查看: 1652|回复: 9
请高手帮忙修改程序:能否改成选定多段线或圆内的图形进行删除或移动或复制
发表于 2018-6-8 20:17:51 | 显示全部楼层 |阅读模式
(defun C:WPS ( / i elist at cmde cen rad p1)
(setq cmde (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq i 0 elist (entget (car (entsel "\nPick a circle or polyline: "))))
(setvar "OSMODE" (boole 7 (getvar "OSMODE") 16384))
(if (zerop (getvar "CMDACTIVE")) (command "_select"))
(command "_wp") ; or _CP
(if (= (cdr(assoc 0 elist)) "CIRCLE")
  (setq cen (cdr (assoc 10 elist))
        rad (cdr (assoc 40 elist))
  (repeat 90 ; 360/4  0.06981317=4*pi/180
   (setq p1 (polar cen (* i 0.06981317) rad)  i (1+ i))
;   (command "_POINT" (trans p1 0 1))
   (command (trans p1 0 1))
  )); else
  (repeat (length elist)
   (setq at (nth i elist) i (1+ i))
;   (if (= (car at) 10) (command (cdr at)))
   (if (= (car at) 10) (command (trans (cdr at) 0 1)))
);if CIRCLE
(command "")
(setvar "OSMODE" (boole 2 (getvar "OSMODE") 16384))
(setvar "cmdecho" cmde)
发表于 2018-6-9 09:55:33 | 显示全部楼层
Command: wps
Select objects:
Command: m
MOVE
Select objects: p
 楼主| 发表于 2018-6-9 11:08:44 | 显示全部楼层
你好!能完整的lap上传吗?
发表于 2018-6-9 11:42:09 | 显示全部楼层
您可能会与程序互动的的架构!?
如何运作较有效率,请举实例
 楼主| 发表于 2018-6-9 11:58:57 | 显示全部楼层
举例文件,将蓝色范围多段线内的点、数字、图形等进行删除或移动或复制。此图举例多段线里为点和数字,如果要有其它图形也一样
 楼主| 发表于 2018-6-9 12:00:43 | 显示全部楼层
一次性选择一条或无数条多段线或圆
发表于 2018-6-9 12:51:28 | 显示全部楼层
Command: wps
Select objects:  选了右下的 LwPolyline
Command: e
ERASE
Select objects: p
746 found
Select objects:
如上执行
您的想法又是如何!?
发表于 2018-7-16 11:52:56 | 显示全部楼层
CAD小帮手技术交流群1: 115604002  (视频和原图档请在群文件下载)
CAD小帮手技术交流群2: 618984401  (视频和原图档请在群文件下载)
发表于 2018-10-4 10:47:22 | 显示全部楼层
同求,请大神关注!!!论坛找了个圆内选择的!求矩形或者多边形选择的!
发表于 2025-2-25 04:14:19 | 显示全部楼层
谢谢大师分享
GMT+8, 2025-5-1 02:21 , Processed in 0.187141 second(s), 28 queries , Gzip On.
