查看: 817|回复: 1
Building debug version of curveText.dbx to be used with non-debug/Prod AutoCAD
发表于 2018-7-1 00:14:05 | 显示全部楼层 |阅读模式
“Building debug version of curveText.dbx to be used with non-debug/Prod AutoCAD“会是什么原因?
 楼主| 发表于 2018-7-1 00:24:57 | 显示全部楼层
//自动菜单
// This use COM by itself (without MFC), to access
// the AutoCAD ActiveX Automation APIs. from sample <AsdkPlainComSamp.cpp>
#include "stdafx.h"
#include <rxregsvc.h>
#include <aced.h>
#include <adslib.h>
#include "tchar.h"
#include "WinRegister.h"
#ifdef CAD2008
#import "C:\\ObjectARX_2008\\inc\\acax17ENU.tlb" no_implementation raw_interfaces_only named_guids
#endif
#ifdef CAD2007
#import "C:\\ObjectARX_2007\\inc\\acax17ENU.tlb" no_implementation raw_interfaces_only named_guids
#endif
#ifdef CAD2006
#import "C:\\ObjectARX_2006\\inc\\acax16ENU.tlb" no_implementation raw_interfaces_only named_guids
#endif
#ifdef CAD2004
#import "C:\\ObjectARX_2004\\inc\\acax16ENU.tlb" no_implementation raw_interfaces_only named_guids
#endif
#ifdef CAD2010
#ifdef X64
#import "C:\\ObjectARX_2010\\inc-X64\\acax18ENU.tlb" no_implementation raw_interfaces_only named_guids
#else
#import "C:\\ObjectARX_2010\\inc-win32\\acax18ENU.tlb" no_implementation raw_interfaces_only named_guids
#endif
#endif
#ifdef CAD2012
#ifdef X64
#import "C:\\ObjectARX_2012\\inc-X64\\acax18ENU.tlb" no_implementation raw_interfaces_only named_guids
#else
#import "C:\\ObjectARX_2012\\inc-win32\\acax18ENU.tlb" no_implementation raw_interfaces_only named_guids
#endif
#endif
#ifdef CAD2013
#ifdef X64
#import "C:\\ObjectARX_2013\\inc-X64\\acax19ENU.tlb" no_implementation raw_interfaces_only named_guids
#else
#import "C:\\ObjectARX_2013\\inc-win32\\acax19ENU.tlb" no_implementation raw_interfaces_only named_guids
#endif
#endif
static bool bIsMenuLoaded = false;
void addMenuThroughCom()
    AutoCAD::IAcadApplication *pAcad;
    AutoCAD::IAcadMenuBar *pMenuBar;
    AutoCAD::IAcadMenuGroups *pMenuGroups;
    AutoCAD::IAcadMenuGroup *pMenuGroup;
    AutoCAD::IAcadPopupMenus *pPopUpMenus;
    AutoCAD::IAcadPopupMenu *pPopUpMenu;
    AutoCAD::IAcadPopupMenuItem *pPopUpMenuItem;
        int indexMenu = 0;
#ifdef CAD2004
    HRESULT hr = NOERROR;
    CLSID clsid;
    LPUNKNOWN pUnk = NULL;
    LPDISPATCH pAcadDisp = NULL;
    hr = ::CLSIDFromProgID(L"AutoCAD.Application", &clsid);
    if (FAILED(hr))
                return;
    if(::GetActiveObject(clsid, NULL, &pUnk) != S_OK)
                return;
    hr = pUnk->QueryInterface(IID_IDispatch, (LPVOID*) &pAcadDisp);
    pUnk->Release();
        if (FAILED(hr))
        return;
#else
        LPDISPATCH pAcadDisp = acedGetIDispatch(TRUE);
        if(pAcadDisp==NULL)
                return;
#endif
        hr = pAcadDisp->QueryInterface(AutoCAD::IID_IAcadApplication,(void**)&pAcad);
    pAcadDisp->Release();
        if (FAILED(hr))
        return;
    pAcad->put_Visible(true);
        pAcad->get_MenuBar(&pMenuBar);
    pAcad->get_MenuGroups(&pMenuGroups);
    pAcad->Release();
    long numberOfMenus;
    pMenuBar->get_Count(&numberOfMenus);
    pMenuBar->Release();
    VARIANT index;
    VariantInit(&index);
    V_VT(&index) = VT_I4;
    V_I4(&index) = 0;
    pMenuGroups->Item(index, &pMenuGroup);
    pMenuGroups->Release();
    pMenuGroup->get_Menus(&pPopUpMenus);
    pMenuGroup->Release();
    WCHAR wstrMenuName[256];
        #ifdef UNICODE
                if(Global_ChineseVersion)
                        _tcscpy(wstrMenuName, L"二维码");
                else
                        _tcscpy(wstrMenuName, L"QRCode");
    #else
                        MultiByteToWideChar(CP_ACP, 0, "二维码", -1, wstrMenuName, 256);
                else
                        MultiByteToWideChar(CP_ACP, 0, "QRCode", -1, wstrMenuName, 256);
        #endif // !UNICODE
    // Enables the menu to be loaded/unloaded with the same command.
    if (!bIsMenuLoaded) {
        pPopUpMenus->Add(wstrMenuName, &pPopUpMenu);
        if (pPopUpMenu != NULL) {
            WCHAR wstrMenuItemName[256];
                        WCHAR wstrMenuItemMacro[256];
                        #ifdef UNICODE
                                        _tcscpy(wstrMenuItemName, L"绘制二维码");
                                else
                                        _tcscpy(wstrMenuItemName, L"Draw QRCode");
                _tcscpy(wstrMenuItemMacro, L"CADQR ");
            #else  // !UNICODE
                                        MultiByteToWideChar(CP_ACP, 0, "绘制二维码", -1, wstrMenuItemName, 256);
                                else
                                        MultiByteToWideChar(CP_ACP, 0, "Draw QRCode", -1, wstrMenuItemName, 256);
                                MultiByteToWideChar(CP_ACP, 0, "CADQR ", -1, wstrMenuItemMacro, 256);
                        #endif // !UNICODE
            V_I4(&index) = indexMenu;  indexMenu++;
            pPopUpMenu->AddMenuItem(index, wstrMenuItemName, wstrMenuItemMacro, &pPopUpMenuItem);
                        #ifdef UNICODE
                _tcscpy(wstrMenuItemName, L"www.SummerCAD.com");
                _tcscpy(wstrMenuItemMacro, L"gotoSummerCAD ");
            #else  // !UNICODE
                                MultiByteToWideChar(CP_ACP, 0, "www.SummerCAD.com", -1, wstrMenuItemName, 256);
                                MultiByteToWideChar(CP_ACP, 0, "gotoSummerCAD ", -1, wstrMenuItemMacro, 256);
                        #endif // !UNICODE
            V_I4(&index) = numberOfMenus - 2;
            pPopUpMenu->InsertInMenuBar(index);
            pPopUpMenuItem->Release();
            bIsMenuLoaded = true;
        } else {
            acutPrintf(_T("\nMenu not created."));
    } else {
        V_VT(&index) = VT_BSTR;
        V_BSTR(&index) = wstrMenuName;
        pPopUpMenus->RemoveMenuFromMenuBar(index);
        VariantClear(&index);
    pPopUpMenus->Release();
void setExpertMode()
        TCHAR reply[256];
        _tcscpy(reply, _T("Yes"));
        acedInitGet(NULL, _T("Yes No"));
        int res;
                res = acedGetKword(_T("\n启用专家模式菜单(Y/N)[Y]:"), reply);
        else
                res = acedGetKword(_T("\nUsing Expert Mode(Y/N)[Y]:"), reply);
        if (res == RTNONE || reply[0] == _T('Y'))
                RegPutInt(HKEY_CURRENT_USER,_T("Software\\SummerCAD\\SDWM"), _T("ExpertMode"), 1);
        }else{
                RegPutInt(HKEY_CURRENT_USER,_T("Software\\SummerCAD\\SDWM"), _T("ExpertMode"), 0);
        acutPrintf(_T("\n重新启动AutoCAD后生效。"));
输出窗口
                 正在编译...
acrxEntryPoint.cpp
WINVER not defined. Defaulting to 0x0502 (Windows Server 2003)
AutoMenu.cpp
***\automenu.cpp(59) : error C2653: “AutoCAD”: 不是类或命名空间名称
***\automenu.cpp(59) : error C2065: “IAcadApplication”: 未声明的标识符
***\automenu.cpp(59) : error C2065: “pAcad”: 未声明的标识符
***\automenu.cpp(60) : error C2653: “AutoCAD”: 不是类或命名空间名称
***\automenu.cpp(60) : error C2065: “IAcadMenuBar”: 未声明的标识符
***\automenu.cpp(60) : error C2065: “pMenuBar”: 未声明的标识符
***\automenu.cpp(61) : error C2653: “AutoCAD”: 不是类或命名空间名称
***\automenu.cpp(61) : error C2065: “IAcadMenuGroups”: 未声明的标识符
***\automenu.cpp(61) : error C2065: “pMenuGroups”: 未声明的标识符
***\automenu.cpp(62) : error C2653: “AutoCAD”: 不是类或命名空间名称
***\automenu.cpp(62) : error C2065: “IAcadMenuGroup”: 未声明的标识符
***\automenu.cpp(62) : error C2065: “pMenuGroup”: 未声明的标识符
***\automenu.cpp(63) : error C2653: “AutoCAD”: 不是类或命名空间名称
***\automenu.cpp(63) : error C2065: “IAcadPopupMenus”: 未声明的标识符
***\automenu.cpp(63) : error C2065: “pPopUpMenus”: 未声明的标识符
***\automenu.cpp(64) : error C2653: “AutoCAD”: 不是类或命名空间名称
***\automenu.cpp(64) : error C2065: “IAcadPopupMenu”: 未声明的标识符
***\automenu.cpp(64) : error C2065: “pPopUpMenu”: 未声明的标识符
***\automenu.cpp(65) : error C2653: “AutoCAD”: 不是类或命名空间名称
***\automenu.cpp(65) : error C2065: “IAcadPopupMenuItem”: 未声明的标识符
***\automenu.cpp(65) : error C2065: “pPopUpMenuItem”: 未声明的标识符
崩溃啦
GMT+8, 2025-5-1 08:11 , Processed in 0.151735 second(s), 24 queries , Gzip On.
