查看: 1621|回复: 7
求高手改个选择显示代码
发表于 2017-10-18 17:40:28 | 显示全部楼层 |阅读模式
已有筛好的对象,不要代码里的选中步骤,直接显示已选中的对象.
(defun c:hredraw ( / YH_DOWHAT YH_INDEX YH_SELECTION YH_SELECTION1)
  (setq YH_selection (ssget))
  (initget "H R")
  (setq YH_dowhat (GETKWORD "\n隐藏选择对象<H>;保留选择对象<R>"))
  (if (or (= YH_dowhat "R") (= YH_dowhat "r"))
      (setq YH_selection1 (ssget "X"))
      (setq YH_index 0)
      (repeat (sslength YH_selection)
(setq YH_selection1 (ssdel (ssname YH_selection YH_index) YH_selection1))
(setq YH_index (1+ YH_index))
      (setq YH_selection YH_selection1)
  (setq YH_index 0)
    (redraw (ssname YH_selection YH_index) 2)
发表于 2017-10-19 10:01:07 | 显示全部楼层
路过,顶一下
发表于 2017-10-19 15:11:10 | 显示全部楼层
  1. (defun c:cc (/ YH_INDEX YH_SELECTION YH_SELECTION1)
  2.   (setq YH_selection (ssget))
  3.   (setq YH_selection1 (ssget "X"))
  4.   (setq YH_index 0)
  5.   (repeat (sslength YH_selection)
  6.     (setq YH_selection1
  7.            (ssdel (ssname YH_selection YH_index) YH_selection1)
  8.     )
  9.     (setq YH_index (1+ YH_index))
  10.   )
  11.   (setq YH_selection YH_selection1)
  12.   (setq YH_index 0)
  13.   (repeat (sslength YH_selection)
  14.     (redraw (ssname YH_selection YH_index) 2)
  15.     (setq YH_index (1+ YH_index))
  16.   )
  17.   (princ)
  18. )
参与人数 1金钱 +10 收起 理由
ccc230 + 10 很给力!
 楼主| 发表于 2017-10-19 17:14:35 | 显示全部楼层
琴剑江山_10184  我试了,很好呢,谢谢哈
发表于 2017-10-19 18:53:59 | 显示全部楼层
隐藏后,如何全部显示呢
发表于 2017-10-20 17:32:26 | 显示全部楼层
command: Regen
 楼主| 发表于 2017-10-21 16:41:07 | 显示全部楼层
重生成图形命令
command: Regen
发表于 2022-12-8 09:17:55 | 显示全部楼层
高手实在是高啊
GMT+8, 2025-5-25 18:22 , Processed in 0.176511 second(s), 27 queries , Gzip On.
