查看: 5808|回复: 18
[提问] BOUNDARY用弧岛的办法太卡了
发表于 2018-6-9 21:34:19 | 显示全部楼层 |阅读模式
图中的效果怎么才能实现,不用BOUNDARY太卡了,这样做就算不是封闭区域也可以得到一个矩形
能写一个我学习下么?
飞鱼StrawHaat + 1 看你没币了,送你10个币,动态处理的lisp程.
发表于 2018-6-15 16:33:12 | 显示全部楼层
  1. ;;动态框绘制 By 明经通道 Gu_xl
  2. (defun c:DynRect (/               GR         GetScreenCoords
  3.              LL               LMTS         LOOP           LU             P1
  4.              P2               P3         P4           PT             RL
  5.              RU               S1         S2           S3             S4
  6.             )
  7.   ;;取得当前绘图区屏幕的左下角和右上角的坐标
  8.   (defun GetScreenCoords
  9.          (/ c03 c08 c04 c05 c07 c06 c09 c01 c02)
  10.     (setq c03 (getvar "viewctr")
  11.           c03 (trans c03 1 2)
  12.           c08 (getvar "viewsize")
  13.           c04 (getvar "screensize")
  14.           c07 (car c04)
  15.           c06 (cadr c04)
  16.           c09 (/ (* c08 c07) c06)
  17.           c01 (list (- (car c03) (* 0.5 c09)) (- (cadr c03) (* 0.5 c08)))
  18.           c02 (list (+ (car c03) (* 0.5 c09)) (+ (cadr c03) (* 0.5 c08)))
  19.           c01 (trans c01 2 1)
  20.           c02 (trans c02 2 1)
  21.     )
  22.     (list c01 c02)
  23.   )
  24.   (setq loop t)
  25.   (while loop
  26.     (setq lmts (GetScreenCoords))
  27.     (setq gr (grread t 15 0))
  28.     (cond ((= 5 (car gr))
  29.            (setq pt (cadr gr))
  30.            (if (and
  31.                  (setq s1 (ssget "F"
  32.                                  (list pt (list (car pt) (cadadr lmts) 0))
  33.                                  '((0 . "*line,arc,circle"))
  34.                           )
  35.                  ) ;_ 向上
  36.                  (setq s2 (ssget "F"
  37.                                  (list pt (list (car pt) (cadar lmts) 0))
  38.                                  '((0 . "*line,arc,circle"))
  39.                           )
  40.                  ) ;_ 向下
  41.                  (setq s3 (ssget "F"
  42.                                  (list pt (list (caar lmts) (cadr pt) 0))
  43.                                  '((0 . "*line,arc,circle"))
  44.                           )
  45.                  ) ;_ 向左
  46.                  (setq s4 (ssget "F"
  47.                                  (list pt (list (caadr lmts) (cadr pt) 0))
  48.                                  '((0 . "*line,arc,circle"))
  49.                           )
  50.                  ) ;_ 向右
  51.                )
  52.              (progn
  53.                (setq p1 (trans (cadar (cdddar (ssnamex s1))) 0 1)) ;_ 上点
  54.                (setq p2 (trans (cadar (cdddar (ssnamex s2))) 0 1)) ;_ 下点
  55.                (setq p3 (trans (cadar (cdddar (ssnamex s3))) 0 1)) ;_ 左点
  56.                (setq p4 (trans (cadar (cdddar (ssnamex s4))) 0 1)) ;_ 右点
  57.                (setq ll (apply 'mapcar (cons 'min (list p1 p2 p3 p4)))) ;_ 左下角点
  58.                (setq ru (apply 'mapcar (cons 'max (list p1 p2 p3 p4)))) ;_ 右上角点
  59.                (setq lu (list (car ll) (cadr ru) 0)) ;_ 左上角点
  60.                (setq rl (list (car ru) (cadr ll) 0)) ;_ 右下角点
  61.                (redraw)
  62.                (grdraw ll lu 1)
  63.                (grdraw lu ru 1)
  64.                (grdraw ru rl 1)
  65.                (grdraw rl ll 1)
  66.              )
  67.              (redraw)
  68.            )
  69.           )
  70.           ((= 3 (car gr))
  71.            (setq loop nil)
  72.            (command "_rectang" "_non" ll "_non" ru)
  73.           )
  74.     )
  75.   )
  76.   (redraw)
  77.   (princ)
  78. )
和顾神的差距,看来只剩一个好想法和一个 ssnamex 函数了。  发表于 2018-6-16 22:59
taoyi0727 + 1 谢G版的回复,明明用ssget里有选arc,有的ar.
回复 支持 4 反对 0
发表于 2018-6-16 23:36:43 | 显示全部楼层
taoyi0727 发表于 2018-6-14 16:28
用这个方法  还是比用BOUNDARY弧岛的办法  快很多
思路是看的海龙工具里的,主要函数来自明经,我就是个DI ...
上面G版的回复接近于完美答案了,我上传的附件作用仅仅在于精简了你原来的代码而已,不值一哂。
ssget构建的选择集中图元的顺序和图元对象被拾取、选择的顺序相关,因此,不管是栏选(F)还是窗交(C),只要选择的顺序是从光标处至视图边框,该选择集中的第一个图元就是选择集所有图元中距光标最近的,所以,如果通过求交点的方法,只需要求得该图元和光标处直线的交点即可,没必要求得所有交点再进行比较。
 楼主| 发表于 2018-6-11 09:31:05 | 显示全部楼层
自己琢磨出来了 但是不会高级函数,都是一般的函数堆出来的,代码好长,大神们都帮我改改吗?
有一个函数是的 HH:TwoEntsInters 两对象交点列表
有一个函数不知道是谁的了 fp 屏幕两对角坐标
大神们都帮我改改
飞鱼StrawHaat + 1
发表于 2018-6-14 13:10:19 | 显示全部楼层
评分的评论有字数限制,lisp动态处理的思路建议你去 Lee Mac 的个人网站 http://www.lee-mac.com 学习
发表于 2018-6-14 13:11:34 | 显示全部楼层
明经币每次只能送一个,给你送10次吧。
 楼主| 发表于 2018-6-14 13:41:22 | 显示全部楼层
飞鱼StrawHaat 发表于 2018-6-14 13:11
明经币每次只能送一个,给你送10次吧。
主要是英文不会 就只认识字母 看那些英文网站有难度
我后面又修改了下  不会出现错误
但是新的问题又来了  用这种方法只能找到Z轴在0上的交点 有好多图Z轴不是在0上,只是无限接近z轴0位,每次打开文件都先全图Z轴归0的话,这个程序就不通用了
有没有投影找交点的办法,或着好点的思路
飞鱼StrawHaat + 1
 楼主| 发表于 2018-6-14 14:01:19 | 显示全部楼层
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=79868
8楼的代码可以解决这个问题
他的方法是复制出1个一个的实体,把这个实体Z归0,再求交点,然后删除实体
刚试了下  问题又绕回来了 用这个图多在卡爆了
 楼主| 发表于 2018-6-14 16:28:23 | 显示全部楼层
思路是看的海龙工具里的,主要函数来自明经,我就是个DIY小能手
谢谢 飞鱼StrawHaat 的支持
不知道为什么我发的贴没什么人理,哎~,没难度?还是太难?可能是太忙
有大神给优化一下就好了
飞鱼StrawHaat + 1
 楼主| 发表于 2018-6-15 17:40:21 | 显示全部楼层
谢G版的回复,明明用ssget里有选arc,有的arc就找不到点
 楼主| 发表于 2018-6-15 17:53:55 | 显示全部楼层
找到原因了
把    '((0 . "*line,arc.circle"))
改成'((0 . "*line,arc,circle"))
GMT+8, 2025-12-12 06:52 , Processed in 0.157005 second(s), 30 queries , Gzip On.
