查看: 1698|回复: 1
王伟,删除图层251内容
发表于 2018-6-6 17:34:59 | 显示全部楼层 |阅读模式
  1. (defun qf_getFolder (msg / WinShell shFolder path catchit)
  2.   (vl-load-com)
  3.   (setq winshell (vlax-create-object "Shell.Application"))
  4.   (setq shFolder (vlax-invoke-method WinShell 'BrowseForFolder 0 msg 1))
  5.   (setq
  6.     catchit (vl-catch-all-apply
  7.           '(lambda ()
  8.          (setq shFolder (vlax-get-property shFolder 'self))
  9.          (setq path (vlax-get-property shFolder 'path))
  10.            )
  11.         )
  12.   )
  13.   (if (vl-catch-all-error-p catchit)
  14.     nil
  15.     path
  16.   )
  17. )
  18. ;|函数功能: 获取目录下(包含子目录)里的某类型文件
  19. ;使用格式: a为路径名或多个路劲名表,b为扩展名
  20. ;范    例: (n5-get-files "D:" "lsp"),搜索d盘中所有lsp文件|;
  21. ;(setq c(n5-get-files b "dat"))
  22. ;(vl-file-directory-p b)返回T
  23. ;2016-6-11
  24. ;095
  25. (defun n5-get-files(a b / lst mulu wj x )
  26.   (setq lst '())
  27. (cond
  28. ((= (type a)'STR)
  29.   (if (setq wj (mapcar '(lambda(x)(strcat a "\" x))(vl-directory-files a (strcat"*." b))))
  30.       (setq lst (cons wj lst)))
  31.   (if (setq mulu (mapcar '(lambda(x)(strcat a "\" x))(cddr(vl-directory-files a nil -1))))
  32.     (foreach x mulu(setq lst(cons(n5-get-files x b) lst)))
  33.       )
  34. )
  35. ((= (type a) 'list) (foreach x a (setq lst (cons(n5-get-files x b)lst))))
  36. )
  37.     (reverse(apply 'append lst))
  38. )
  39. (defun lst-(l1 l2)(if l2(foreach x l2(setq l1(vl-remove x l1)))l1))
  40. (defun c:tt(/ fp *DBX* COLORLST DBX DOC FILENAME FILENAME1 FILES LAY LAYLST LAYLSTS LAYNAMELST LAYNAMELSTS LAYS MSP NAMELST PATH SUBOBJ)
  41. (setq *dbx* (strcat "ObjectDBX.AxDbDocument."(substr (getvar "acadver") 1 2)))
  42. (setq colorlst(list 251 252));要保留的颜色列表
  43. (setq path(QF_GETFOLDER"选择文件夹"))
  44. (setq files(N5-GET-FILES path "dwg"))
  45.   (setq fp(open "c:\\你微笑时很美.txt" "w"))
  46. (foreach file files
  47.   (write-line (strcat "当前:"file))
  48.   (setq filename(VL-FILENAME-MKTEMP nil nil ".dwg"))
  49.   (vl-file-copy file filename)
  50.   (setq dbx(vlax-get-or-create-object *dbx*))
  51.   (vla-open dbx filename)
  52.   (setq msp(vla-get-ModelSpace dbx))
  53.   (setq doc(vlax-get msp 'Document))
  54.   (setq lays(vla-get-layers doc))
  55.   (setq laylst nil laylsts laylst)
  56.   (vlax-for lay lays
  57.    (if (apply'or(mapcar(function(lambda(x)(= x (vla-get-color lay))))colorlst))
  58.   (setq laylst(cons lay laylst))
  59.   (if (= "0" (vla-get-name lay))(setq laylst(cons lay laylst))))
  60.    (setq laylsts(cons lay laylsts)))
  61.   (setq laynamelsts(mapcar'vla-get-name laylsts));全图层名字
  62.   (setq namelst(mapcar'vla-get-name laylst));要保留的图层的名字
  63.   (setq laynamelst(lst- laynamelsts namelst));要删除的图层的名字
  64.   (vlax-for  subobj msp
  65.    (if (apply'or(mapcar(function(lambda(x)(= x (vla-get-layer subobj))))laynamelst))
  66.   (vla-delete subobj)));删除图层上的图形
  67. ;;;  (mapcar'vla-delete (lst- laylsts laylst));删除图层
  68.    (foreach x (lst- laylsts laylst)
  69.      (if(vl-catch-all-error-p(vl-catch-all-apply 'vla-delete (list x)))
  70.    (write-line (strcat file "  "(vla-get-name x) "图层,删除失败")fp)
  71.        )
  72.      )
  73.   (setq filename1(VL-FILENAME-MKTEMP nil nil ".dwg"))
  74.   (vlax-invoke dbx 'saveas filename1)
  75.   (vlax-release-object dbx)
  76.
  77.   (vl-file-delete file)
  78.   (vl-file-copy filename1 file)
  79.   (vl-file-delete filename1)
  80.   )
  81.   (close fp)
  82.   (startapp"notepad" "c:\\你微笑时很美.txt")
  83. (princ)
  84. )
GMT+8, 2025-5-1 05:44 , Processed in 0.160004 second(s), 28 queries , Gzip On.
