查看: 1058|回复: 1
WPF应用Binding之MultiBinding
发表于 2018-5-8 22:37:43 | 显示全部楼层 |阅读模式
本文引用地址:https://blog.csdn.net/lh806732/article/details/38679043
有时目标绑定多个源的数据,此时需要使用多路绑定MultiBinding。
本例4个TextBox(textBox1, textBox2, textBox3, textBox4)及一个按钮,当textBox1与textBox2内容相同,并且textBox3与textBox4内容相同时,Button有效。
一、方式一(通过C#进行绑定)
  1. <Grid>
  2.     <StackPanel>
  3.         <TextBox x:Name="TextBox1" Margin="5"/>
  4.         <TextBox x:Name="TextBox2" Margin="5"/>
  5.         <TextBox x:Name="TextBox3" Margin="5"/>
  6.         <TextBox x:Name="TextBox4" Margin="5"/>
  7.         <Button x:Name="btn_Commit" Content="Commit" Margin="5" Click="btn_Commit_Click" />
  8.     </StackPanel>
  9. </Grid>
复制代码
2. C#逻辑
  1. public partial class MainWindow : Window
  2.     {
  3.         public MainWindow()
  4.         {
  5.             InitializeComponent();
  6.
  7.             SetMultiBinding();
  8.         }
  9.
  10.         private void btn_Commit_Click(object sender, RoutedEventArgs e)
  11.         {
  12.
  13.         }
  14.
  15.         private void SetMultiBinding()
  16.         {
  17.             Binding b1 = new Binding("Text") { Source = TextBox1 };  //注意此处数据源是TextBox对象,路径是Text属性;
  18.             Binding b2 = new Binding("Text") { Source = TextBox2 };
  19.             Binding b3 = new Binding("Text") { Source = TextBox3 };
  20.             Binding b4 = new Binding("Text") { Source = TextBox4 };
  21.
  22.             MultiBinding mb = new MultiBinding() { Mode = BindingMode.OneWay };
  23.             /* MultiBinding对Add顺序敏感 */
  24.             mb.Bindings.Add(b1);
  25.             mb.Bindings.Add(b2);
  26.             mb.Bindings.Add(b3);
  27.             mb.Bindings.Add(b4);
  28.
  29.             mb.Converter = new MultiBindingConvert();
  30.
  31.             btn_Commit.SetBinding(Button.IsEnabledProperty, mb);
  32.         }
  33.     }
  34.
  35.     /* 多路绑定数据转换 */
  36.     public class MultiBindingConvert : IMultiValueConverter
  37.     {
  38.         public object Convert(object[] values, Type targetType, object parameter, System.Globalization.CultureInfo culture)
  39.         {
  40.             if (!values.Cast<string>().Any(text => string.IsNullOrEmpty(text))&&
  41.                 values[0].ToString() == values[1].ToString()                  &&
  42.                 values[2].ToString() == values[3].ToString()
  43.                 )
  44.             {
  45.                 return true;
  46.             }
  47.
  48.             return false;
  49.         }
  50.
  51.         public object[] ConvertBack(object value, Type[] targetTypes, object parameter, System.Globalization.CultureInfo culture)
  52.         {
  53.             throw new NotImplementedException();
  54.         }
  55.     }
二、方式二(通过XAML绑定)
  1. <Window x:Class="WpfApp5.MainWindow"
  2.         xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
  3.         xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
  4.         xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
  5.         xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
  6.         xmlns:local="clr-namespace:WpfApp5"
  7.         mc:Ignorable="d"
  8.         Title="MainWindow" Height="198.5" Width="255">
  9.     <Window.Resources>
  10.         <local:LogonButtonEnableConvert x:Key="lbec"/>
  11.     </Window.Resources>
  12.     <Grid>
  13.         <StackPanel>
  14.             <TextBox x:Name="TextBox1" Margin="5"/>
  15.             <TextBox x:Name="TextBox2" Margin="5"/>
  16.             <TextBox x:Name="TextBox3" Margin="5"/>
  17.             <TextBox x:Name="TextBox4" Margin="5"/>
  18.             <Button x:Name="btn_Commit" Content="Commit" Margin="5" Click="btn_Commit_Click">
  19.                 <Button.IsEnabled>
  20.                     <MultiBinding Converter="{StaticResource lbec}" ConverterParameter="ParamTest">
  21.                         <Binding ElementName="TextBox1" Path="Text"/>
  22.                         <Binding ElementName="TextBox2" Path="Text"/>
  23.                         <Binding ElementName="TextBox3" Path="Text"/>
  24.                         <Binding ElementName="TextBox4" Path="Text"/>
  25.                     </MultiBinding>
  26.                 </Button.IsEnabled>
  27.             </Button>
  28.         </StackPanel>
  29.     </Grid>
  30. </Window>
2、C#数据转换类
  1. public class LogonButtonEnableConvert : IMultiValueConverter
  2. {
  3.     /*
  4.      * object[] values                          : 所绑定的源的值
  5.      * Type targetType                          : 目标的类型
  6.      * object parameter                         : 绑定时所传递的参数
  7.      * System.Globalization.CultureInfo culture : 系统语言等信息
  8.      */
  9.     public object Convert(object[] values, Type targetType, object parameter, System.Globalization.CultureInfo culture)
  10.     {
  11.         if (!values.Cast<string>().Any(text => string.IsNullOrEmpty(text))&&
  12.             values[0].ToString() == values[1].ToString()                  &&
  13.             values[2].ToString() == values[3].ToString()
  14.             )
  15.         {
  16.             return true;
  17.         }
  18.
  19.         return false;
  20.     }
  21.
  22.     public object[] ConvertBack(object value, Type[] targetTypes, object parameter, System.Globalization.CultureInfo culture)
  23.     {
  24.         throw new NotImplementedException();
  25.     }
  26. }
复制代码
发表于 2018-5-9 07:56:26 | 显示全部楼层
小博666……紫薯布丁
GMT+8, 2025-5-1 17:47 , Processed in 0.171960 second(s), 24 queries , Gzip On.
