查看: 2564|回复: 3
矩阵 按钮提示
发表于 2017-11-7 17:29:13 | 显示全部楼层 |阅读模式
; Buttons from assoc list (matrix):
; dlglbl - dialog's label
; size - list of '(width height) - must be numerical
; aL - assoc list of strings, each item defines a row, the strings must be unique (they are used as keys)
(defun PromptWithMatrixButtons ( dlglbl size aL / LM:Unique-p *error* dcl des dch dcf r )
  ;; Unique-p  -  Lee Mac ;; Returns T if the supplied list contains distinct items.
  (defun LM:Unique-p ( l ) (vl-every (function (lambda ( x ) (not (member x (setq l (cdr l)))))) l) )
  (defun *error* ( msg )
    (and (< 0 dch) (unload_dialog dch))
    (and (eq 'FILE (type des)) (close des))
    (and (eq 'STR (type dcl)) (findfile dcl) (vl-file-delete dcl))
    (and msg (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\nError: " msg)) ))
  ); defun *error*
  (cond
    ( (not (vl-consp aL)) (princ "\n Invalid input - aL is not a list.") )
    ( (not (vl-every '(lambda (x) (and (vl-consp x) (vl-every '(lambda (s) (or (not s) (eq 'STR (type s)))) x))) aL))
      (princ "\nInvalid list, the format must be assoc list of strings")
    ( (not (LM:Unique-p (mapcar '(lambda (x) (strcase x)) (vl-remove-if 'null (apply 'append aL)))))
      (princ "\n Invalid list, it contains duplicate keys.")
      (not
        (and (setq dcl (vl-filename-mktemp nil nil ".dcl")) (setq des (open dcl "w"))
          (mapcar (function (lambda (x) (princ (strcat "\n" x) des)))
            (list
              "PromptWithMatrixButtons : dialog"
              (strcat "{ label = \"" (if (eq 'STR (type dlglbl)) dlglbl "") "\"; children_alignment = centered; spacer;")
              (apply 'strcat
                (mapcar
                  '(lambda (x)
                    (strcat
                      "\n: row"
                      "\n{"
                      (apply 'strcat
                        (mapcar
                          (function
                            (lambda ( keylbl )
                              (if keylbl
                                (strcat
                                  "\n: button"
                                  "{ label = \"" keylbl "\"; key = \"" keylbl "\"; "
                                  (if (and (vl-consp size) (= 2 (length size)))
                                    (strcat
                                      (if (numberp (car size)) (strcat "width = "(vl-princ-to-string (car size))";") "")
                                      (if (numberp (cadr size)) (strcat "height = "(vl-princ-to-string (cadr size))";") "")
                                    ); strcat
                                  ); if
                                ); strcat
                                (strcat
                                  "\n : button"
                                  "is_enabled = false;"
                                    (strcat
                                    ); strcat
                                  ); if
                                ); strcat
                              ); if keylbl
                            ); lambda (keylbl)
                        ); mapcar
                      ); apply 'strcat
                      "\n}"
                    ); strcat
                  ); lambda (x)
                  aL
                ); mapcar
              ); apply 'strcat
              "  spacer; ok_only;"
            ); list
          ); mapcar
          (not (setq des (close des))) (< 0 (setq dch (load_dialog dcl)))
        ); and
      ); not
      (princ "\n Unable to write or load the DCL file.")
    ( (not (new_dialog "PromptWithMatrixButtons" dch)) (princ "\n Unable to display the dialog") )
        (mapcar '(lambda (k) (action_tile k (vl-prin1-to-string '(progn (setq r $key) (done_dialog 1))))) (vl-remove 'nil (apply 'append aL)))
        (action_tile "accept" (vl-prin1-to-string '(done_dialog 0)))
        (/= 1 (setq dcf (start_dialog)))
      ); progn
      (princ "\n User cancelled the dialog.")
  ); cond
  (*error* nil) r
); defun PromptWithMatrixButtons
(defun c:11()
(PromptWithMatrixButtons "Matrix Buttons Prompt" '(8 3)
    ("A1" "B1" "C1" "D1" "E1" "F1" "G1" "H1" "I1" "J1" "K1" "L1" "M1" "N1") ; <- row
    ("A2" "B2" "C2" "D2" "E2" "F2" "G2" "H2" "I2" "J2" "K2" "L2" "M2" "N2")
    ("A3" "B3" "C3" "D3" "E3" "F3" "G3" "H3" "I3" "J3" "K3" "L3" "M3" "N3")
    ("A4" "B4" "C4" "D4" "E4" "F4" "G4" "H4" "I4" "J4" "K4" "L4" "M4" "N4")
    ("A5" "B5" "C5" "D5" "E5" "F5" "G5" "H5" "I5" "J5" "K5" "L5" "M5" "N5")
    ("A6" "B6" "C6" "D6" "E6" "F6" "G6" "H6" "I6" "J6" "K6" "L6" "M6" "N6")
    ("A7" "B7" "C7" "D7" "E7" "F7" "G7" "H7" "I7" "J7" "K7" "L7" "M7" "N7")
    ("A8" "B8" "C8" "D8" "E8" "F8" "G8" "H8" "I8" "J8" "K8" "L8" "M8" "N8")
    ("A9" "B9" "C9" "D9" "E9" "F9" "G9" "H9" "I9" "J9" "K9" "L9" "M9" "N9")
  );  ^ column
发表于 2017-11-7 20:05:07 来自手机 | 显示全部楼层
太了,处处都是高!
发表于 2017-11-10 08:34:29 | 显示全部楼层
(defun c:11() . . .  (princ))中的(princ)语句应注释掉,不然,就不能返回你究竟是按了哪个按钮
发表于 2021-2-9 21:47:22 | 显示全部楼层
调用函数没整成功,版主能讲一下吗?
GMT+8, 2025-5-24 20:19 , Processed in 0.165488 second(s), 24 queries , Gzip On.
