查看: 2924|回复: 4
[基础] IntersectWith”已过时:“Use the overload taking IntPtr instead.”。 怎么解决?
发表于 2017-12-27 20:26:33 | 显示全部楼层 |阅读模式
警告        2        “Public Sub IntersectWith(entityPointer As Autodesk.AutoCAD.DatabaseServices.Entity, intersectType As Autodesk.AutoCAD.DatabaseServices.Intersect, projectionPlane As Autodesk.AutoCAD.Geometry.Plane, points As Autodesk.AutoCAD.Geometry.Point3dCollection, thisGraphicSystemMarker As Long, otherGraphicSystemMarker As Long)”已过时:“Use the overload taking IntPtr instead.”。
发表于 2017-12-28 11:16:37 | 显示全部楼层
splineLeft.IntersectWith(circleda2, Intersect.ExtendThis, JDcell, System.IntPtr.Zero, System.IntPtr.Zero);
 楼主| 发表于 2018-1-9 20:33:29 | 显示全部楼层
System.IntPtr.Zero 谢谢
发表于 2025-2-19 20:59:31 | 显示全部楼层
谜底就在迷面上
GMT+8, 2025-5-1 04:27 , Processed in 0.154071 second(s), 23 queries , Gzip On.
