查看: 3689|回复: 5
[运行时] ResultBuffer扩展类第二版
发表于 2017-12-3 14:00:24 | 显示全部楼层 |阅读模式
源码:
这一版的ResulrBuffer扩展类分为三大类分别对应扩展字典/数据、Lisp数据和选择集过滤器
其中
XdataList类对应扩展字典/数据
Lisp*类对应Lisp数据
Op*类对应选择集过滤器
测试代码:
  1.         [CommandMethod("tt1")]
  2.         public void Test1()
  3.         {
  4.             //扩展数据
  5.             XdataList lst =
  6.                 new XdataList
  7.                 {
  8.                     { 1001, "myapp" },
  9.                     { 1000, "hello" }
  10.                 };
  11.             //过滤器的三种写法
  12.             var fd =
  13.                 new OpOr
  14.                 {
  15.                         !new OpAnd
  16.                         {
  17.                             { 0, "line" },
  18.                             { 8, "0" },
  19.                         },
  20.                         new OpAnd
  21.                         {
  22.                             !new OpEqual(0, "circle"),
  23.                             { 8, "2" },
  24.                             { 10, new Point3d(10,10,0), ">,>,*" }
  25.                         },
  26.                 };
  27.             var p = new Point3d(10, 10, 0);
  28.             var f =
  29.                 OpFilter.Bulid(
  30.                     e =>
  31.                         !(e.Dxf(0) == "line" & e.Dxf(8) == "0") |
  32.                         e.Dxf(0) != "circle" & e.Dxf(8) == "2" & e.Dxf(10) >= p
  33.                     );
  34.             var f2 =
  35.                 OpFilter.Bulid(
  36.                     e =>
  37.                         e.Or(
  38.                         !e.And(e.Dxf(0) == "line", e.Dxf(8) == "0"),
  39.                         e.And(e.Dxf(0) != "circle", e.Dxf(8) == "2", e.Dxf(10) <= new Point3d(10, 10, 0)))
  40.                     );
  41.             SystemManager.Editor.WriteMessage($"\nXdataList:{lst}\n{fd}\n{f}\n{f2}");
  42.         }
  43.         [LispFunction("mytt")]
  44.         public object LispTest(ResultBuffer rb)
  45.         {
  46.             var rl = LispList.FromBuffer(rb);
  47.             return rl[0].GetValue();
  48.         }
  49.         [LispFunction("mytt2")]
  50.         public object LispTest2(ResultBuffer rb)
  51.         {
  52.             var r2 =
  53.                 new LispList
  54.                 {
  55.                     0,
  56.                     new LispDottedPair{ 12, 13 }
  57.                 };
  58.             return r2.GetValue();
  59.         }
 楼主| 发表于 2017-12-3 18:30:08 | 显示全部楼层
结果
命令:
  1. TT1
  2. XdataList:((1001,myapp)(1000,hello))
  3. (-4,<Or)(-4,<Not)(-4,<And)(0,line)(8,0)(-4,And>)(-4,Not>)(-4,<And)(-4,<Not)(0,circle)(-4,Not>)(8,2)(-4,>,>,*)(10,(10,10,0))(-4,And>)(-4,Or>)
  4. (-4,<Or)(-4,<Not)(-4,<And)(0,line)(8,0)(-4,And>)(-4,Not>)(-4,<And)(-4,<Not)(0,circle)(-4,Not>)(8,2)(-4,>,>,*)(10,(10,10,0))(-4,And>)(-4,Or>)
  5. (-4,<Or)(-4,<Not)(-4,<And)(0,line)(8,0)(-4,And>)(-4,Not>)(-4,<And)(-4,<Not)(0,circle)(-4,Not>)(8,2)(-4,<,<,*)(10,(10,10,0))(-4,And>)(-4,Or>)
  6. 命令: (mytt2)
  7. (0 (12 . 13))
  8. 命令: (mytt '(1 (2 . 3)))
  9. (1 (2 . 3))
复制代码
发表于 2017-12-5 12:45:08 | 显示全部楼层
学习了,非常感谢!!
发表于 2017-12-21 23:16:39 | 显示全部楼层
飞狐出品,必属精品
发表于 2017-12-27 23:29:13 | 显示全部楼层
厉害,好好拜读下
发表于 2018-6-11 19:05:21 | 显示全部楼层
厉害,好好拜读下
GMT+8, 2025-5-23 07:51 , Processed in 0.167113 second(s), 23 queries , Gzip On.
