查看: 1525|回复: 1
王伟让我写的简单打印
发表于 2018-6-6 17:23:37 | 显示全部楼层 |阅读模式
  1. (defun qf_getFolder (msg / WinShell shFolder path catchit)
  2.   (vl-load-com)
  3.   (setq winshell (vlax-create-object "Shell.Application"))
  4.   (setq shFolder (vlax-invoke-method WinShell 'BrowseForFolder 0 msg 1))
  5.   (setq
  6.     catchit (vl-catch-all-apply
  7.           '(lambda ()
  8.          (setq shFolder (vlax-get-property shFolder 'self))
  9.          (setq path (vlax-get-property shFolder 'path))
  10.            )
  11.         )
  12.   )
  13.   (if (vl-catch-all-error-p catchit)
  14.     nil
  15.     path
  16.   )
  17. )
  18. ;|函数功能: 获取目录下(包含子目录)里的某类型文件
  19. ;使用格式: a为路径名或多个路劲名表,b为扩展名
  20. ;范    例: (n5-get-files "D:" "lsp"),搜索d盘中所有lsp文件|;
  21. ;(setq c(n5-get-files b "dat"))
  22. ;(vl-file-directory-p b)返回T
  23. ;2016-6-11
  24. ;095
  25. (defun n5-get-files(a b / lst mulu wj x )
  26.   (setq lst '())
  27. (cond
  28. ((= (type a)'STR)
  29.   (if (setq wj (mapcar '(lambda(x)(strcat a "\" x))(vl-directory-files a (strcat"*." b))))
  30.       (setq lst (cons wj lst)))
  31.   (if (setq mulu (mapcar '(lambda(x)(strcat a "\" x))(cddr(vl-directory-files a nil -1))))
  32.     (foreach x mulu(setq lst(cons(n5-get-files x b) lst)))
  33.       )
  34. )
  35. ((= (type a) 'list) (foreach x a (setq lst (cons(n5-get-files x b)lst))))
  36. )
  37.     (reverse(apply 'append lst)))
  38. ;
  39. (defun c:tt(/ FILES PATH)
  40.   (setq path(QF_GETFOLDER"选择要打印的文件夹:"))
  41.   (setq files(N5-GET-FILES path"dwg"))
  42.   (foreach file files
  43.     (write-line (strcat"正在打印文件的名为:"file))
  44.     (vla-InsertBlock
  45.       (vla-get-modelspace(vla-get-ActiveDocument(vlax-get-acad-object)))
  46.       (vlax-3d-point '(0 0 0))
  47.       file
  48.       1
  49.       1
  50.       1
  51.       0
  52.       )
  53.     (command"zoom" "e")
  54.     (COMMAND"_plot"
  55.       "N" ""
  56.       "jiangcan" ""
  57.       "N" "N" "Y")
  58.     (entdel (entlast)))
  59.   (prompt"打印结束")
  60.   (PRINC)
  61.   )
批量打印程序使用说明
[size=10.5000pt]1. [size=10.5000pt]打开[size=10.5000pt]AutoCAD[size=10.5000pt]软件cass也是一样的。
[size=10.5000pt]2. [size=10.5000pt]确保[size=10.5000pt]CAD[size=10.5000pt]中没有任何图元
[size=10.5000pt]3. [size=10.5000pt]输入命令p[size=10.5000pt]lot[size=10.5000pt],在打印界面设置各项打印属性,
[size=10.5000pt]4. [size=10.5000pt]设置好各属性之后,点击添加[size=10.5000pt],新面设置名为[size=10.5000pt]”jiangcan”[size=10.5000pt],必须。然后点确定。
[size=10.5000pt]5. [size=10.5000pt]出现这个界面,页面设置名称为[size=10.5000pt]”jiangcan”,[size=10.5000pt]各项属性都正确,可以返回主界面了
[size=10.5000pt]6. [size=10.5000pt]Appload[size=10.5000pt]加载此插件,输入命令t[size=10.5000pt]t,[size=10.5000pt]选择要打印的D[size=10.5000pt]WG[size=10.5000pt]文件所在的文件夹,程序自动打印
[size=10.5000pt]
USER2128 + 1 赞一个!
GMT+8, 2025-5-1 11:07 , Processed in 0.188510 second(s), 28 queries , Gzip On.
