查看: 950|回复: 6
各位大神,不知道能不能帮忙改下代码?
发表于 2018-5-3 18:10:50 | 显示全部楼层 |阅读模式
[size=13.3333px]这个插件是统计工作量的,GYTS-6B1、GYTS-12B1是[size=13.3333px]材料[size=13.3333px]型号,上面的管58、架24、余10;是该[size=13.3333px]材料[size=13.3333px]数量在哪里用掉的量,我现在有个插件可以批量统计出各[size=13.3333px]材料[size=13.3333px]型号及量,但插件只支持上面数值的表示格式是:管XX+架XX+余XX  这种格式的,但是我们一般用到的格式是管XX 架XX 余XX
[size=13.3333px]
---------------------以下是插件代码---------------------------------------------------
(defun c:zz()
(if *error* quit)
(setq cmdmode (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq myosmode (getvar "osmode"))
(setvar "osmode" 0)
(prompt "\n选择计算工作量对象: ")
(setq sset (ssget))
(if (null sset)
(princ "\n错误: 没有选择对象!\n")
;过滤出选中的“text”实体nsset。
(setq ssl (sslength sset))
(setq nsset (ssadd)) ;“text”实体
(setq nsset1 (ssadd)) ;工作量实体
(setq nsset2 (ssadd)) ;光、电缆程式实体
(while (> ssl 0)
  (setq temp (ssname sset (setq ssl(1- ssl))))
  (if (= (cdr (assoc 0 (entget temp))) "TEXT")
    (ssadd temp nsset)
(setq ssl (sslength nsset))
;选出形如"墙20+架10"的对象和"HYA10*0.4"。
(setq total 0)
(setq ssl1 ssl)
(setq ssl2 ssl)
(while (> ssl1 0)
  (setq temp (ssname nsset (setq ssl1 (1- ssl1))))
  (setq txt0 (cdr (assoc 1 (entget temp))))
  (selecttxt_dlcs)
  (selecttxt_gzl)
(gzl_duihao)
(gzl_guilei)
(gzl_culture)
(gzl_viewresult)
(setvar "OSMODE" myosmode)
(setvar "CMDECHO" cmdmode)
(prin1)
;;;选出形如"墙20+架10"
(defun selecttxt_gzl()
(setq re_call 0)
(setq txt_l (strlen txt0))
  ;形如"墙2*******"
(if (> txt_l 2)
    (if (and (> (ascii (substr txt0 1 1)) 128) (> (ascii (substr txt0 2 1)) 128) (< (ascii (substr txt0 3 1)) 58) (> (ascii (substr txt0 3 1)) 47))
      (setq txt0 (substr txt0 3 (- txt_l 2)))
      (setq re_call 1)
  ;形如"20.5+******"
  ;形如"20.5"
(if (and (< (ascii (substr txt0 1 1)) 58) (> (ascii (substr txt0 1 1)) 47) (= re_call 0))
       (setq i 0)
       (while (< i txt_l)
            (setq i (1+ i))
            (setq txt_it (ascii (substr txt0 i 1)))
            (if (and (= txt_it 43) (< i txt_l))
                (setq txt0 (substr txt0 (+ i 1) (- txt_l i)))
                (setq i txt_l)
                (setq re_call 1)))
            (if (and (or (> txt_it 57) (< txt_it 43) (= txt_it 44) (= txt_it 45) (= txt_it 47)) (= re_call 0))
                (setq i txt_l)
                (setq re_call 2)))
            (if (and (= i txt_l) (= re_call 0))
                (if (and (< txt_it 58) (> txt_it 47))
                (ssadd temp nsset1))
(if (= re_call 1) (selecttxt_gzl))
;;;选出"HYA"、"GYT"、"GYS"文字数
(defun selecttxt_dlcs()
(if (> txt_l 3)
    (if (or (= (substr txt0 1 3) "HYA") (= (substr txt0 1 3) "GYT") (= (substr txt0 1 3) "GYS"))
    (ssadd temp nsset2))
;;;工作量与电缆程式对号
(defun gzl_duihao()
  (setq duihao_ls1 nil)
  (setq duihao_ls2 nil)
  (setq nsset1_len (sslength nsset1))
  (while (> nsset1_len 0)
    (setq duihao_yes 0)
    (setq nsset1_temp (ssname nsset1 (setq nsset1_len (1- nsset1_len))))
    (setq nsset1_rd (cdr (assoc 50 (entget nsset1_temp))))
    (setq nsset1_pt (cdr (assoc 10 (entget nsset1_temp))))
    (setq nsset1_pt (list (car nsset1_pt) (cadr nsset1_pt)))
    (setq nsset2_len (sslength nsset2))
          (while (> nsset2_len 0)
                (setq nsset2_temp (ssname nsset2 (setq nsset2_len (1- nsset2_len))))
            (setq nsset2_rd (cdr (assoc 50 (entget nsset2_temp))))
            (if (or (< (abs (- nsset1_rd nsset2_rd)) 0.1) (> (abs (- nsset1_rd nsset2_rd)) 6.2))
                          (setq nsset2_pt (cdr (assoc 10 (entget nsset2_temp))))
                            (setq nsset2_pt (list (car nsset2_pt) (cadr nsset2_pt)))
                      (setq dis_n1n2 (distance nsset1_pt nsset2_pt))
                      (if (< dis_n1n2 12)         ;指定插入点间距范围
                               (setq n1n2_rd (- (angle nsset2_pt nsset1_pt) nsset1_rd))
                           (setq dis_yn1n2 (abs (* dis_n1n2 (sin n1n2_rd))))
                           (if (and (< dis_yn1n2 5) (>= n1n2_rd 0) (<= n1n2_rd Pi))
                                 (setq duihao_yes 1)
                                 (setq nsset2_temp1 nsset2_temp))
                             (if (and (< dis_yn1n2 5) (= duihao_yes 0))
                                 (setq duihao_yes 1)
        (if (= duihao_yes 0)
                   (setq duihao_lstemp nil)
                   (setq duihao_lstemp (cdr (assoc 1 (entget nsset1_temp))))
                   (setq duihao_ls2 (cons duihao_lstemp duihao_ls2))
        (if (= duihao_yes 1)
                    (setq duihao_lstemp (cons (cdr (assoc 1 (entget nsset2_temp1))) (cdr (assoc 1 (entget nsset1_temp)))))
                    (setq duihao_ls1 (cons duihao_lstemp duihao_ls1))
                    (ssdel nsset2_temp1 nsset2)
;归类
(defun gzl_guilei(/ guilei_temp1 guilei_temp2 guilei_temp3 guilei_temp4)
(setq guilei_temp1 duihao_ls1)
(setq guilei_result nil)
(while (/= guilei_temp1 nil)
     (setq guilei_temp2 (car guilei_temp1))
     (setq guilei_temp3 (car guilei_temp2))
     (setq guilei_temp1 (cdr guilei_temp1))
     (if (/= guilei_result nil)
           (if (/= (assoc guilei_temp3 guilei_result) nil)
                 (setq guilei_temp4 (cdr guilei_temp2))
                 (setq guilei_temp4 (strcat (cdr (assoc guilei_temp3 guilei_result)) "+" guilei_temp4))
                 (setq guilei_result (subst (cons guilei_temp3 guilei_temp4) (assoc guilei_temp3 guilei_result) guilei_result))
           (setq guilei_result (cons guilei_temp2 guilei_result)))
;计算工作量文字
(defun gzl_culture(/ cu_temp1 cu_temp2 cu_temp3 cu_temp4 cu_temp5 cu_temp6 cu_temp7 cu_temp8)
(setq cu_result nil)
(setq cu_temp1 guilei_result)
(while (/= cu_temp1 nil)
     (setq cu_temp6 nil)
     (setq cu_temp2 (car cu_temp1))
     (setq cu_temp3 (cdr cu_temp2))
     (setq cu_temp1 (cdr cu_temp1))
     (while (> (setq cu_te3_len (strlen cu_temp3)) 0)
         (setq i 0)
         (while (< i cu_te3_len)
             (setq i (1+ i))
             (setq cu_temp4 (substr cu_temp3 i 1))
             (if (= cu_temp4 "+")
                   (setq cu_temp5 (substr cu_temp3 1 (- i 1)))
                   (setq cu_temp3 (substr cu_temp3 (+ i 1)))
                   (setq i cu_te3_len)
              (if (= i cu_te3_len)
                  (setq cu_temp5 cu_temp3)
                  (setq cu_temp3 ""))))
         (if (and (< (ascii (substr cu_temp5 1 1)) 58) (> (ascii (substr cu_temp5 1 1)) 47))
           (setq cu_temp7 (cons " " cu_temp5))
           (setq cu_temp7 (cons (substr cu_temp5 1 2) (substr cu_temp5 3))))
         (if (or (= cu_temp6 nil) (= (assoc (car cu_temp7) cu_temp6) nil))
            (setq cu_temp6 (cons cu_temp7 cu_temp6))
                 (setq cu_temp8 (rtos (+ (atof (cdr (assoc (car cu_temp7) cu_temp6))) (atof (cdr cu_temp7)))))
                 (setq cu_temp6 (subst (cons (car cu_temp7) cu_temp8) (assoc (car cu_temp7) cu_temp6) cu_temp6))
    (setq cu_result (cons (cons (car cu_temp2) cu_temp6) cu_result))
;显示结果
(defun gzl_viewresult(/ viere_temp1 viere_temp2)
(setq viere_temp1 cu_result)
(while (/= viere_temp1 nil)
      (setq viere_temp2 (car viere_temp1))
      (setq viere_temp1 (cdr viere_temp1))
      (princ viere_temp2)
      (princ "\n")
(if (= duihao_ls2 nil)
  (princ "无可疑数据,图纸很标准。")
      (princ "以下数据为可疑数据,请认真核对:\n")
      (princ duihao_ls2)
 楼主| 发表于 2018-5-3 18:11:47 | 显示全部楼层
这个插件是统计工作量的,GYTS-6B1、GYTS-12B1是材料型号,上面的管58、架24、余10;是该材料数量在哪里用掉的量,我现在有个插件可以批量统计出各材料型号及量,但插件只支持上面数值的表示格式是:管XX+架XX+余XX  这种格式的,但是我们一般用到的格式是管XX 架XX 余XX
 楼主| 发表于 2018-5-3 18:14:47 | 显示全部楼层
插件是以前在论坛里找的,现在找不到那个帖子了。按照插件的要求是:管XX+架XX 这个是在一个单行文字里输入的,但我平时用的是管XX 架XX ,每一个都是一个单行文字
发表于 2018-5-3 23:06:59 | 显示全部楼层
代码太长了,而且又没测试图
你试下把这句(setq guilei_temp4 (strcat (cdr (assoc guilei_temp3 guilei_result)) "+" guilei_temp4))
改成(setq guilei_temp4 (strcat (cdr (assoc guilei_temp3 guilei_result)) guilei_temp4))
试试看
发表于 2018-5-4 09:37:55 | 显示全部楼层
jian445906829 发表于 2018-5-3 18:14
插件是以前在论坛里找的,现在找不到那个帖子了。按照插件的要求是:管XX+架XX 这个是在一个单行文字里输入 ...
既然自己不会,就尽可能按现成的要求做。原来要求在一个单行文字内,你分成两个,如何确定哪个对应哪个?程序就完全不一样了。
发表于 2018-5-7 09:42:54 | 显示全部楼层
对啊,这得要改很多代码的吧
发表于 2018-5-7 15:38:36 | 显示全部楼层
看到Lisp就头痛,为什么不用VC开发
GMT+8, 2025-5-24 19:32 , Processed in 0.255428 second(s), 24 queries , Gzip On.
