.Count > 1)
using (Transaction tran = db.TransactionManager.StartTransaction())
BlockTableRecord btrs = (BlockTableRecord)tran.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
Line line = new Line(pts[pts.Count - 2], pts[pts.Count - 1]);
lines.Add(btrs.AppendEntity(line));
tran.AddNewlyCreatedDBObject(line, true);
tran.Commit();
//撤销的时候从这里重新进入循环
undo:
opt.BasePoint = pts[pts.Count - 1];
opt.UseBasePoint = true;
opt.SetMessageAndKeywords("\n设置线段顶点或者取消[Undo]", "Undo");
if (res.Status == PromptStatus.Keyword)
if (res.StringResult.ToLower() == "undo")
if (lines.Count > 0)
lines[lines.Count - 1].GetObject(OpenMode.ForWrite).Erase(true);
lines.RemoveAt(lines.Count - 1);
tran.Commit();
pts.RemoveAt(pts.Count - 1);
goto undo;
if (pts.Count == 1)
goto undo;
else if (res.Status != PromptStatus.OK)
break;
if (pts.Count >= 1)
using (Transaction tr = db.TransactionManager.StartTransaction())
//获取当前的模型/图纸空间
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
//得到当前的 UCS
Matrix3d ucs = ed.CurrentUserCoordinateSystem;
Point3d origin = new Point3d(0, 0, 0);
Vector3d normal = Vector3d.ZAxis;
//创建一个临时的 plane 来帮助计算
Plane plane = new Plane(origin, normal);
//创建 polyline,同时用已经选择的点的数量来指定顶点数
Polyline pline = new Polyline(pts.Count);
pline.Normal = normal;
foreach (Point3d pt in pts)//对点进行坐标转换,为什么要转换,UCS与 OCS的关系?
Point3d transformedPt = pt.TransformBy(ucs);
pline.AddVertexAt(pline.NumberOfVertices, plane.ParameterOf(transformedPt), 0, 0, 0);
ObjectId plineId = btr.AppendEntity(pline);
tr.AddNewlyCreatedDBObject(pline, true);
//将临时线段从数据库中删除
foreach (var item in lines)
item.GetObject(OpenMode.ForWrite).Erase(true);
tr.Commit();
dlock.Dispose();
