查看: 999|回复: 1
外部参照不绑定,请大侠看看,哪里有错,Vs2015,CAD2016
发表于 2018-1-1 17:28:39 | 显示全部楼层 |阅读模式
想绑定个外部参照为块,始终搞不定,哪位大侠帮我看看代码
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
namespace XrefBind
    public class class1
    [CommandMethod("BindingExternalReference")]
    public void BindingExternalReference()
        // Get the current database and start a transaction
        Database acCurDb;
        acCurDb = Application.DocumentManager.MdiActiveDocument.Database;
        using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                // Create a reference to a DWG file;创建一个参照
                string PathName = "C:\\Exterior Elevations.dwg";
                ObjectId acXrefId = acCurDb.AttachXref(PathName, "Exterior Elevations");
                // If a valid reference is created then continue
                if (!acXrefId.IsNull)
                    // Attach the DWG reference to the current space
                    Point3d insPt = new Point3d(1, 0, 0);
                    using (BlockReference acBlkRef = new BlockReference(insPt, acXrefId))
                        BlockTableRecord acBlkTblRec;
                        acBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                        acBlkTblRec.AppendEntity(acBlkRef);
                        acTrans.AddNewlyCreatedDBObject(acBlkRef, true);
                    Application.ShowAlertDialog("The external reference is attached.外部引用已附加");
                    using (ObjectIdCollection acXrefIdCol = new ObjectIdCollection())
                        acXrefIdCol.Add(acXrefId);
                    Application.ShowAlertDialog(acXrefIdCol.Count.ToString());
                    acCurDb.BindXrefs(acXrefIdCol, false);//这行代码有没有都是一样
                    //acTrans.Commit();
                    Application.ShowAlertDialog("The external reference is bound.外部引用被绑定");
                // Save the new objects to the database
                acTrans.Commit();
                // Dispose of the transaction
 楼主| 发表于 2018-2-3 16:23:08 | 显示全部楼层
自己顶一个
GMT+8, 2025-5-1 19:20 , Processed in 0.169282 second(s), 25 queries , Gzip On.
