查看: 1742|回复: 3
PromptSelectionResult 查询总是error
发表于 2017-12-20 17:07:49 | 显示全部楼层 |阅读模式
public class Class1
        [CommandMethod("GetLayerPro")]
        public static void GetLayerPro()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            //新建一个数据库对象以读取Dwg文件
            Database db = new Database(false, true);
            string fileName = "C:/Users/admin/Desktop/1.dwg";
            //如果指定文件名的文件存在
            if (System.IO.File.Exists(fileName))
                //把文件读入到数据库中
                db.ReadDwgFile(fileName, System.IO.FileShare.Read, true, null);
                using (Transaction trans = db.TransactionManager.StartTransaction())
                    //获取数据库的图层表对象
                    LayerTable lt = (LayerTable)trans.GetObject(db.LayerTableId, OpenMode.ForRead);
                    //循环遍历每个图层
                    foreach (ObjectId layerId in lt)
                        LayerTableRecord ltr = (LayerTableRecord)trans.GetObject(layerId, OpenMode.ForRead);
                        if (ltr != null)
                           List<ObjectId> entitys = GetLayerEntity(ltr.Name);
                           foreach (ObjectId id in entitys)
                                    Entity hatchobj = trans.GetObject(id, OpenMode.ForWrite) as Entity;
                                if (hatchobj != null)
                                    Debug.WriteLine("===============");
                                    TypedValue[] typedValue = hatchobj.XData.AsArray();
                                    if (typedValue[0].Value.Equals("PIPELINE") || typedValue[0].Value.Equals("PIPE"))
                                        foreach (TypedValue obj in hatchobj.XData)
                                            Debug.WriteLine(obj.Value);
                            Autodesk.AutoCAD.Colors.Color layerColor = ltr.Color;
                            ed.WriteMessage("\n图层名称为:" + ltr.Name);
                            ed.WriteMessage("\n图层颜色为:" + layerColor.ToString());
                    trans.Commit();
         //根据图层名获取该图层下的实体id
        public static List<ObjectId> GetLayerEntity(String layerName)
            List<ObjectId> entitys = new List<ObjectId>();
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            TypedValue[] values = { new TypedValue((int)DxfCode.LayerName, layerName) };
            SelectionFilter filters = new SelectionFilter(values);
            PromptSelectionResult result = ed.SelectAll(filters );
            PromptSelectionResult result = ed.SelectAll();
            if (result.Status == PromptStatus.OK)
                ObjectId[] ids = result.Value.GetObjectIds();
                foreach (ObjectId id in ids)
                    entitys.Add(id);
            else
                return entitys;
            return entitys;
红色部分为什么获取的都是error   ,  求大神来解释一下
发表于 2017-12-20 18:27:36 来自手机 | 显示全部楼层
你在当前文档过滤打开的文档的对象?没看懂你要做什么 如果是读入的db只能遍历 不能用选择集的
 楼主| 发表于 2017-12-21 08:59:45 | 显示全部楼层
如果要用选择集该怎么写,我这里是要分层读出每层的实体
发表于 2017-12-21 09:58:38 来自手机 | 显示全部楼层
用db.readdwg读入的文件是无法用选择集的 只能遍历
GMT+8, 2025-5-1 19:52 , Processed in 0.173745 second(s), 25 queries , Gzip On.
