楼主: yxp
[资源] AutoCAD 发行版本与内部版本号
发表于 2018-4-26 08:05:21 | 显示全部楼层
感谢楼主,很全.希望其他大牛继续补充
发表于 2018-4-26 09:49:39 | 显示全部楼层
R2008哪来的64位版本?
发表于 2018-4-26 18:46:34 | 显示全部楼层
发表于 2018-4-27 22:47:06 | 显示全部楼层
History[edit]AutoCAD was derived from a program begun in 1977 and released in 1979[4] called Interact  CAD,[5][6][7] also referred to in early Autodesk documents as MicroCAD, which was written  prior to Autodesk's (then Marinchip Software Partners) formation by Autodesk  cofounder Michael  Riddle.[8][9]
The first version by Autodesk was demonstrated at the 1982 Comdex and  released that December.[10] As Autodesk's flagship product, by March 1986 AutoCAD had become the most  ubiquitous CAD program worldwide.[11] The  2019 release marked the 33rd major release of AutoCAD for Windows.  The 2014 release marked the fourth consecutive year of AutoCAD for Mac.
Version history[edit]The native file format of AutoCAD is .dwg.  This and, to a lesser extent, its interchange file format DXF, have  become de  facto, if proprietary, standards for CAD data interoperability,  particularly for 2D drawing exchange.[citation  needed] AutoCAD has included support for .dwf, a format  developed and promoted by Autodesk, for publishing CAD  data.
Autodesk's logo and, respectively, AutoCAD icons have changed for several  versions through the years.
Official nameVersionDWG        tag
ReleaseOS        support
Date of releaseComments
AutoCAD Version 1.0
1.0
1
1982, DecemberDWG R1.0 file format
AutoCAD Version 1.2
1.2
2
1983, AprilDWG R1.2 file format
AutoCAD Version 1.3
1.3
3
1983, AugustDWG R1.3 file format
AutoCAD Version 1.4
1.4
4
1983, OctoberDWG R1.4 file format
AutoCAD Version 2.0
2.0
5
1984, OctoberDWG R2.05 file format
AutoCAD Version 2.1
2.1
6
1985, MayDWG R2.1 file format
AutoCAD Version 2.5
2.5
7
1986, JuneDWG R2.5 file format
AutoCAD Version 2.6
2.6
8
1987, AprilDWG R2.6 file format. Last version to run without a math     co-processor.
AutoCAD Release 9
9.0
9
1987, SeptemberDWG R9 file format
AutoCAD Release 10
10.0
10
1988, OctoberDWG R10 file format
AutoCAD Release 11
11.0
11
1990, OctoberDWG R11 file format
AutoCAD Release 12
12.0
12
1992, JuneDWG R11/R12 file format. Last release for Apple Macintosh       till 2010.
AutoCAD Release 13
13.0
13
1994, NovemberDWG R13 file format. Last release for Unix,        MS-DOS       and Windows       3.11.
AutoCAD Release 14
14.0
14
1997, FebruaryDWG R14 file format
AutoCAD 2000
15.0
AC1015
15
1999, MarchDWG 2000 file format
AutoCAD 2000i
15.1
AC1015
16
2000, July
AutoCAD 2002
15.2
AC1015
17
2001, June
AutoCAD 2004
16.0
AC1018
18
2003, MarchDWG 2004 file format
AutoCAD 2005
16.1
AC1018
19
2004, March
AutoCAD 2006
16.2
AC1018
20
2005, MarchDynamic Block
AutoCAD 2007
17.0
AC1021
21
2006, MarchDWG 2007 file format
AutoCAD 2008
17.1
AC1021
22
2007, MarchAnnotative objects introduced. AutoCAD 2008 and higher (including       AutoCAD LT) can directly import and underlay DGN       V8 files.
AutoCAD 2009
17.2
AC1021
23
2008, MarchRevisions to the user interface including the option of a tabbed     ribbon
AutoCAD 2010
18.0
AC1024
24
Windows XP        Windows Vista
Windows 7[12][13][14]
2009, March 24DWG 2010 file format introduced. Parametrics introduced. Mesh 3D solid       modeling introduced. PDF underlays. Both 32-bit and 64-bit versions of       AutoCAD 2010 and AutoCAD LT 2010 are compatible with and supported under       Microsoft Windows 7.
AutoCAD 2011
18.1
AC1024
25
2010, March 25Surface modeling, surface analysis and object transparency introduced.       October 15, 2010[15]       AutoCAD 2011 for Mac was released. Are compatible with and supported under       Microsoft Windows 7
AutoCAD 2012
18.2
AC1024
26
2011, March 22Associative array, model documentation, DGN editing. Support for       complex line types in DGN files is improved in AutoCAD 2012.
AutoCAD 2013
19.0
AC1027
27
Windows XP Vista        Windows 7
Windows 8[16][17]
2012, March 27DWG 2013 file format (AC1027)
AutoCAD 2014
19.1
AC1027
28
2013, March 26File tabs, design feed, reality capture, Autodesk live maps
AutoCAD 2015
20.0
AC1027
29
Windows 7        Windows 8
Windows 8.1[18]
2014, March 27Line smoothing (anti-aliasing), Windows 8.1 support added, dropped       Windows XP support (incl. compatibility mode)
AutoCAD 2016
20.1
AC1027
30
Windows 7 SP1        Windows 8.1
Windows 10[19][20]
2015, March 23More comprehensive canvas, richer design context, and intelligent new       tools such as smart dimensioning, coordination model, and enhanced   PDFs
AutoCAD 2017
21.0
AC1027
31
2016, March 21PDF import, associative center marks, and centerlines, DirectX 11       graphics
AutoCAD 2018
22.0
AC1032
32
2017, March 21DWG 2018 file format
AutoCAD 2019
23.0
AC1032
33
Windows 8.1        Windows 10
2018, March 22Shared Views, DWG Compare, Save To AutoCAD Web &   Mobile
自贡黄明儒 + 1 很给力!
回复 支持 4 反对 0
发表于 2018-4-29 18:13:47 | 显示全部楼层
cad2002的版本应该15.2,系统变量返回的是15.06
关于cad版本的历史,可以参考这个链接
https://en.wikipedia.org/wiki/AutoCAD
发表于 2018-4-30 18:32:03 | 显示全部楼层
vectra 发表于 2018-4-25 12:10
谁有 AutoCAD 2008  64 位版本 发个链接我 一直没找到
https://pan.baidu.com/s/1eRHtaLk
你这个也是32位的,只是可以在win64下用  发表于 2018-6-23 17:29
发表于 2018-5-1 21:07:25 | 显示全部楼层
好像没有啊,国内支持软件也很少
发表于 2018-5-9 18:08:08 来自手机 | 显示全部楼层
非常有用,他这版本号更新好像没有规律
发表于 2018-9-18 07:38:43 | 显示全部楼层
BUBUBA918 发表于 2018-5-1 21:07
好像没有啊,国内支持软件也很少
AutoCAD2008版本,英文版有64位,中文版没有64位,要在64位系统安装中文版,需要修改32位版本的MSI才可以安装到64位系统。
发表于 2018-9-18 10:02:12 | 显示全部楼层
前生 发表于 2018-4-24 23:17
呵呵,10年前,在一家鬼子的厂里做设计时自己写了一些在模具上使用的LSP程序,在离职时,鬼子非要算是公司 ...
再加个时间限制就更好了,离职一年后程序就不运行了
GMT+8, 2025-7-4 19:07 , Processed in 0.185783 second(s), 20 queries , Gzip On.
